[PATCH 2/2] rtems: Add rtems_scheduler_map_from_posix_priority()
Mon Feb 24 13:07:44 UTC 2020
Update #3881.
 cpukit/Makefile.am                       |  1 +
 cpukit/include/rtems/rtems/tasks.h       | 18 ++++++++
 cpukit/rtems/src/schedulermapfromposix.c | 70 ++++++++++++++++++++++++++++++++
 testsuites/sptests/spscheduler01/init.c  | 44 ++++++++++++++++++++
 4 files changed, 133 insertions(+)
 create mode 100644 cpukit/rtems/src/schedulermapfromposix.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index f5374efab7..9ed260addb 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -769,6 +769,7 @@ librtemscpu_a_SOURCES += rtems/src/schedulergetprocessorset.c
 librtemscpu_a_SOURCES += rtems/src/scheduleridentbyprocessor.c
 librtemscpu_a_SOURCES += rtems/src/scheduleridentbyprocessorset.c
 librtemscpu_a_SOURCES += rtems/src/schedulerident.c
+librtemscpu_a_SOURCES += rtems/src/schedulermapfromposix.c
 librtemscpu_a_SOURCES += rtems/src/schedulermaptoposix.c
 librtemscpu_a_SOURCES += rtems/src/schedulerremoveprocessor.c
 librtemscpu_a_SOURCES += rtems/src/sem.c
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 9f4d918149..3ee7946df2 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -754,6 +754,24 @@ rtems_status_code rtems_scheduler_map_to_posix_priority(
   int                 *posix_priority
+ * @brief Map a POSIX thread priority to the corresonding task priority.
+ * @param scheduler_id Identifier of the scheduler instance.
+ * @param posix_priority The POSIX thread priority to map.
+ * @param[out] priority Pointer to a task priority value.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a priority parameter is @c NULL.
+ * @retval RTEMS_INVALID_ID Invalid scheduler instance identifier.
+ * @retval RTEMS_INVALID_PRIORITY Invalid POSIX thread priority.
+rtems_status_code rtems_scheduler_map_from_posix_priority(
+  rtems_id             scheduler_id,
+  int                  posix_priority,
+  rtems_task_priority *priority
 #ifdef __cplusplus
diff --git a/cpukit/rtems/src/schedulermapfromposix.c b/cpukit/rtems/src/schedulermapfromposix.c
new file mode 100644
index 0000000000..ccf56e1465
--- /dev/null
+++ b/cpukit/rtems/src/schedulermapfromposix.c
@@ -0,0 +1,70 @@
+ * @file
+ * @ingroup ClassicTasks
+ * @brief Implementation of rtems_scheduler_map_from_posix_priority().
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/posix/priorityimpl.h>
+#include <rtems/score/schedulerimpl.h>
+  const Scheduler_Control *scheduler;
+  Priority_Control         core_priority;
+  bool                     valid;
+  if ( priority == NULL ) {
+    return RTEMS_INVALID_ADDRESS;
+  scheduler = _Scheduler_Get_by_id( scheduler_id );
+  if ( scheduler == NULL ) {
+    return RTEMS_INVALID_ID;
+  core_priority = _POSIX_Priority_To_core( scheduler, posix_priority, &valid );
+  if ( !valid ) {
+    return RTEMS_INVALID_PRIORITY;
+  *priority = _RTEMS_Priority_From_core( scheduler, core_priority );
+  return RTEMS_SUCCESSFUL;
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index 3b94adf36f..f086cb05c0 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -534,6 +534,49 @@ static void test_scheduler_map_to_posix(void)
   rtems_test_assert(posix_priority == 1);
+static void test_scheduler_map_from_posix(void)
+  rtems_status_code sc;
+  rtems_task_priority priority;
+  rtems_id scheduler_id;
+  priority = 123;
+  sc = rtems_scheduler_map_from_posix_priority(invalid_id, 1, &priority);
+  rtems_test_assert(sc == RTEMS_INVALID_ID);
+  rtems_test_assert(priority == 123);
+  sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_scheduler_map_from_posix_priority(scheduler_id, 1, NULL);
+  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+  priority = 123;
+  sc = rtems_scheduler_map_from_posix_priority(scheduler_id, -1, &priority);
+  rtems_test_assert(sc == RTEMS_INVALID_PRIORITY);
+  priority = 123;
+  sc = rtems_scheduler_map_from_posix_priority(scheduler_id, 0, &priority);
+  priority = 123;
+  sc = rtems_scheduler_map_from_posix_priority(scheduler_id, 255, &priority);
+  priority = 123;
+  sc = rtems_scheduler_map_from_posix_priority(scheduler_id, 1, &priority);
+  rtems_test_assert(priority == 254);
+  priority = 123;
+  sc = rtems_scheduler_map_from_posix_priority(scheduler_id, 254, &priority);
+  rtems_test_assert(priority == 1);
 static void test_scheduler_get_processors(void)
@@ -663,6 +706,7 @@ static void Init(rtems_task_argument arg)
   test_scheduler_ident();
   test_scheduler_get_max_prio();
   test_scheduler_map_to_posix();
+  test_scheduler_map_from_posix();
   test_scheduler_get_processors();
   test_scheduler_add_remove_processors();
   test_task_get_priority();
2.16.4
