Coverity false positive pattern
Joel Sherrill
joel at rtems.org
Tue Feb 25 15:51:22 UTC 2020
On Tue, Feb 25, 2020 at 9:47 AM suyash singh <suyashsingh234 at gmail.com>
wrote:
> Coverity shows value_overwrite errors for variables which are reassigned
> new values. What should be the procedure to prevent these?
When I have seen these in the past, they indicate a case where a variable
is assigned
and assigned later without the first value being used. Is this what you are
seeing?
What file and line?
We sometimes assign a variable 0 when declaring it to avoid gcc warning
about used
before initialized. It wouldn't surprise me if Scan didn't always like that.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200225/e9bf037e/attachment.html>
