Testing BSP package using beaglebone black
Niteesh G. S. niteesh.gs at gmail.com
Mon Feb 24 06:32:45 UTC 2020
Hii,
Can you just check if you have the ARM toolchain installed?
The guide that you mentioned is for RTEMS 4.11 and maybe things changed
with RTEMS 5.
If you don't have it installed you can do in a similar way as you did for
sparc
$ ../source-builder/sb-set-builder --source-only-download 5/rtems-arm
$ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
5/rtems-arm
After this, you should be able to build your BSP.
Thank you,
Niteesh
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200224/64fc218b/attachment.html>
