[PATCH] bsp/raspberrypi: Updated the console API.
G S Niteesh
gsnb.gn at gmail.com
Fri Jan 3 08:26:21 UTC 2020
Replaces the legacy termios API with new termios API (#3034)
Replaces the custom PL011 serial driver with RTEMS arm-pl011.
Update #3034
bsps/arm/raspberrypi/console/console-config.c | 148 ++++++++++++----
bsps/arm/raspberrypi/console/console_select.c | 114 ------------
bsps/arm/raspberrypi/console/fbcons.c | 78 ++++----
bsps/arm/raspberrypi/console/usart.c | 167 ------------------
bsps/arm/raspberrypi/include/bsp.h | 2 +
bsps/arm/raspberrypi/include/bsp/fbcons.h | 17 +-
.../arm/raspberrypi/include/bsp/raspberrypi.h | 54 ++----
bsps/arm/raspberrypi/include/bsp/usart.h | 5 +-
bsps/arm/raspberrypi/start/bspstart.c | 15 ++
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 6 +-
10 files changed, 199 insertions(+), 407 deletions(-)
delete mode 100644 bsps/arm/raspberrypi/console/console_select.c
delete mode 100644 bsps/arm/raspberrypi/console/usart.c
diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
index d2186c918b..4000fd1c50 100644
--- a/bsps/arm/raspberrypi/console/console-config.c
+++ b/bsps/arm/raspberrypi/console/console-config.c
@@ -19,50 +19,132 @@
#include <rtems/bspIo.h>
-#include <libchip/serial.h>
+#include <rtems/console.h>
+#include <rtems/sysinit.h>
#include <bspopts.h>
-#include <bsp/irq.h>
-#include <bsp/usart.h>
+#include <bsp.h>
#include <bsp/raspberrypi.h>
+#include <bsp/usart.h>
+#include <bsp/arm-pl011.h>
#include <bsp/fbcons.h>
+#include <bsp/console-termios.h>
+#include <bsp/fdt.h>
+#include <bsp/fatal.h>
+#include <libfdt.h>
+#include <libchip/serial.h>
+#define UART0 "/dev/ttyS0"
+#define FBCONS "/dev/fbcons"
+arm_pl011_context pl011_context;
+rpi_fb_context fb_context;
+static void output_char_serial(char c)
+ arm_pl011_write_polled(&pl011_context.base, c);
+void output_char_fb(char c)
+ fbcons_write_polled(&fb_context.base, c);
-console_tbl Console_Configuration_Ports [] = {
- .sDeviceName = "/dev/ttyS0",
- .deviceType = SERIAL_CUSTOM,
- .pDeviceFns = &bcm2835_usart_fns,
- .deviceProbe = NULL,
- .pDeviceFlow = NULL,
- .ulCtrlPort1 = BCM2835_UART0_BASE,
- .ulCtrlPort2 = 0,
- .ulClock = USART0_DEFAULT_BAUD,
- .ulIntVector = BCM2835_IRQ_ID_UART
- .sDeviceName ="/dev/fbcons",
- .pDeviceFns = &fbcons_fns,
- .deviceProbe = fbcons_probe,
-#define PORT_COUNT \
- (sizeof(Console_Configuration_Ports) \
- / sizeof(Console_Configuration_Ports [0]))
-unsigned long Console_Configuration_Count = PORT_COUNT;
+static void init_ctx_arm_pl011(
+ const void *fdt,
+ int node
+ arm_pl011_context *ctx = &pl011_context;
+ rtems_termios_device_context_initialize(&ctx->base, "UART");
+ ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
+static void register_fb( void )
+ if (fbcons_probe(&fb_context.base) == true) {
+ rtems_termios_device_install(
+ FBCONS,
+ &fbcons_fns,
+ NULL,
+ &fb_context.base);
+static void console_select( void )
+ const char *opt;
+ opt = rpi_cmdline_get_arg("--console=");
+ if ( opt ) {
+ if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
+ if ( rpi_video_is_initialized() > 0 ) {
+ BSP_output_char = output_char_fb;
+ link(FBCONS, CONSOLE_DEVICE_NAME);
+ return ;
+ BSP_output_char = output_char_serial;
+ link(UART0, CONSOLE_DEVICE_NAME);
+static void uart_probe(void)
+ static bool initialized = false;
+ const void *fdt;
+ int node;
+ if ( initialized ) {
+ return ;
+ fdt = bsp_fdt_get();
+ node = fdt_node_offset_by_compatible(fdt, -1, "brcm,bcm2835-pl011");
+ init_ctx_arm_pl011(fdt, node);
+ initialized = true;
static void output_char(char c)
- const console_fns *con =
- Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
+ uart_probe();
+ output_char_serial(c);
+rtems_status_code console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ rtems_termios_initialize();
- con->deviceWritePolled((int) Console_Port_Minor, c);
+ uart_probe();
+ UART0,
+ &arm_pl011_fns,
+ NULL,
+ &pl011_context.base
+ register_fb();
+ console_select();
+ return RTEMS_SUCCESSFUL;
BSP_output_char_function_type BSP_output_char = output_char;
BSP_polling_getchar_function_type BSP_poll_char = NULL;
+RTEMS_SYSINIT_ITEM(
+ uart_probe,
+ RTEMS_SYSINIT_BSP_START,
+ RTEMS_SYSINIT_ORDER_LAST
\ No newline at end of file
diff --git a/bsps/arm/raspberrypi/console/console_select.c b/bsps/arm/raspberrypi/console/console_select.c
deleted file mode 100644
index bd246ca868..0000000000
--- a/bsps/arm/raspberrypi/console/console_select.c
+++ /dev/null
@@ -1,114 +0,0 @@
- * @file
- * @ingroup raspberrypi_console
- * @brief console select
- * Copyright (c) 2015 Yang Qiao
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE
-#include <bsp.h>
-#include <bsp/fatal.h>
-#include <rtems/libio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <assert.h>
-#include <termios.h>
-#include <rtems/termiostypes.h>
-#include "../../shared/dev/serial/legacy-console.h"
-#include <bsp/rpi-fb.h>
-rtems_device_minor_number BSPPrintkPort = 0;
- * Method to return true if the device associated with the
- * minor number probs available.
-static bool bsp_Is_Available( rtems_device_minor_number minor )
- console_tbl *cptr = Console_Port_Tbl[ minor ];
- * First perform the configuration dependent probe, then the
- * device dependent probe
- if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
- cptr->pDeviceFns->deviceProbe( minor ) ) {
- return true;
- return false;
- * Method to return the first available device.
-static rtems_device_minor_number bsp_First_Available_Device( void )
- rtems_device_minor_number minor;
- for ( minor = 0; minor < Console_Port_Count; minor++ ) {
- return minor;
- * Error No devices were found. We will want to bail here.
- bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
-void bsp_console_select( void )
- * Reset Console_Port_Minor and
- * BSPPrintkPort here if desired.
- * This default version allows the bsp to set these
- * values at creation and will not touch them again
- * unless the selected port number is not available.
- const char *opt;
- Console_Port_Minor = BSP_CONSOLE_UART0;
- BSPPrintkPort = BSP_CONSOLE_UART0;
- opt = rpi_cmdline_get_arg( "--console=" );
- if ( opt ) {
- if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
- if ( rpi_video_is_initialized() > 0 ) {
- Console_Port_Minor = BSP_CONSOLE_FB;
- BSPPrintkPort = BSP_CONSOLE_FB;
- * If the device that was selected isn't available then
- * let the user know and select the first available device.
- if ( !bsp_Is_Available( Console_Port_Minor ) ) {
- Console_Port_Minor = bsp_First_Available_Device();
diff --git a/bsps/arm/raspberrypi/console/fbcons.c b/bsps/arm/raspberrypi/console/fbcons.c
index 3669ba458d..0c0a5087ce 100644
--- a/bsps/arm/raspberrypi/console/fbcons.c
+++ b/bsps/arm/raspberrypi/console/fbcons.c
@@ -18,6 +18,7 @@
+#include <rtems/termiostypes.h>
@@ -29,15 +30,6 @@
#include <bsp/vc.h>
- * fbcons_init
- * This function initializes the fb console to a quiecsent state.
-static void fbcons_init( int minor )
* fbcons_open
@@ -45,13 +37,14 @@ static void fbcons_init( int minor )
* Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
-static int fbcons_open(
- int major,
- int minor,
- void *arg
+static bool fbcons_open(
+ struct rtems_termios_tty *tty,
+ rtems_termios_device_context *base,
+ struct termios *term,
+ rtems_libio_open_close_args_t *args
- return RTEMS_SUCCESSFUL;
+ return true;
@@ -59,13 +52,12 @@ static int fbcons_open(
* This function shuts down the requested port.
-static int fbcons_close(
- int major,
- int minor,
- void *arg
+static void fbcons_close(
- return ( RTEMS_SUCCESSFUL );
@@ -73,8 +65,8 @@ static int fbcons_close(
* This routine polls out the requested character.
-static void fbcons_write_polled(
- int minor,
+void fbcons_write_polled(
char c
@@ -90,8 +82,8 @@ static void fbcons_write_polled(
* Console Termios output entry point when using polled output.
-static ssize_t fbcons_write_support_polled(
- int minor,
+static void fbcons_write_support_polled(
const char *buf,
size_t len
@@ -102,14 +94,9 @@ static ssize_t fbcons_write_support_polled(
* poll each byte in the string out of the port.
while ( nwrite < len ) {
- fbcons_write_polled( minor, *buf++ );
+ fbcons_write_polled( base, *buf++ );
nwrite++;
- * return the number of bytes written.
- return nwrite;
@@ -117,7 +104,9 @@ static ssize_t fbcons_write_support_polled(
* Console Termios polling input entry point.
-static int fbcons_inbyte_nonblocking_polled( int minor )
+static int fbcons_inbyte_nonblocking_polled(
// if( rtems_kbpoll() ) {
// int c = getch();
@@ -133,15 +122,17 @@ static int fbcons_inbyte_nonblocking_polled( int minor )
* This function sets the UART channel to reflect the requested termios
* port settings.
-static int fbcons_set_attributes(
- int minor,
+static bool fbcons_set_attributes(
const struct termios *t
- return 0;
+ return true;
-bool fbcons_probe( int minor )
+bool fbcons_probe(
+ rtems_termios_device_context *context
// rtems_status_code status;
static bool firstTime = true;
@@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
return ret;
-const console_fns fbcons_fns =
+const rtems_termios_device_handler fbcons_fns =
- .deviceProbe = libchip_serial_default_probe, /* deviceProbe */
- .deviceFirstOpen = fbcons_open, /* deviceFirstOpen */
- .deviceLastClose = fbcons_close, /* deviceLastClose */
- .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
- .deviceWrite = fbcons_write_support_polled, /* deviceWrite */
- .deviceInitialize = fbcons_init, /* deviceInitialize */
- .deviceWritePolled = fbcons_write_polled, /* deviceWritePolled */
- .deviceSetAttributes = fbcons_set_attributes, /* deviceSetAttributes */
- .deviceOutputUsesInterrupts = FALSE, /* deviceOutputUsesInterrupts*/
+ .first_open = fbcons_open,
+ .last_close = fbcons_close,
+ .poll_read = fbcons_inbyte_nonblocking_polled,
+ .write = fbcons_write_support_polled,
+ .set_attributes = fbcons_set_attributes,
+ .mode = TERMIOS_POLLED
diff --git a/bsps/arm/raspberrypi/console/usart.c b/bsps/arm/raspberrypi/console/usart.c
index 25fb523621..0000000000
--- a/bsps/arm/raspberrypi/console/usart.c
+++ /dev/null
@@ -1,167 +0,0 @@
- * @file
- * @ingroup raspberrypi_usart
- * @brief USART support.
- * Copyright (c) 2013 Alan Cudmore
-#include <libchip/sersupp.h>
-#include <bsp.h>
-#include <bsp/raspberrypi.h>
-#include <rtems/bspIo.h>
-static void usart_delay(uint32_t n)
- volatile uint32_t i = 0;
- for(i = 0; i < n; i++)
-#if 0
- * These will be useful when the driver supports interrupt driven IO.
-static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
- return ct->ulIntVector;
-static uint32_t usart_get_baud(const console_tbl *ct)
- return ct->ulClock;
-#endif
-static void usart_set_baud(int minor, int baud)
- * Nothing for now
- return;
-static void usart_initialize(int minor)
- unsigned int gpio_reg;
- ** Program GPIO pins for UART 0
- gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
- gpio_reg &= ~(7<<12); /* gpio14 */
- gpio_reg |= (4<<12); /* alt0 */
- gpio_reg &= ~(7<<15); /* gpio15 */
- gpio_reg |= (4<<15); /* alt0 */
- BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
- BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
- usart_delay(150);
- BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
- usart_delay(150);
- BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
- ** Init the PL011 UART
- BCM2835_REG(BCM2835_UART0_CR) = 0;
- BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
- BCM2835_REG(BCM2835_UART0_IMSC) = 0;
- BCM2835_REG(BCM2835_UART0_IBRD) = 1;
- BCM2835_REG(BCM2835_UART0_FBRD) = 40;
- BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
- BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
- BCM2835_REG(BCM2835_UART0_CR) = 0x301;
- BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
- usart_set_baud(minor, 115000);
-static int usart_first_open(int major, int minor, void *arg)
- rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *) arg;
- struct rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
- const console_tbl *ct = Console_Port_Tbl [minor];
- console_data *cd = &Console_Port_Data [minor];
- cd->termios_data = tty;
- rtems_termios_set_initial_baud(tty, ct->ulClock);
- return 0;
-static int usart_last_close(int major, int minor, void *arg)
- return 0;
-static int usart_read_polled(int minor)
- if (minor == 0) {
- if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
- return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
- } else {
- return -1;
- } else {
- printk("Unknown console minor number: %d\n", minor);
- return -1;
-static void usart_write_polled(int minor, char c)
- while (1) {
- if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
- break;
- BCM2835_REG(BCM2835_UART0_DR) = c;
-static ssize_t usart_write_support_polled(
- int minor,
- const char *s,
- size_t n
- ssize_t i = 0;
- for (i = 0; i < n; ++i) {
- usart_write_polled(minor, s [i]);
- return n;
-static int usart_set_attributes(int minor, const struct termios *term)
- return -1;
-const console_fns bcm2835_usart_fns = {
- .deviceFirstOpen = usart_first_open,
- .deviceLastClose = usart_last_close,
- .deviceRead = usart_read_polled,
- .deviceWrite = usart_write_support_polled,
- .deviceInitialize = usart_initialize,
- .deviceWritePolled = usart_write_polled,
- .deviceSetAttributes = usart_set_attributes,
- .deviceOutputUsesInterrupts = false
diff --git a/bsps/arm/raspberrypi/include/bsp.h b/bsps/arm/raspberrypi/include/bsp.h
index b81d19cd76..190dd16184 100644
--- a/bsps/arm/raspberrypi/include/bsp.h
+++ b/bsps/arm/raspberrypi/include/bsp.h
@@ -54,6 +54,8 @@ extern "C" {
#define BSP_CONSOLE_UART0 0
#define BSP_CONSOLE_FB 1
+void *raspberrypi_get_reg_of_node(const void *fdt, int node);
void rpi_init_cmdline(void);
const char *rpi_cmdline_get_cached(void);
const char *rpi_cmdline_get_raw(void);
diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h b/bsps/arm/raspberrypi/include/bsp/fbcons.h
index d0e126699a..9de75ee5a4 100644
--- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
+++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
@@ -33,12 +33,25 @@ extern "C" {
#define FB_CONSOLE 0x50492835
-bool fbcons_probe( int minor );
+bool fbcons_probe(
+ char c
+void output_char_fb(char c);
+typedef struct {
+ rtems_termios_device_context base;
+} rpi_fb_context ;
* Driver function table
-extern const console_fns fbcons_fns;
+extern const rtems_termios_device_handler fbcons_fns;
#ifdef __cplusplus
diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
index 40c80cf408..eeb48c42f1 100644
--- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
+++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
@@ -53,12 +53,24 @@
#if (BSP_IS_RPI2 == 1)
- #define RPI_PERIPHERAL_BASE 0x3F000000
+ #define RPI_PERIPHERAL_BASE 0x3F000000
+ #define BASE_OFFSET 0X3F000000
#else
- #define RPI_PERIPHERAL_BASE 0x20000000
+ #define RPI_PERIPHERAL_BASE 0x20000000
+ #define BASE_OFFSET 0X5E000000
#endif
-#define RPI_PERIPHERAL_SIZE 0x01000000
+#define RPI_PERIPHERAL_SIZE 0x01000000
+ * @name Bus to Physical address translation
+ * Macro.
+#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
* @name Internal ARM Timer Registers
@@ -184,42 +196,6 @@
- * @name UART 0 (PL011) Registers
-#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE + 0x201000)
-#define BCM2835_UART0_DR (BCM2835_UART0_BASE + 0x00)
-#define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE + 0x04)
-#define BCM2835_UART0_FR (BCM2835_UART0_BASE + 0x18)
-#define BCM2835_UART0_ILPR (BCM2835_UART0_BASE + 0x20)
-#define BCM2835_UART0_IBRD (BCM2835_UART0_BASE + 0x24)
-#define BCM2835_UART0_FBRD (BCM2835_UART0_BASE + 0x28)
-#define BCM2835_UART0_LCRH (BCM2835_UART0_BASE + 0x2C)
-#define BCM2835_UART0_CR (BCM2835_UART0_BASE + 0x30)
-#define BCM2835_UART0_IFLS (BCM2835_UART0_BASE + 0x34)
-#define BCM2835_UART0_IMSC (BCM2835_UART0_BASE + 0x38)
-#define BCM2835_UART0_RIS (BCM2835_UART0_BASE + 0x3C)
-#define BCM2835_UART0_MIS (BCM2835_UART0_BASE + 0x40)
-#define BCM2835_UART0_ICR (BCM2835_UART0_BASE + 0x44)
-#define BCM2835_UART0_DMACR (BCM2835_UART0_BASE + 0x48)
-#define BCM2835_UART0_ITCR (BCM2835_UART0_BASE + 0x80)
-#define BCM2835_UART0_ITIP (BCM2835_UART0_BASE + 0x84)
-#define BCM2835_UART0_ITOP (BCM2835_UART0_BASE + 0x88)
-#define BCM2835_UART0_TDR (BCM2835_UART0_BASE + 0x8C)
-#define BCM2835_UART0_MIS_RX 0x10
-#define BCM2835_UART0_MIS_TX 0x20
-#define BCM2835_UART0_IMSC_RX 0x10
-#define BCM2835_UART0_IMSC_TX 0x20
-#define BCM2835_UART0_FR_RXFE 0x10
-#define BCM2835_UART0_FR_TXFF 0x20
-#define BCM2835_UART0_ICR_RX 0x10
-#define BCM2835_UART0_ICR_TX 0x20
diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h b/bsps/arm/raspberrypi/include/bsp/usart.h
index d3e710c5e9..abbf53626c 100644
--- a/bsps/arm/raspberrypi/include/bsp/usart.h
+++ b/bsps/arm/raspberrypi/include/bsp/usart.h
@@ -32,9 +32,8 @@
extern "C" {
#endif /* __cplusplus */
-#define USART0_DEFAULT_BAUD 115000
-extern const console_fns bcm2835_usart_fns;
+#define PL011_DEFAULT_BAUD 115000
+#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
#ifdef __cplusplus
diff --git a/bsps/arm/raspberrypi/start/bspstart.c b/bsps/arm/raspberrypi/start/bspstart.c
index 6ff286f840..49896e4d47 100644
--- a/bsps/arm/raspberrypi/start/bspstart.c
+++ b/bsps/arm/raspberrypi/start/bspstart.c
@@ -24,6 +24,8 @@
#include <bsp/vc.h>
static const struct {
uint32_t code;
const char* label;
@@ -86,6 +88,19 @@ static const char* rpi_mem[] =
#define NUMOF(_s) (sizeof(_s) / sizeof(_s[0]))
+ int len;
+ const uint32_t *val;
+ val = fdt_getprop(fdt, node, "reg", &len);
+ if (val == NULL || len < 4) {
+ return NULL;
+ return (BUS_TO_PHY((void *) fdt32_to_cpu(val[0])));
void bsp_start(void)
bcm2835_get_board_spec_entries spec = { 0 };
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 77aa360977..57562c10c7 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -64,11 +64,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/irq/irq.c
# Console
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/arm-pl011.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console-config.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console_select.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/usart.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fb.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/outch.c
2.17.1
