Build Linux: PASSED 5/rtems-arm on x86_64-linux-gnu
Thu Feb 27 15:35:45 UTC 2020
On Wed, Feb 26, 2020 at 11:56 PM Sebastian Huber
> On 27/02/2020 07:38, Chris Johns wrote:
> > On 27/2/20 5:25 pm, Sebastian Huber wrote:
> >> On 26/02/2020 23:15, Chris Johns wrote:
> >>> On 27/2/20 12:26 am, Sebastian Huber wrote:
> >>>> On 26/02/2020 14:21,sebastian.huber at embedded-brains.de   wrote:
> >>>>> RTEMS Source Builder Repository Status
> >>>>>     Remotes:
> >>>>>       1: origin:ssh://sebh@dispatch.rtems.org/data/git/rtems-source-builder.git
> >>>>>       2:
> >>>>> main:git at main.eb.localhost:eb/101-embedded-brains/oss/rtems-source-builder.git
> >>>>>       3:esa:git at gitrepos.estec.esa.int:external/rtems-smp-qualification-rsb.git
> >>>> Why are the remote repositories reported?
> >>> It provides the git environment being used. The report needs a repo and I am not
> >>> sure you can tell which is the source of branch programmatically.
> >>>> I think we should remove this private and user-dependent information.
> >>> I have a specific repo I use for these types of publicly posted build ...
> >>>    Remotes:
> >>>      1: origin: git://git.rtems.org/rtems-source-builder.git
> >>>    Status:
> >>>     Clean
> >>>    Head:
> >>>     Commit: 14c5cb77132a3e66afab571afbf67dacad433ec3
> >> The Status and Head are very important information. Which remote repositories
> >> you use should be none of the business of the RTEMS Project. It can leak
> >> business relationships and project names. We should not do this without asking
> >> the user. I suggest to remove this part of the report.
> > I think the repo used is important information especially if someone is wanting
> > to replicate post results.
> To replicate results all you need is the commit hash and the original
> report must show a clean status. If the commit hash is not included in
> the RTEMS repositories you can ask the reporter.
> I think if a user requests to send a report and the status is not clean,
> then the RSB should stop with an error.
I agree with Sebastian. We should remove the "Remotes:" part.
> devel mailing list
> devel at rtems.org
