ticket #2970 Add ftw.h to newlib
Thu Feb 27 14:50:16 UTC 2020
On Thu, Feb 27, 2020 at 5:49 AM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> Also, Should look into ticket #3642 related to adding function prototypes
> to wchar.h
Make sure what's left to do is always the first step. :)
And make sure you are making progress on a proposal.
> On Thu, Feb 27, 2020 at 5:11 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Wed, Feb 26, 2020 at 8:50 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Wed, Feb 26, 2020 at 9:06 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> so the subtasks would consist of adding missing functions to stat.h ,
>>>> types.h mainly I suppose
>>> What do you think is missing in those? My reading of the POSIX standard
>>> has is implying that
>>> <ftw.h> includes <sys/stat.h> to get st_mode and the stat structure.
>> Not much related to ftw.h but there are unsupported functions in
>> sys/stat.h which can be added
>> to Newlib
What does your analysis show is missing? The POSIX Compliance document
should be right
but it is always good to know.
For analysis purposes, I would build arm with the xilinx zynq qemu BSP.
Then add on rtems-libbsd.
The methods can appear in newlib, RTEMS base, or rtems-libbsd. Most likely
if it isn't networking
related, it will be in the first two.
But my tracking spreadsheet indicates mknod() is there with networking
which I think sounds odd.
Anyway, the Compliance Guide is a good first cut but may have mistakes.
Start with good information.
>> Also wanted to know which headers which aren't present in newlib or RTEMS
>> which could make my GSOC proposal more acceptable?
>>> https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/ftw.h.html
>>> The subtasks I referred to as the same for every time a new C Library or
>>> POSIX method
>>> is added to RTEMS or Newlib:
>>> + the code itself
>>> + test code
>>> + addition to documentation as needed
>>> + update to compliance tracking spreadsheet (usually I will do this)
>>>> - Eshan
>>>> On Wed, Feb 26, 2020 at 7:30 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Wed, Feb 26, 2020 at 7:03 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>> wrote:
>>>>>> I wanted to know the status of implementation of ftw.h in newlib
>>>>>> and the dependencies it requires?
>>>>> FIrst hint is that the ticket is still open. :)
>>>>> The next is a way to check if it is part of the installed C Library.
>>>>> Wherever
>>>>> you installed the tools (TOOLS_PREFIX) for CPU-rtems5
>>>>> find TOOLS_PREFIX -name ftw.h
>>>>> CPU-rtems5-nm TOOLS_PREFIX/CPU-rtems5/lib/libc.a | grep ftw
>>>>> In this case, you will see it isn't there.
>>>>>> As it could be ported from FreeBSD since it lies under favourable
>>>>>> licence
>>>>> Yep. And this would almost certainly need to be merged into the newlib
>>>>> C library
>>>>> with tests added to RTEMS.
>>>>> Documentation added to the POSIX Users Guide and the tracking
>>>>> spreadsheet
>>>>> updated.
>>>>> Just to list all the subtasks. :)
>>>>> --joel
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200227/7a4972e0/attachment.html>
