RTEMS test
Cláudio Maia clrrm at isep.ipp.pt
Tue Feb 25 09:47:15 UTC 2020
Hi John,
You need to add the toolchain binaries to your path in the shell in order for them to be found by your shell when you invoke them.
Thus, after you build and install the toolchain (in this case for ARM architectures) with the following command (where $RTEMS is given by, for instance, "export RTEMS=~/rtems/"):
$ ../source-builder/sb-set-builder --prefix=$RTEMS/5 5/rtems-arm
You can add the toolchain binaries to the path by typing the following in the shell:
$ export PATH=$RTEMS/5/bin:$PATH
After that you should be able to use "rtems-test" and all the other binaries in "$RTEMS/5/bin".
Hope this helps.
Regards,
Cláudio
On 25/02/20 06:19, John kongtcheu wrote:
> Hello,
> I'm trying to run the rtems-test after closing my computer and switching operating systems(dual booted computer), but weirdly enough, I received the message
> rtems-test: command not found
> So I attempted running the command for rtems-tools, but then the message I received was
>  ./rtems-test --lists-bsps
> error: RTEMS Toolkit python wrapper not found, plrease report
> Understand, I had previously been able to run the rtems-test command fine before, this was only after I turned off ubuntu, turned on Windows, and then turned off Windows and turned on ubuntu that this error occurred.
> I'd greatly appreciate help in this mater.
> Thank you,
> devel mailing list
> devel at rtems.org
