tar/psx/bsdtar on CentOS 8
Chris Johns
chrisj at rtems.org
Fri Feb 28 22:07:30 UTC 2020
>> On 29 Feb 2020, at 6:10 am, Jeff Mayes <Jeff.Mayes at oarcorp.com> wrote:
> Aha! So, spax provides pax now, and spax is in the BaseOS Repo. That’ll need to be updated in the documentation.
We need the PAX format from any source. I switched to the pax command because POSIX defines it and silly me thought a POSIX OS would always provide it.
If all the tar implementations support an option to generate the PAX format we can change back to tar.
We need to:
- check tar on each host
- check a test exe that is built
Would this be a simpler long term solution?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200229/863536e4/attachment.html>
