ticket #2970 Add ftw.h to newlib
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Feb 26 15:06:31 UTC 2020
so the subtasks would consist of adding missing functions to stat.h ,
types.h mainly I suppose
- Eshan
On Wed, Feb 26, 2020 at 7:30 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Feb 26, 2020 at 7:03 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> I wanted to know the status of implementation of ftw.h in newlib
>> and the dependencies it requires?
> FIrst hint is that the ticket is still open. :)
> The next is a way to check if it is part of the installed C Library.
> Wherever
> you installed the tools (TOOLS_PREFIX) for CPU-rtems5
> find TOOLS_PREFIX -name ftw.h
> CPU-rtems5-nm TOOLS_PREFIX/CPU-rtems5/lib/libc.a | grep ftw
> In this case, you will see it isn't there.
>> As it could be ported from FreeBSD since it lies under favourable licence
> Yep. And this would almost certainly need to be merged into the newlib C
> library
> with tests added to RTEMS.
> Documentation added to the POSIX Users Guide and the tracking spreadsheet
> updated.
> Just to list all the subtasks. :)
> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200226/82fd3ed6/attachment.html>
