Coverity false positive pattern
suyash singh suyashsingh234 at gmail.com
Tue Feb 25 16:38:42 UTC 2020
Yes it is showing for unused values
For example at line 262 in
https://scan5.coverity.com/reports.htm#v53137/p10069/fileInstanceId=164938787&defectInstanceId=45953284&mergedDefectId=1399751
On Tue, Feb 25, 2020 at 9:21 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Feb 25, 2020 at 9:47 AM suyash singh <suyashsingh234 at gmail.com>
> wrote:
>> Coverity shows value_overwrite errors for variables which are reassigned
>> new values. What should be the procedure to prevent these?
> When I have seen these in the past, they indicate a case where a variable
> is assigned
> and assigned later without the first value being used. Is this what you
> are seeing?
> What file and line?
> We sometimes assign a variable 0 when declaring it to avoid gcc warning
> about used
> before initialized. It wouldn't surprise me if Scan didn't always like
> that.
> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200225/60ff6ca8/attachment.html>
