[PATCH] tester: Use prefix for rtems_tools by default
Fri Feb 14 06:14:02 UTC 2020
On 14/02/2020 03:54, Chris Johns wrote:
> On 2020-02-12 17:27, Sebastian Huber wrote:
>> Commit 72c684eff2cd932b4948e21902680a93473340c3 removed the default
>> value of rtems_tools.  If the --rtems--tools option was omitted the
>> rtems-test command printed lots of
>>     error: run.cfg:61: macro '%{rtems_tools}' not found
>> error messages.
> I will need to think about this. I am wondering id removing the prefix
> code allowed the PATH to be used.
I have rtems-test in the $PATH and calling it without --rtems-tools
doesn't work without this patch.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200214/e2c8d64d/attachment.html>
