[PATCH] user: Add a link for the setup of frdme310arty BSP
Gedare Bloom
gedare at rtems.org
Thu Jan 2 15:57:34 UTC 2020
On Wed, Jan 1, 2020 at 11:21 PM Sebastian Huber
> On 31/12/2019 10:55, Pragnesh Patel wrote:
> >> -----Original Message-----
> >> From: Pragnesh Patel<pragnesh.patel at sifive.com>
> >> Sent: 29 November 2019 19:14
> >> To:Sebastian.Huber at embedded-brains.de
> >> Cc:devel at rtems.org; Pragnesh Patel<pragnesh.patel at sifive.com>
> >> Subject: [PATCH] user: Add a link for the setup of frdme310arty BSP
> >> Signed-off-by: Pragnesh Patel<pragnesh.patel at sifive.com>
> >> user/bsps/bsps-riscv.rst | 3 +++
> >> 1 file changed, 3 insertions(+)
> >> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst index
> >> 0799ad6..40d7606 100644
> >> --- a/user/bsps/bsps-riscv.rst
> >> +++ b/user/bsps/bsps-riscv.rst
> >> @@ -93,6 +93,9 @@ The following options are available at the configure
> >> command line.
> >> Enables support sifive Freedom E310 Arty board if defined to a non-zero
> >> value,otherwise it is disabled (disabled by default)
> >> + Please seehttps://github.com/pragnesh26992/rtems and follow
> >> + README-frdme310arty.md
> > Any update on this patch ?
> It would be nice if most of the content of
> https://github.com/pragnesh26992/rtems/blob/master/README-frdme310arty.md
> could move to the User Manual.
> In general, this repository gives rise to an RTEMS Project question.
> Should it provide BIT files, device tree files, debugger configuration
> files, etc. to set up a target (evaluation board)? If yes, where? Maybe
> rtems-docs?
These things are certainly useful. Putting them in 'docs' is
misleading though. rtems-tools or a new high-level repo might be a
better fit. It should be discussed separately from the issue of this
patch.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
