ticket #2970 Add ftw.h to newlib
Eshan Dhawan
eshandhawan51 at gmail.com
Thu Feb 27 11:49:46 UTC 2020
Also, Should look into ticket #3642 related to adding function prototypes
to wchar.h
On Thu, Feb 27, 2020 at 5:11 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> On Wed, Feb 26, 2020 at 8:50 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Wed, Feb 26, 2020 at 9:06 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>>> so the subtasks would consist of adding missing functions to stat.h ,
>>> types.h mainly I suppose
>> What do you think is missing in those? My reading of the POSIX standard
>> has is implying that
>> <ftw.h> includes <sys/stat.h> to get st_mode and the stat structure.
> Not much related to ftw.h but there are unsupported functions in
> sys/stat.h which can be added
> to Newlib
> Also wanted to know which headers which aren't present in newlib or RTEMS
> which could make my GSOC proposal more acceptable?
>> https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/ftw.h.html
>> The subtasks I referred to as the same for every time a new C Library or
>> POSIX method
>> is added to RTEMS or Newlib:
>> + the code itself
>> + test code
>> + addition to documentation as needed
>> + update to compliance tracking spreadsheet (usually I will do this)
>>> - Eshan
>>> On Wed, Feb 26, 2020 at 7:30 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> On Wed, Feb 26, 2020 at 7:03 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>> wrote:
>>>>> I wanted to know the status of implementation of ftw.h in newlib
>>>>> and the dependencies it requires?
>>>> FIrst hint is that the ticket is still open. :)
>>>> The next is a way to check if it is part of the installed C Library.
>>>> Wherever
>>>> you installed the tools (TOOLS_PREFIX) for CPU-rtems5
>>>> find TOOLS_PREFIX -name ftw.h
>>>> CPU-rtems5-nm TOOLS_PREFIX/CPU-rtems5/lib/libc.a | grep ftw
>>>> In this case, you will see it isn't there.
>>>>> As it could be ported from FreeBSD since it lies under favourable
>>>>> licence
>>>> Yep. And this would almost certainly need to be merged into the newlib
>>>> C library
>>>> with tests added to RTEMS.
>>>> Documentation added to the POSIX Users Guide and the tracking
>>>> spreadsheet
>>>> updated.
>>>> Just to list all the subtasks. :)
>>>> --joel
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200227/174cb1c0/attachment-0001.html>
