[PATCH 1/2] rtems: Add rtems_scheduler_map_to_posix_priority()
Sebastian Huber
Mon Feb 24 13:07:43 UTC 2020
Update #3881.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/rtems/tasks.h | 18 ++++++++
cpukit/rtems/src/schedulermaptoposix.c | 81 +++++++++++++++++++++++++++++++++
testsuites/sptests/spscheduler01/init.c | 52 ++++++++++++++++++---
4 files changed, 145 insertions(+), 7 deletions(-)
create mode 100644 cpukit/rtems/src/schedulermaptoposix.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 85b427848a..f5374efab7 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -769,6 +769,7 @@ librtemscpu_a_SOURCES += rtems/src/schedulergetprocessorset.c
librtemscpu_a_SOURCES += rtems/src/scheduleridentbyprocessor.c
librtemscpu_a_SOURCES += rtems/src/scheduleridentbyprocessorset.c
librtemscpu_a_SOURCES += rtems/src/schedulerident.c
+librtemscpu_a_SOURCES += rtems/src/schedulermaptoposix.c
librtemscpu_a_SOURCES += rtems/src/schedulerremoveprocessor.c
librtemscpu_a_SOURCES += rtems/src/sem.c
librtemscpu_a_SOURCES += rtems/src/semcreate.c
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 307b1b13aa..9f4d918149 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -736,6 +736,24 @@ rtems_status_code rtems_scheduler_get_maximum_priority(
rtems_task_priority *priority
+ * @brief Map a task priority to the corresonding POSIX thread priority.
+ * @param scheduler_id Identifier of the scheduler instance.
+ * @param priority The task priority to map.
+ * @param[out] posix_priority Pointer to a POSIX thread priority value.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a posix_priority parameter is @c NULL.
+ * @retval RTEMS_INVALID_ID Invalid scheduler instance identifier.
+ * @retval RTEMS_INVALID_PRIORITY Invalid task priority.
+rtems_status_code rtems_scheduler_map_to_posix_priority(
+ rtems_id scheduler_id,
+ rtems_task_priority priority,
+ int *posix_priority
#ifdef __cplusplus
diff --git a/cpukit/rtems/src/schedulermaptoposix.c b/cpukit/rtems/src/schedulermaptoposix.c
new file mode 100644
index 0000000000..12215b89e1
--- /dev/null
+++ b/cpukit/rtems/src/schedulermaptoposix.c
@@ -0,0 +1,81 @@
+ * @file
+ * @ingroup ClassicTasks
+ * @brief Implementation of rtems_scheduler_map_to_posix_priority().
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/posix/priorityimpl.h>
+#include <rtems/score/schedulerimpl.h>
+ const Scheduler_Control *scheduler;
+ Priority_Control core_priority;
+ bool valid;
+ int maybe_priority;
+ if ( posix_priority == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
+ scheduler = _Scheduler_Get_by_id( scheduler_id );
+ if ( scheduler == NULL ) {
+ return RTEMS_INVALID_ID;
+ core_priority = _RTEMS_Priority_To_core( scheduler, priority, &valid );
+ if ( !valid ) {
+ return RTEMS_INVALID_PRIORITY;
+ maybe_priority = _POSIX_Priority_From_core( scheduler, core_priority );
+ if ( maybe_priority < POSIX_SCHEDULER_MINIMUM_PRIORITY ) {
+ if ( maybe_priority >= scheduler->maximum_priority ) {
+ *posix_priority = maybe_priority;
+ return RTEMS_SUCCESSFUL;
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index f42e60c593..3b94adf36f 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -1,11 +1,5 @@
- * Copyright (c) 2014, 2018 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * Copyright (C) 2014, 2020 embedded brains GmbH (http://www.embedded-brains.de)
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -497,6 +491,49 @@ static void test_scheduler_get_max_prio(void)
rtems_test_assert(priority == 255);
+static void test_scheduler_map_to_posix(void)
+ rtems_status_code sc;
+ int posix_priority;
+ rtems_id scheduler_id;
+ posix_priority = 123;
+ sc = rtems_scheduler_map_to_posix_priority(invalid_id, 1, &posix_priority);
+ rtems_test_assert(sc == RTEMS_INVALID_ID);
+ rtems_test_assert(posix_priority == 123);
+ sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_scheduler_map_to_posix_priority(scheduler_id, 1, NULL);
+ rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+ sc = rtems_scheduler_map_to_posix_priority(scheduler_id, 0, &posix_priority);
+ rtems_test_assert(sc == RTEMS_INVALID_PRIORITY);
+ sc = rtems_scheduler_map_to_posix_priority(scheduler_id, 255, &posix_priority);
+ sc = rtems_scheduler_map_to_posix_priority(scheduler_id, 256, &posix_priority);
+ sc = rtems_scheduler_map_to_posix_priority(scheduler_id, 1, &posix_priority);
+ rtems_test_assert(posix_priority == 254);
+ sc = rtems_scheduler_map_to_posix_priority(scheduler_id, 254, &posix_priority);
+ rtems_test_assert(posix_priority == 1);
static void test_scheduler_get_processors(void)
@@ -625,6 +662,7 @@ static void Init(rtems_task_argument arg)
test_task_get_set_scheduler();
test_scheduler_ident();
test_scheduler_get_max_prio();
+ test_scheduler_map_to_posix();
test_scheduler_get_processors();
test_scheduler_add_remove_processors();
test_task_get_priority();
2.16.4
