ticket #2970 Add ftw.h to newlib
Joel Sherrill
joel at rtems.org
Wed Feb 26 14:00:03 UTC 2020
On Wed, Feb 26, 2020 at 7:03 AM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> I wanted to know the status of implementation of ftw.h in newlib
> and the dependencies it requires?
FIrst hint is that the ticket is still open. :)
The next is a way to check if it is part of the installed C Library.
Wherever
you installed the tools (TOOLS_PREFIX) for CPU-rtems5
find TOOLS_PREFIX -name ftw.h
CPU-rtems5-nm TOOLS_PREFIX/CPU-rtems5/lib/libc.a | grep ftw
In this case, you will see it isn't there.
> As it could be ported from FreeBSD since it lies under favourable licence
Yep. And this would almost certainly need to be merged into the newlib C
library
with tests added to RTEMS.
Documentation added to the POSIX Users Guide and the tracking spreadsheet
updated.
Just to list all the subtasks. :)
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200226/8a5ac347/attachment-0001.html>
