SPDX License Identifier Only and Full Copy?
Chris Johns
chrisj at rtems.org
Wed Feb 26 04:17:56 UTC 2020
On 26/2/20 3:06 pm, Gedare Bloom wrote:
> On Tue, Feb 25, 2020 at 6:57 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 24/2/20 6:52 pm, Sebastian Huber wrote:
>>> Hello,
>>> I updated the File Template section:
>>> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html
>>> Please have a look at it and check if it is all right for you.
>> Does there need to be something about code copied into the source tree?
>> Chris
> Do you mean 3rd party code / code that is not licensed with 2-BSD?
Take this file ...
https://git.rtems.org/rtems/tree/cpukit/dtc/README.license
Does the procedure need to manage the process a user follows to add a file like
this? The procedure in the link covers code written by the user which is great
but not code that is imported. Should it?
