Testing BSP package using beaglebone black
Mon Feb 24 15:45:54 UTC 2020
On Mon, Feb 24, 2020 at 8:44 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hello John,
> On Sun, Feb 23, 2020 at 10:16 PM John kongtcheu <johnkongtcheu at gmail.com> wrote:
> > Hello,
> > I was just testing the bsp package using beagleboard and I ran into an error when trying to build the bsp. I received the error
> > checking for arm-rtems5-gcc... no
> > configure: error: no acceptable cc found in $PATH
> You need to first build and install the RTEMS Toolchain for the ARM
> target (arm-rtems5) to your PATH. You can follow a similar approach as
> taken to build the sparc toolchain in the Getting Started guide, but
> replace sparc with arm.
> > Makefile:740: recipe for target 'beagleboardxm' failed
> You need to configure for the beagleboneblack BSP, not the
> beagleboardxm BSP. Can you show your command line for configure to
> RTEMS?
> > make[2]: *** [beagleboardxm] Error 1
> > make[2]: Leaving directory '/home/kingkong/Coding-Projects/build/beagle-black/arm-rtems5/c'
> > Makefile:289: recipe for target 'all-recursive' failed
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory '/home/kingkong/Coding-Projects/build/beagle-black/arm-rtems5/c'
> > For more extensive details see the screenshot below. I tried re-bootstraping and following the guide for the hello-world example, but I still received the same error message. I was using the guide listed on the ideas page ("http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html")
> > The current path I used was /home/kingkong/Coding-Projects/rtems/5/bin:$PATH.
> That Guide is outdated. You can follow many of the steps in it, but
> you should use our official repositories instead of Ben's forks on
> github. All the support needed for BBB has been merged into our repos
> by now. I think you might find better up-to-date instructions if you
> look at blog posts from GSoC Students who worked on BBB in the last
> couple of years.
> There is also user documentation for the beagle at
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#beagle
> > Thank you for your help
PS: Instead of attaching a screenshot of a terminal, you can attach a
text file of the terminal output. That would be more likely to be
analyzed completely.
> > devel mailing list
> > devel at rtems.org
