[PATCH] removed unneccesary assigning to rc triggering unused value error in coverity
Thu Feb 27 15:48:14 UTC 2020
Hi Suyash,
I have a  few comments for you.
First, the commit message should follow the guidance at
https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
and follow through the link about Commit Messages. We like to have a
short "tag" at the start of the commit to indicate the area of RTEMS
the commit applies to, in this case, maybe "bsps/shared: ignore return
value in display driver"  -- We don't currently have a set of standard
tags.
Second, avoid making unnecessary changes in whitespace elsewhere in
source code. My guess is that your text editor did this for you
automatically. You may want to investigate how to disable it from
rewriting the entire file for formatting on open.
Third, if a return value is unused, there are two options to consider:
(a) it should be used, or (b) it should be ignored. Either way, we
would prefer to be explicit about the programmer intent. In this case,
does it make sense to check the return status of
rtems_semaphore_release? Can it fail? Would it matter if it does?
To explicitly ignore a return value, you can do this instead:
rc = rtems_semaphore_release(...)
(void) rc;
As directed by our coding standards: "Use ‘(void) unused;’ to mark
unused parameters and set-but-unused variables immediately after being
set."
On Thu, Feb 27, 2020 at 3:24 AM suyash singh <suyashsingh234 at gmail.com> wrote:
>  bsps/shared/dev/display/disp_hcms29xx.c | 8 ++++----
>  1 file changed, 4 insertions(+), 4 deletions(-)
> diff --git a/bsps/shared/dev/display/disp_hcms29xx.c b/bsps/shared/dev/display/disp_hcms29xx.c
> index 5730b36ea9..9d3e7220cf 100644
> --- a/bsps/shared/dev/display/disp_hcms29xx.c
> +++ b/bsps/shared/dev/display/disp_hcms29xx.c
> @@ -530,7 +530,7 @@ static rtems_task disp_hcms29xx_update_task
>  | Input Parameters:                                                         |
> -   rtems_task_argument argument
> +   rtems_task_argument argument
>  | Return Value:                                                             |
> @@ -597,7 +597,7 @@ static rtems_task disp_hcms29xx_update_task
>           (int) strlen(softc_ptr->disp_param.disp_buffer);
>        if (rc == RTEMS_SUCCESSFUL) {
> -       rc = rtems_semaphore_release(softc_ptr->disp_param.trns_sema_id);
> +        rtems_semaphore_release(softc_ptr->disp_param.trns_sema_id);
>         * set initial offset to negative value
> @@ -911,7 +911,7 @@ static rtems_driver_address_table disp_hcms29xx_ops = {
>  static disp_hcms29xx_drv_t disp_hcms29xx_drv_tbl = {
>    {/* public fields */
> -    .ops =         &disp_hcms29xx_ops,
> +    .ops =         &disp_hcms29xx_ops,
>      .size =        sizeof (disp_hcms29xx_drv_t),
>    { /* our private fields */
> @@ -927,6 +927,6 @@ static disp_hcms29xx_drv_t disp_hcms29xx_drv_tbl = {
> -rtems_libi2c_drv_t *disp_hcms29xx_driver_descriptor =
> +rtems_libi2c_drv_t *disp_hcms29xx_driver_descriptor =
>    &disp_hcms29xx_drv_tbl.libi2c_drv_entry;
> 2.17.1
> devel mailing list
> devel at rtems.org
