[PATCH 01/27] libfdt: return correct value if #size-cells property is not present
Fri Feb 28 06:51:18 UTC 2020
According to the device tree specification, the default value for
#size-cells is 1, but fdt_size_cells() was returning 2 if this property
was not present.
This patch also makes fdt_address_cells() and fdt_size_cells() conform
to the behaviour documented in libfdt.h. The defaults are only returned
if fdt_getprop() returns -FDT_ERR_NOTFOUND, otherwise the actual error
is returned.
Signed-off-by: John Clarke <johnc at kirriwa.net>
 cpukit/dtc/libfdt/fdt_addresses.c | 16 +++++++++++++---
 cpukit/include/libfdt.h           |  2 +-
 2 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_addresses.c b/cpukit/dtc/libfdt/fdt_addresses.c
index 49537b578d..f13a87dfa0 100644
--- a/cpukit/dtc/libfdt/fdt_addresses.c
+++ b/cpukit/dtc/libfdt/fdt_addresses.c
@@ -64,7 +64,7 @@ static int fdt_cells(const void *fdt, int nodeoffset, const char *name)
 	c = fdt_getprop(fdt, nodeoffset, name, &len);
 	if (!c)
-		return 2;
+		return len;
 	if (len != sizeof(*c))
 		return -FDT_ERR_BADNCELLS;
@@ -78,10 +78,20 @@ static int fdt_cells(const void *fdt, int nodeoffset, const char *name)
 int fdt_address_cells(const void *fdt, int nodeoffset)
-	return fdt_cells(fdt, nodeoffset, "#address-cells");
+	int val;
+	val = fdt_cells(fdt, nodeoffset, "#address-cells");
+	if (val == -FDT_ERR_NOTFOUND)
+		return 2;
+	return val;
 int fdt_size_cells(const void *fdt, int nodeoffset)
-	return fdt_cells(fdt, nodeoffset, "#size-cells");
+	int val;
+	val = fdt_cells(fdt, nodeoffset, "#size-cells");
+		return 1;
+	return val;
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 830b77e4be..face02c102 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -1145,7 +1145,7 @@ int fdt_address_cells(const void *fdt, int nodeoffset);
  * returns:
  *	0 <= n < FDT_MAX_NCELLS, on success
- *      2, if the node has no #size-cells property
+ *      1, if the node has no #size-cells property
  *      -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid
  *		#size-cells property
  *	-FDT_ERR_BADMAGIC,
2.16.4
