[PATCH] removed unneccesary assigning to rc triggering unused value error in coverity
suyash singh suyashsingh234 at gmail.com
Thu Feb 27 16:24:04 UTC 2020
Okay sorry I missed out on the coding standards docs.
yes code blocks edited without telling I will change its settings
On Thu, Feb 27, 2020 at 9:18 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Suyash,
> I have a  few comments for you.
> First, the commit message should follow the guidance at
> https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
> and follow through the link about Commit Messages. We like to have a
> short "tag" at the start of the commit to indicate the area of RTEMS
> the commit applies to, in this case, maybe "bsps/shared: ignore return
> value in display driver"  -- We don't currently have a set of standard
> tags.
> Second, avoid making unnecessary changes in whitespace elsewhere in
> source code. My guess is that your text editor did this for you
> automatically. You may want to investigate how to disable it from
> rewriting the entire file for formatting on open.
> Third, if a return value is unused, there are two options to consider:
> (a) it should be used, or (b) it should be ignored. Either way, we
> would prefer to be explicit about the programmer intent. In this case,
> does it make sense to check the return status of
> rtems_semaphore_release? Can it fail? Would it matter if it does?
> To explicitly ignore a return value, you can do this instead:
> rc = rtems_semaphore_release(...)
> (void) rc;
> As directed by our coding standards: "Use ‘(void) unused;’ to mark
> unused parameters and set-but-unused variables immediately after being
> set."
> On Thu, Feb 27, 2020 at 3:24 AM suyash singh <suyashsingh234 at gmail.com>
> wrote:
> >  bsps/shared/dev/display/disp_hcms29xx.c | 8 ++++----
> >  1 file changed, 4 insertions(+), 4 deletions(-)
> > diff --git a/bsps/shared/dev/display/disp_hcms29xx.c
> b/bsps/shared/dev/display/disp_hcms29xx.c
> > index 5730b36ea9..9d3e7220cf 100644
> > --- a/bsps/shared/dev/display/disp_hcms29xx.c
> > +++ b/bsps/shared/dev/display/disp_hcms29xx.c
> > @@ -530,7 +530,7 @@ static rtems_task disp_hcms29xx_update_task
> >  | Input Parameters:
> > -   rtems_task_argument argument
> > +   rtems_task_argument argument
> >  | Return Value:
> > @@ -597,7 +597,7 @@ static rtems_task disp_hcms29xx_update_task
> >           (int) strlen(softc_ptr->disp_param.disp_buffer);
> >        if (rc == RTEMS_SUCCESSFUL) {
> > -       rc = rtems_semaphore_release(softc_ptr->disp_param.trns_sema_id);
> > +        rtems_semaphore_release(softc_ptr->disp_param.trns_sema_id);
> >         * set initial offset to negative value
> > @@ -911,7 +911,7 @@ static rtems_driver_address_table disp_hcms29xx_ops
> >  static disp_hcms29xx_drv_t disp_hcms29xx_drv_tbl = {
> >    {/* public fields */
> > -    .ops =         &disp_hcms29xx_ops,
> > +    .ops =         &disp_hcms29xx_ops,
> >      .size =        sizeof (disp_hcms29xx_drv_t),
> >    { /* our private fields */
> > @@ -927,6 +927,6 @@ static disp_hcms29xx_drv_t disp_hcms29xx_drv_tbl = {
> > -rtems_libi2c_drv_t *disp_hcms29xx_driver_descriptor =
> > +rtems_libi2c_drv_t *disp_hcms29xx_driver_descriptor =
> >    &disp_hcms29xx_drv_tbl.libi2c_drv_entry;
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200227/4ead8dc7/attachment.html>
