[PATCH] tester: Use prefix for rtems_tools by default
Sebastian Huber
Tue Feb 25 08:33:59 UTC 2020
Hello Chris,
On 14/02/2020 07:14, Sebastian Huber wrote:
> On 14/02/2020 03:54, Chris Johns wrote:
>> On 2020-02-12 17:27, Sebastian Huber wrote:
>>> Commit 72c684eff2cd932b4948e21902680a93473340c3 removed the default
>>> value of rtems_tools. If the --rtems--tools option was omitted the
>>> rtems-test command printed lots of
>>> error: run.cfg:61: macro '%{rtems_tools}' not found
>>> error messages.
>> I will need to think about this. I am wondering id removing the prefix
>> code allowed the PATH to be used.
> I have rtems-test in the $PATH and calling it without --rtems-tools
> doesn't work without this patch.
could you please have a look at this. Since the %{rtems_tools} macros
needed it should be defined:
grep -r rtems_tools --include '*.cfg'
tester/rtems/testing/gdb.cfg:%define gdb_cmd
%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-gdb
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
