Build Linux: PASSED 5/rtems-arm on x86_64-linux-gnu
Sebastian Huber
Thu Feb 27 06:56:52 UTC 2020
On 27/02/2020 07:38, Chris Johns wrote:
> On 27/2/20 5:25 pm, Sebastian Huber wrote:
>> On 26/02/2020 23:15, Chris Johns wrote:
>>> On 27/2/20 12:26 am, Sebastian Huber wrote:
>>>> On 26/02/2020 14:21,sebastian.huber at embedded-brains.de wrote:
>>>>> RTEMS Source Builder Repository Status
>>>>> Remotes:
>>>>> 1: origin:ssh://sebh@dispatch.rtems.org/data/git/rtems-source-builder.git
>>>>> 2:
>>>>> main:git at main.eb.localhost:eb/101-embedded-brains/oss/rtems-source-builder.git
>>>>> 3:esa:git at gitrepos.estec.esa.int:external/rtems-smp-qualification-rsb.git
>>>> Why are the remote repositories reported?
>>> It provides the git environment being used. The report needs a repo and I am not
>>> sure you can tell which is the source of branch programmatically.
>>>> I think we should remove this private and user-dependent information.
>>> I have a specific repo I use for these types of publicly posted build ...
>>> Remotes:
>>> 1: origin: git://git.rtems.org/rtems-source-builder.git
>>> Status:
>>> Clean
>>> Head:
>>> Commit: 14c5cb77132a3e66afab571afbf67dacad433ec3
>> The Status and Head are very important information. Which remote repositories
>> you use should be none of the business of the RTEMS Project. It can leak
>> business relationships and project names. We should not do this without asking
>> the user. I suggest to remove this part of the report.
> I think the repo used is important information especially if someone is wanting
> to replicate post results.
To replicate results all you need is the commit hash and the original
report must show a clean status. If the commit hash is not included in
the RTEMS repositories you can ask the reporter.
I think if a user requests to send a report and the status is not clean,
then the RSB should stop with an error.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
