[PATCH] user: Add a link for the setup of frdme310arty BSP
Sebastian Huber
Thu Jan 2 06:20:45 UTC 2020
On 31/12/2019 10:55, Pragnesh Patel wrote:
>> -----Original Message-----
>> From: Pragnesh Patel<pragnesh.patel at sifive.com>
>> Sent: 29 November 2019 19:14
>> To:Sebastian.Huber at embedded-brains.de
>> Cc:devel at rtems.org; Pragnesh Patel<pragnesh.patel at sifive.com>
>> Subject: [PATCH] user: Add a link for the setup of frdme310arty BSP
>> Signed-off-by: Pragnesh Patel<pragnesh.patel at sifive.com>
>> user/bsps/bsps-riscv.rst | 3 +++
>> 1 file changed, 3 insertions(+)
>> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst index
>> 0799ad6..40d7606 100644
>> --- a/user/bsps/bsps-riscv.rst
>> +++ b/user/bsps/bsps-riscv.rst
>> @@ -93,6 +93,9 @@ The following options are available at the configure
>> command line.
>> Enables support sifive Freedom E310 Arty board if defined to a non-zero
>> value,otherwise it is disabled (disabled by default)
>> + Please seehttps://github.com/pragnesh26992/rtems and follow
>> + README-frdme310arty.md
> Any update on this patch ?
It would be nice if most of the content of
https://github.com/pragnesh26992/rtems/blob/master/README-frdme310arty.md
could move to the User Manual.
In general, this repository gives rise to an RTEMS Project question.
Should it provide BIT files, device tree files, debugger configuration
files, etc. to set up a target (evaluation board)? If yes, where? Maybe
rtems-docs?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
