SPDX License Identifier Only and Full Copy?
Joel Sherrill
joel at rtems.org
Mon Feb 24 12:22:17 UTC 2020
On Mon, Feb 24, 2020, 6:03 AM Sebastian Huber <
> Hello Andrew,
> On 24/02/2020 10:48, Andrew Butterfield wrote:
> > Hi Sebastian,
> > a quick question
> > - does the Doxygen block requirement also apply to test programs
> (xxtest/init.c),
> > either hand-written or model-generated?
> we currently don't use Doxygen in the tests. There is some test
> documentation in the *.doc files of the test suite. I would like to
> improve the test documentation with the test specification items, but
> this is a future topic.
> It is probably a good approach to add some documentation to generated
> files if it is available at a higher level.
It would be good if the tests had at least file level Doxygen. But that's a
lot of retrofitting.
Andrew may not realise that Doxygen is newer than RTEMS and that all
Doxygen comments are later additions or conversions of the previous comment
format.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200224/cefa8e25/attachment.html>
