[PATCH 00/27] Update dtc to the latest upstream master
Fri Feb 28 06:51:17 UTC 2020
AKASHI Takahiro (1):
  libfdt: add fdt_append_addrrange()
David Gibson (6):
  libfdt: Don't use memcpy to handle unaligned reads on ARM
  Revert "libfdt: Add phandle generation helper"
  libfdt: Make fdt_get_max_phandle() an inline
  libfdt: Tweak data handling to satisfy Coverity
  libfdt: Allow #size-cells of 0
  libfdt: Correct prototype for fdt_ro_probe_()
Geert Uytterhoeven (2):
  libfdt: Fix fdt_getprop_by_offset() parameter name in documentation
  libfdt: Fix FDT_ERR_NOTFOUND typos in documentation
John Clarke (1):
  libfdt: return correct value if #size-cells property is not present
Luc Michel (1):
  libfdt.h: add explicit cast from void* to uint8_t* in fdt(32|64)_st
Nicholas Piggin (3):
  libfdt: Ensure fdt_add_property frees allocated name string on failure
  libfdt: Introduce fdt_create_with_flags()
  libfdt: Add FDT_CREATE_FLAG_NO_NAME_DEDUP flag that trades size for
    speed
Rob Herring (1):
  libfdt: Replace GPL/BSD boilerplate/reference with SPDX tags
Sebastian Huber (1):
  dtc: Update VERSION
Simon Glass (8):
  libfdt: De-inline fdt_header_size()
  Add a way to control the level of checks in the code
  libfdt: Add support for disabling dtb checks
  libfdt: Add support for disabling sanity checks
  libfdt: Add support for disabling rollback handling
  libfdt: Add support for disabling version checks
  libfdt: Add support for disabling ordering check/fixup
  libfdt: Allow exclusion of fdt_check_full()
Thierry Reding (3):
  libfdt: Add new maximum phandle lookup function
 cpukit/dtc/VERSION                  |   6 +-
 cpukit/dtc/libfdt/fdt.c             | 153 ++++++++++------------
 cpukit/dtc/libfdt/fdt_addresses.c   | 118 +++++++++--------
 cpukit/dtc/libfdt/fdt_empty_tree.c  |  47 +------
 cpukit/dtc/libfdt/fdt_ro.c          | 249 +++++++++++++-----------------------
 cpukit/dtc/libfdt/fdt_rw.c          |  92 ++++++-------
 cpukit/dtc/libfdt/fdt_strerror.c    |  47 +------
 cpukit/dtc/libfdt/fdt_sw.c          | 141 +++++++++++---------
 cpukit/dtc/libfdt/fdt_wip.c         |  47 +------
 cpukit/dtc/libfdt/libfdt_internal.h | 163 +++++++++++++++--------
 cpukit/include/fdt.h                |  47 +------
 cpukit/include/libfdt.h             | 236 +++++++++++++++++++++++++---------
 cpukit/include/libfdt_env.h         |  48 +------
 13 files changed, 639 insertions(+), 755 deletions(-)
2.16.4
