[PATCH] bsp/raspberrypi: Updated the console API.
Christian Mauderer
list at c-mauderer.de
Fri Jan 3 10:09:33 UTC 2020
Hello Niteesh,
looks good to me. The UART works for a Pi1 and a Pi2. The Framebuffer
console doesn't but it doesn't work either before this patch and as far
as I can tell you took over the logic correctly. So I don't think this
patch will break anything that isn't already broken.
I'll give the patch some more days for others to review and if no one
objects, I'll push it together with the "Enable FDT support" and my two
patches that fix the SDRAM stuff.
Best regards
Christian
On 03/01/2020 09:26, G S Niteesh wrote:
> Replaces the legacy termios API with new termios API (#3034)
> Replaces the custom PL011 serial driver with RTEMS arm-pl011.
> Update #3034
> bsps/arm/raspberrypi/console/console-config.c | 148 ++++++++++++----
> bsps/arm/raspberrypi/console/console_select.c | 114 ------------
> bsps/arm/raspberrypi/console/fbcons.c | 78 ++++----
> bsps/arm/raspberrypi/console/usart.c | 167 ------------------
> bsps/arm/raspberrypi/include/bsp.h | 2 +
> bsps/arm/raspberrypi/include/bsp/fbcons.h | 17 +-
> .../arm/raspberrypi/include/bsp/raspberrypi.h | 54 ++----
> bsps/arm/raspberrypi/include/bsp/usart.h | 5 +-
> bsps/arm/raspberrypi/start/bspstart.c | 15 ++
> c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 6 +-
> 10 files changed, 199 insertions(+), 407 deletions(-)
> delete mode 100644 bsps/arm/raspberrypi/console/console_select.c
> delete mode 100644 bsps/arm/raspberrypi/console/usart.c
> diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
> index d2186c918b..4000fd1c50 100644
> --- a/bsps/arm/raspberrypi/console/console-config.c
> +++ b/bsps/arm/raspberrypi/console/console-config.c
> @@ -19,50 +19,132 @@
> #include <rtems/bspIo.h>
> -#include <libchip/serial.h>
> +#include <rtems/console.h>
> +#include <rtems/sysinit.h>
> #include <bspopts.h>
> -#include <bsp/irq.h>
> -#include <bsp/usart.h>
> +#include <bsp.h>
> #include <bsp/raspberrypi.h>
> +#include <bsp/usart.h>
> +#include <bsp/arm-pl011.h>
> #include <bsp/fbcons.h>
> +#include <bsp/console-termios.h>
> +#include <bsp/fdt.h>
> +#include <bsp/fatal.h>
> +#include <libfdt.h>
> +#include <libchip/serial.h>
> +#define UART0 "/dev/ttyS0"
> +#define FBCONS "/dev/fbcons"
> +arm_pl011_context pl011_context;
> +rpi_fb_context fb_context;
> +static void output_char_serial(char c)
> + arm_pl011_write_polled(&pl011_context.base, c);
> +void output_char_fb(char c)
> + fbcons_write_polled(&fb_context.base, c);
> -console_tbl Console_Configuration_Ports [] = {
> - .sDeviceName = "/dev/ttyS0",
> - .deviceType = SERIAL_CUSTOM,
> - .pDeviceFns = &bcm2835_usart_fns,
> - .deviceProbe = NULL,
> - .pDeviceFlow = NULL,
> - .ulCtrlPort1 = BCM2835_UART0_BASE,
> - .ulCtrlPort2 = 0,
> - .ulClock = USART0_DEFAULT_BAUD,
> - .ulIntVector = BCM2835_IRQ_ID_UART
> - .sDeviceName ="/dev/fbcons",
> - .pDeviceFns = &fbcons_fns,
> - .deviceProbe = fbcons_probe,
> -#define PORT_COUNT \
> - (sizeof(Console_Configuration_Ports) \
> - / sizeof(Console_Configuration_Ports [0]))
> -unsigned long Console_Configuration_Count = PORT_COUNT;
> +static void init_ctx_arm_pl011(
> + const void *fdt,
> + int node
> + arm_pl011_context *ctx = &pl011_context;
> + rtems_termios_device_context_initialize(&ctx->base, "UART");
> + ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
> +static void register_fb( void )
> + if (fbcons_probe(&fb_context.base) == true) {
> + rtems_termios_device_install(
> + FBCONS,
> + &fbcons_fns,
> + NULL,
> + &fb_context.base);
> +static void console_select( void )
> + const char *opt;
> + opt = rpi_cmdline_get_arg("--console=");
> + if ( opt ) {
> + if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
> + if ( rpi_video_is_initialized() > 0 ) {
> + BSP_output_char = output_char_fb;
> + link(FBCONS, CONSOLE_DEVICE_NAME);
> + return ;
> + BSP_output_char = output_char_serial;
> + link(UART0, CONSOLE_DEVICE_NAME);
> +static void uart_probe(void)
> + static bool initialized = false;
> + const void *fdt;
> + int node;
> + if ( initialized ) {
> + return ;
> + fdt = bsp_fdt_get();
> + node = fdt_node_offset_by_compatible(fdt, -1, "brcm,bcm2835-pl011");
> + init_ctx_arm_pl011(fdt, node);
> + initialized = true;
> static void output_char(char c)
> - const console_fns *con =
> - Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
> + uart_probe();
> + output_char_serial(c);
> +rtems_status_code console_initialize(
> + rtems_device_major_number major,
> + rtems_device_minor_number minor,
> + void *arg
> + rtems_termios_initialize();
> - con->deviceWritePolled((int) Console_Port_Minor, c);
> + uart_probe();
> + UART0,
> + &arm_pl011_fns,
> + NULL,
> + &pl011_context.base
> + register_fb();
> + console_select();
> + return RTEMS_SUCCESSFUL;
> BSP_output_char_function_type BSP_output_char = output_char;
> BSP_polling_getchar_function_type BSP_poll_char = NULL;
> +RTEMS_SYSINIT_ITEM(
> + uart_probe,
> + RTEMS_SYSINIT_BSP_START,
> + RTEMS_SYSINIT_ORDER_LAST
> \ No newline at end of file
> diff --git a/bsps/arm/raspberrypi/console/console_select.c b/bsps/arm/raspberrypi/console/console_select.c
> deleted file mode 100644
> index bd246ca868..0000000000
> --- a/bsps/arm/raspberrypi/console/console_select.c
> +++ /dev/null
> @@ -1,114 +0,0 @@
> - * @file
> - * @ingroup raspberrypi_console
> - * @brief console select
> - * Copyright (c) 2015 Yang Qiao
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE
> -#include <bsp.h>
> -#include <bsp/fatal.h>
> -#include <rtems/libio.h>
> -#include <stdlib.h>
> -#include <string.h>
> -#include <assert.h>
> -#include <termios.h>
> -#include <rtems/termiostypes.h>
> -#include "../../shared/dev/serial/legacy-console.h"
> -#include <bsp/rpi-fb.h>
> -rtems_device_minor_number BSPPrintkPort = 0;
> - * Method to return true if the device associated with the
> - * minor number probs available.
> -static bool bsp_Is_Available( rtems_device_minor_number minor )
> - console_tbl *cptr = Console_Port_Tbl[ minor ];
> - * First perform the configuration dependent probe, then the
> - * device dependent probe
> - if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
> - cptr->pDeviceFns->deviceProbe( minor ) ) {
> - return true;
> - return false;
> - * Method to return the first available device.
> -static rtems_device_minor_number bsp_First_Available_Device( void )
> - rtems_device_minor_number minor;
> - for ( minor = 0; minor < Console_Port_Count; minor++ ) {
> - return minor;
> - * Error No devices were found. We will want to bail here.
> - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> -void bsp_console_select( void )
> - * Reset Console_Port_Minor and
> - * BSPPrintkPort here if desired.
> - * This default version allows the bsp to set these
> - * values at creation and will not touch them again
> - * unless the selected port number is not available.
> - const char *opt;
> - Console_Port_Minor = BSP_CONSOLE_UART0;
> - BSPPrintkPort = BSP_CONSOLE_UART0;
> - opt = rpi_cmdline_get_arg( "--console=" );
> - if ( opt ) {
> - if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
> - if ( rpi_video_is_initialized() > 0 ) {
> - Console_Port_Minor = BSP_CONSOLE_FB;
> - BSPPrintkPort = BSP_CONSOLE_FB;
> - * If the device that was selected isn't available then
> - * let the user know and select the first available device.
> - if ( !bsp_Is_Available( Console_Port_Minor ) ) {
> - Console_Port_Minor = bsp_First_Available_Device();
> diff --git a/bsps/arm/raspberrypi/console/fbcons.c b/bsps/arm/raspberrypi/console/fbcons.c
> index 3669ba458d..0c0a5087ce 100644
> --- a/bsps/arm/raspberrypi/console/fbcons.c
> +++ b/bsps/arm/raspberrypi/console/fbcons.c
> @@ -18,6 +18,7 @@
> #include <rtems.h>
> +#include <rtems/termiostypes.h>
> #include <stdlib.h>
> @@ -29,15 +30,6 @@
> #include <bsp/vc.h>
> - * fbcons_init
> - * This function initializes the fb console to a quiecsent state.
> -static void fbcons_init( int minor )
> * fbcons_open
> @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
> * Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
> -static int fbcons_open(
> - int major,
> - int minor,
> - void *arg
> +static bool fbcons_open(
> + struct rtems_termios_tty *tty,
> + rtems_termios_device_context *base,
> + struct termios *term,
> + rtems_libio_open_close_args_t *args
> - return RTEMS_SUCCESSFUL;
> + return true;
> @@ -59,13 +52,12 @@ static int fbcons_open(
> * This function shuts down the requested port.
> -static int fbcons_close(
> - int major,
> - int minor,
> - void *arg
> +static void fbcons_close(
> - return ( RTEMS_SUCCESSFUL );
> @@ -73,8 +65,8 @@ static int fbcons_close(
> * This routine polls out the requested character.
> -static void fbcons_write_polled(
> - int minor,
> +void fbcons_write_polled(
> char c
> @@ -90,8 +82,8 @@ static void fbcons_write_polled(
> * Console Termios output entry point when using polled output.
> -static ssize_t fbcons_write_support_polled(
> - int minor,
> +static void fbcons_write_support_polled(
> const char *buf,
> size_t len
> @@ -102,14 +94,9 @@ static ssize_t fbcons_write_support_polled(
> * poll each byte in the string out of the port.
> while ( nwrite < len ) {
> - fbcons_write_polled( minor, *buf++ );
> + fbcons_write_polled( base, *buf++ );
> nwrite++;
> - * return the number of bytes written.
> - return nwrite;
> @@ -117,7 +104,9 @@ static ssize_t fbcons_write_support_polled(
> * Console Termios polling input entry point.
> -static int fbcons_inbyte_nonblocking_polled( int minor )
> +static int fbcons_inbyte_nonblocking_polled(
> // if( rtems_kbpoll() ) {
> // int c = getch();
> @@ -133,15 +122,17 @@ static int fbcons_inbyte_nonblocking_polled( int minor )
> * This function sets the UART channel to reflect the requested termios
> * port settings.
> -static int fbcons_set_attributes(
> - int minor,
> +static bool fbcons_set_attributes(
> const struct termios *t
> - return 0;
> + return true;
> -bool fbcons_probe( int minor )
> +bool fbcons_probe(
> + rtems_termios_device_context *context
> // rtems_status_code status;
> static bool firstTime = true;
> @@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
> return ret;
> -const console_fns fbcons_fns =
> +const rtems_termios_device_handler fbcons_fns =
> - .deviceProbe = libchip_serial_default_probe, /* deviceProbe */
> - .deviceFirstOpen = fbcons_open, /* deviceFirstOpen */
> - .deviceLastClose = fbcons_close, /* deviceLastClose */
> - .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
> - .deviceWrite = fbcons_write_support_polled, /* deviceWrite */
> - .deviceInitialize = fbcons_init, /* deviceInitialize */
> - .deviceWritePolled = fbcons_write_polled, /* deviceWritePolled */
> - .deviceSetAttributes = fbcons_set_attributes, /* deviceSetAttributes */
> - .deviceOutputUsesInterrupts = FALSE, /* deviceOutputUsesInterrupts*/
> + .first_open = fbcons_open,
> + .last_close = fbcons_close,
> + .poll_read = fbcons_inbyte_nonblocking_polled,
> + .write = fbcons_write_support_polled,
> + .set_attributes = fbcons_set_attributes,
> + .mode = TERMIOS_POLLED
> diff --git a/bsps/arm/raspberrypi/console/usart.c b/bsps/arm/raspberrypi/console/usart.c
> index 25fb523621..0000000000
> --- a/bsps/arm/raspberrypi/console/usart.c
> +++ /dev/null
> @@ -1,167 +0,0 @@
> - * @file
> - * @ingroup raspberrypi_usart
> - * @brief USART support.
> - * Copyright (c) 2013 Alan Cudmore
> -#include <libchip/sersupp.h>
> -#include <bsp.h>
> -#include <bsp/raspberrypi.h>
> -#include <rtems/bspIo.h>
> -static void usart_delay(uint32_t n)
> - volatile uint32_t i = 0;
> - for(i = 0; i < n; i++)
> -#if 0
> - * These will be useful when the driver supports interrupt driven IO.
> -static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
> - return ct->ulIntVector;
> -static uint32_t usart_get_baud(const console_tbl *ct)
> - return ct->ulClock;
> -#endif
> -static void usart_set_baud(int minor, int baud)
> - * Nothing for now
> - return;
> -static void usart_initialize(int minor)
> - unsigned int gpio_reg;
> - ** Program GPIO pins for UART 0
> - gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> - gpio_reg &= ~(7<<12); /* gpio14 */
> - gpio_reg |= (4<<12); /* alt0 */
> - gpio_reg &= ~(7<<15); /* gpio15 */
> - gpio_reg |= (4<<15); /* alt0 */
> - BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> - usart_delay(150);
> - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
> - usart_delay(150);
> - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> - ** Init the PL011 UART
> - BCM2835_REG(BCM2835_UART0_CR) = 0;
> - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
> - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
> - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
> - BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> - usart_set_baud(minor, 115000);
> -static int usart_first_open(int major, int minor, void *arg)
> - rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *) arg;
> - struct rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
> - const console_tbl *ct = Console_Port_Tbl [minor];
> - console_data *cd = &Console_Port_Data [minor];
> - cd->termios_data = tty;
> - rtems_termios_set_initial_baud(tty, ct->ulClock);
> - return 0;
> -static int usart_last_close(int major, int minor, void *arg)
> - return 0;
> -static int usart_read_polled(int minor)
> - if (minor == 0) {
> - if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
> - return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> - } else {
> - return -1;
> - } else {
> - printk("Unknown console minor number: %d\n", minor);
> - return -1;
> -static void usart_write_polled(int minor, char c)
> - while (1) {
> - if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
> - break;
> - BCM2835_REG(BCM2835_UART0_DR) = c;
> -static ssize_t usart_write_support_polled(
> - int minor,
> - const char *s,
> - size_t n
> - ssize_t i = 0;
> - for (i = 0; i < n; ++i) {
> - usart_write_polled(minor, s [i]);
> - return n;
> -static int usart_set_attributes(int minor, const struct termios *term)
> - return -1;
> -const console_fns bcm2835_usart_fns = {
> - .deviceFirstOpen = usart_first_open,
> - .deviceLastClose = usart_last_close,
> - .deviceRead = usart_read_polled,
> - .deviceWrite = usart_write_support_polled,
> - .deviceInitialize = usart_initialize,
> - .deviceWritePolled = usart_write_polled,
> - .deviceSetAttributes = usart_set_attributes,
> - .deviceOutputUsesInterrupts = false
> diff --git a/bsps/arm/raspberrypi/include/bsp.h b/bsps/arm/raspberrypi/include/bsp.h
> index b81d19cd76..190dd16184 100644
> --- a/bsps/arm/raspberrypi/include/bsp.h
> +++ b/bsps/arm/raspberrypi/include/bsp.h
> @@ -54,6 +54,8 @@ extern "C" {
> #define BSP_CONSOLE_UART0 0
> #define BSP_CONSOLE_FB 1
> +void *raspberrypi_get_reg_of_node(const void *fdt, int node);
> void rpi_init_cmdline(void);
> const char *rpi_cmdline_get_cached(void);
> const char *rpi_cmdline_get_raw(void);
> diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> index d0e126699a..9de75ee5a4 100644
> --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> @@ -33,12 +33,25 @@ extern "C" {
> #define FB_CONSOLE 0x50492835
> -bool fbcons_probe( int minor );
> +bool fbcons_probe(
> + char c
> +void output_char_fb(char c);
> +typedef struct {
> + rtems_termios_device_context base;
> +} rpi_fb_context ;
> * Driver function table
> -extern const console_fns fbcons_fns;
> +extern const rtems_termios_device_handler fbcons_fns;
> #ifdef __cplusplus
> diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> index 40c80cf408..eeb48c42f1 100644
> --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> @@ -53,12 +53,24 @@
> #if (BSP_IS_RPI2 == 1)
> - #define RPI_PERIPHERAL_BASE 0x3F000000
> + #define RPI_PERIPHERAL_BASE 0x3F000000
> + #define BASE_OFFSET 0X3F000000
> #else
> - #define RPI_PERIPHERAL_BASE 0x20000000
> + #define RPI_PERIPHERAL_BASE 0x20000000
> + #define BASE_OFFSET 0X5E000000
> #endif
> -#define RPI_PERIPHERAL_SIZE 0x01000000
> +#define RPI_PERIPHERAL_SIZE 0x01000000
> + * @name Bus to Physical address translation
> + * Macro.
> +#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
> * @name Internal ARM Timer Registers
> @@ -184,42 +196,6 @@
> - * @name UART 0 (PL011) Registers
> -#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE + 0x201000)
> -#define BCM2835_UART0_DR (BCM2835_UART0_BASE + 0x00)
> -#define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE + 0x04)
> -#define BCM2835_UART0_FR (BCM2835_UART0_BASE + 0x18)
> -#define BCM2835_UART0_ILPR (BCM2835_UART0_BASE + 0x20)
> -#define BCM2835_UART0_IBRD (BCM2835_UART0_BASE + 0x24)
> -#define BCM2835_UART0_FBRD (BCM2835_UART0_BASE + 0x28)
> -#define BCM2835_UART0_LCRH (BCM2835_UART0_BASE + 0x2C)
> -#define BCM2835_UART0_CR (BCM2835_UART0_BASE + 0x30)
> -#define BCM2835_UART0_IFLS (BCM2835_UART0_BASE + 0x34)
> -#define BCM2835_UART0_IMSC (BCM2835_UART0_BASE + 0x38)
> -#define BCM2835_UART0_RIS (BCM2835_UART0_BASE + 0x3C)
> -#define BCM2835_UART0_MIS (BCM2835_UART0_BASE + 0x40)
> -#define BCM2835_UART0_ICR (BCM2835_UART0_BASE + 0x44)
> -#define BCM2835_UART0_DMACR (BCM2835_UART0_BASE + 0x48)
> -#define BCM2835_UART0_ITCR (BCM2835_UART0_BASE + 0x80)
> -#define BCM2835_UART0_ITIP (BCM2835_UART0_BASE + 0x84)
> -#define BCM2835_UART0_ITOP (BCM2835_UART0_BASE + 0x88)
> -#define BCM2835_UART0_TDR (BCM2835_UART0_BASE + 0x8C)
> -#define BCM2835_UART0_MIS_RX 0x10
> -#define BCM2835_UART0_MIS_TX 0x20
> -#define BCM2835_UART0_IMSC_RX 0x10
> -#define BCM2835_UART0_IMSC_TX 0x20
> -#define BCM2835_UART0_FR_RXFE 0x10
> -#define BCM2835_UART0_FR_TXFF 0x20
> -#define BCM2835_UART0_ICR_RX 0x10
> -#define BCM2835_UART0_ICR_TX 0x20
> diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h b/bsps/arm/raspberrypi/include/bsp/usart.h
> index d3e710c5e9..abbf53626c 100644
> --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> @@ -32,9 +32,8 @@
> extern "C" {
> #endif /* __cplusplus */
> -#define USART0_DEFAULT_BAUD 115000
> -extern const console_fns bcm2835_usart_fns;
> +#define PL011_DEFAULT_BAUD 115000
> +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
> #ifdef __cplusplus
> diff --git a/bsps/arm/raspberrypi/start/bspstart.c b/bsps/arm/raspberrypi/start/bspstart.c
> index 6ff286f840..49896e4d47 100644
> --- a/bsps/arm/raspberrypi/start/bspstart.c
> +++ b/bsps/arm/raspberrypi/start/bspstart.c
> @@ -24,6 +24,8 @@
> #include <bsp/vc.h>
> static const struct {
> uint32_t code;
> const char* label;
> @@ -86,6 +88,19 @@ static const char* rpi_mem[] =
> #define NUMOF(_s) (sizeof(_s) / sizeof(_s[0]))
> + int len;
> + const uint32_t *val;
> + val = fdt_getprop(fdt, node, "reg", &len);
> + if (val == NULL || len < 4) {
> + return NULL;
> + return (BUS_TO_PHY((void *) fdt32_to_cpu(val[0])));
> void bsp_start(void)
> bcm2835_get_board_spec_entries spec = { 0 };
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> index 77aa360977..57562c10c7 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> @@ -64,11 +64,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
> librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/irq/irq.c
> # Console
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/arm-pl011.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console-config.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console_select.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/usart.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fb.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/outch.c
