AW: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
Jan.Sommer at dlr.de
Wed Feb 26 08:28:37 UTC 2020
Are there any further comments regarding these patches?
Is the solution with the "path-mappings" acceptable or do you prefer something different?
Beste regards,
Jan
> -----Ursprüngliche Nachricht-----
> Von: Sommer, Jan
> Gesendet: Dienstag, 18. Februar 2020 11:22
> An: devel at rtems.org
> Cc: Sommer, Jan
> Betreff: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
> Similar to the previous patchset for i386 this one enables compilation for the
> amd64 BSP with the following limitations:
> - dev_nic_e1000 needs to be off
> - debugger01.exe does not link because the amd64 bsp has no libdebugger
> support
> I tried to use the lessons learned from the last patch set.
> It does not seem to affect arm, sparc and i386 compilation.
> Made a mistake and started to send with v3, so I will increment from
> there to keep consecutive numbers.
> Version 4:
> - Added a path-mapping mechanism to waf_libbsd.py and libbsd.py
> - Removed the "if cpu == " switches from waf_libbsd.py
> Best regards,
> Jan
> Jan Sommer (3):
> amd64: Add missing files from FreeBSD
> amd64: Add to build
> amd64: Port to RTEMS
> freebsd/sys/amd64/amd64/in_cksum.c | 245 ++++
> freebsd/sys/amd64/include/machine/_bus.h | 48 +
> freebsd/sys/amd64/include/machine/cpufunc.h | 1053 +++++++++++++++++
> freebsd/sys/amd64/include/machine/efi.h | 78 ++
> freebsd/sys/amd64/include/machine/in_cksum.h | 86 ++
> freebsd/sys/amd64/include/machine/md_var.h | 90 ++
> .../sys/amd64/include/machine/specialreg.h | 6 +
> freebsd/sys/sys/efi.h | 198 ++++
> libbsd.py | 25 +
> rtemsbsd/amd64/include/machine/clock.h | 2 +
> waf_libbsd.py | 13 +-
> 11 files changed, 1842 insertions(+), 2 deletions(-)
> create mode 100644 freebsd/sys/amd64/amd64/in_cksum.c
> create mode 100644 freebsd/sys/amd64/include/machine/_bus.h
> create mode 100644 freebsd/sys/amd64/include/machine/cpufunc.h
> create mode 100644 freebsd/sys/amd64/include/machine/efi.h
> create mode 100644 freebsd/sys/amd64/include/machine/in_cksum.h
> create mode 100644 freebsd/sys/amd64/include/machine/md_var.h
> create mode 100644 freebsd/sys/amd64/include/machine/specialreg.h
> create mode 100644 freebsd/sys/sys/efi.h
> create mode 100644 rtemsbsd/amd64/include/machine/clock.h
> 2.17.1
