Coverity false positive pattern
Gedare Bloom
gedare at rtems.org
Tue Feb 25 21:00:25 UTC 2020
On Tue, Feb 25, 2020 at 9:38 AM suyash singh <suyashsingh234 at gmail.com> wrote:
> Yes it is showing for unused values
> For example at line 262 in https://scan5.coverity.com/reports.htm#v53137/p10069/fileInstanceId=164938787&defectInstanceId=45953284&mergedDefectId=1399751
That appears to be legitimate. Analysis now has to be made whether the
value written should have been consumed somewhere, or if it is OK to
remove the assignment.
> On Tue, Feb 25, 2020 at 9:21 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Feb 25, 2020 at 9:47 AM suyash singh <suyashsingh234 at gmail.com> wrote:
>>> Coverity shows value_overwrite errors for variables which are reassigned new values. What should be the procedure to prevent these?
>> When I have seen these in the past, they indicate a case where a variable is assigned
>> and assigned later without the first value being used. Is this what you are seeing?
>> What file and line?
>> We sometimes assign a variable 0 when declaring it to avoid gcc warning about used
>> before initialized. It wouldn't surprise me if Scan didn't always like that.
>> --joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
