[PATCH] cpukit/libfs: remove more dead code from pipe/fifo.c
Fri Jan 3 19:01:22 UTC 2020
Looks good to me.
FWIW the one in untar may have to be annotated as ok in the code. They
legitimately see a potential race condition but we should document that
untar should be allowed to run with no interference.
On Fri, Jan 3, 2020, 12:56 PM Gedare Bloom <gedare at rtems.org> wrote:
> Dead code identified by Coverity (CID 1456674). The value of ret
> at line 358 is always 0.
>  cpukit/libfs/src/pipe/fifo.c | 2 --
>  1 file changed, 2 deletions(-)
> diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
> index 579f118bfd..0a3cbf3d65 100644
> --- a/cpukit/libfs/src/pipe/fifo.c
> +++ b/cpukit/libfs/src/pipe/fifo.c
> @@ -355,8 +355,6 @@ ssize_t pipe_write(
>        pipe->waitingWriters ++;
>        PIPE_WRITEWAIT(pipe);
>        pipe->waitingWriters --;
> -      if (ret != 0)
> -        goto out_locked;
>        if (pipe->Readers == 0) {
>          ret = -EPIPE;
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200103/199f72d4/attachment.html>
