[PATCH] cpukit/libfs: remove more dead code from pipe/fifo.c
Fri Jan 3 18:56:22 UTC 2020
Dead code identified by Coverity (CID 1456674). The value of ret
at line 358 is always 0.
 cpukit/libfs/src/pipe/fifo.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
index 579f118bfd..0a3cbf3d65 100644
--- a/cpukit/libfs/src/pipe/fifo.c
+++ b/cpukit/libfs/src/pipe/fifo.c
@@ -355,8 +355,6 @@ ssize_t pipe_write(
       pipe->waitingWriters ++;
       PIPE_WRITEWAIT(pipe);
       pipe->waitingWriters --;
-      if (ret != 0)
-        goto out_locked;
       if (pipe->Readers == 0) {
         ret = -EPIPE;
2.17.1
