What do you want to study in GSOC 2020?
Niteesh
gsnb.gn at gmail.com
Fri Jan 3 19:17:41 UTC 2020
Finally, I am able to load IMAGES into Rpi3 using u-boot. But didn't
check whether FDT works. I added the AUX driver from my bare-metal
project for testing. I'll replace it with NS16550 soon.
I loaded the fileio example and it prints the board information. Below
is the link to the screenshot
https://ibb.co/cJbFHqz
But it's stuck there, maybe an exception was raised because I didn't
modify the address for another device but not sure! Can you think of
something
which could have caused it?
On Fri, Jan 3, 2020 at 11:07 PM Niteesh <gsnb.gn at gmail.com> wrote:
> On Fri, Jan 3, 2020 at 7:30 PM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> On 03/01/2020 13:49, Niteesh wrote:
>> > I have gone through previous year works and selected a few topics which
>> > I found
>> > interesting.
>> > 1. Basic Support for Trace Compass #3696
>> > <https://devel.rtems.org/ticket/3696>.
>> A basic support has been added last year and Sebastian extended that
>> quite a bit because we had a customer who needed it. I'm not sure what
>> the current state is and whether there are tasks left that could be done
>> in a GSoC project.
>> > 2. RTEMS testing tool project #2927 <
>> https://devel.rtems.org/ticket/2927>.
>> No idea what the status is. Chris?
>> > 3. Beagle BSP: Add a flattened device tree based initialization #3784
>> > <https://devel.rtems.org/ticket/3784>.
>> That one is open. It would include adding some infrastructure for fdt
>> based drivers. In theory you could do the same project for raspberry or
>> any other board.
>> Please note Gedares comment from the previous mail:
>> > Infrastructure projects are nice (FDT, dynamic linking, debugger,
>> > tracer) but need to be clearly defined ahead of time and discussed
>> > thoroughly with the community, or you risk ending up in the "long
>> > tedious discussions" when you should be coding.
>> > 4. BSPs for Simulators #2903 <https://devel.rtems.org/ticket/2903>.
>> That's always open.
>> Some simulators are easy because the board is already supported and you
>> only have to find out how to start it. For these a tester integration is
>> a good target. But most likely that's only small stuff and should be
>> only one part of a project.
>> Other simulators are not supported yet. In that case you have to write
>> some drivers which can be a good project size.
>> > 5. Improve the Raspberry Pi BSP #2899 <
>> https://devel.rtems.org/ticket/2899>.
>> You already noted: The raspberry BSP isn't in the best shape. So it's
>> quite open for improvement.
>> I think that there is still some work getting it to run again. We don't
>> have something with "*bcm*" in libbsd yet so most likely USB and
>> Ethernet are not working yet. Could be still still be a nice task.
> Why don't we use the driver's from other sources as a reference and create
> our
> own, for USB https://github.com/Chadderz121/csud this could be used as a
> reference, U-boot, and Linux are good sources too. But is it worth the
> effort for a
> BSP like raspberry pi? There is also a c++ bare metal environment called
> circle
> https://github.com/rsta2/circle which supports USB(
> https://github.com/rsta2/uspi)
> and ethernet.
> Christian, can you check out this https://github.com/0xabu/qemu/wiki it
> partially supports
> USB, can you give it a try?
>> With the difficulties getting it to run on RPi3 or RPi4 that might could
>> be also a project. It seems that they are aarch64. Also I was quite
>> surprised about it I didn't find a aarch64 BSP. So that would be a new
>> port.
> Rpi3 looks for kernel7.img if it finds one, it boots into 32bit mode, so
> if the, offset is the only difference
> between rpi2 and rpi3 it should boot without any issues I'll try adding
> the AUX uart driver
> and see if it boots on Rpi3.
> I would also like to discuss about the FDT infrastructure for RTEMS, I
> would like to know what are
> the requirements, what could be expected in a short span of 3months, what
> could be used as a reference
> and so on.
> Note that an aarch64 port would most likely be observed with argus eyes
>> because it has the potential to be a very important port. But don't let
>> that keep you bag suggesting it.
>> > I would like to know what are the future plans for these topics.
>> > What is the current status of USB and ethernet in raspberrypi?
>> > Does the beagle BSP require hardware or is it possible to emulate it?
>> I never used an emulator for Beagle. It seems that qemu supported it
>> some when:
>> https://www.cnx-software.com/2011/09/26/beagleboard-emulator-in-ubuntu-with-qemu/
>> But I didn't find it in current qemu. So most likely it would need
>> hardware.
>> > Last year Vijay Kumar Banerjee worked on analysis and generation of gcov
>> > reports.
>> > On Thu, Jan 2, 2020 at 10:07 PM Gedare Bloom <gedare at rtems.org
>> > <mailto:gedare at rtems.org>> wrote:
>> > On Mon, Dec 30, 2019 at 2:47 PM Christian Mauderer
>> > <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>> > > On 30/12/2019 15:45, Niteesh wrote:
>> > > > On Mon, Dec 30, 2019 at 7:14 PM Christian Mauderer
>> > > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>> > > > On 30/12/2019 07:25, Niteesh wrote:
>> > > > > On Mon, Dec 30, 2019 at 4:44 AM Peter Dufault
>> > <dufault at hda.com <mailto:dufault at hda.com>
>> > > > <mailto:dufault at hda.com <mailto:dufault at hda.com>>
>> > <mailto:dufault at hda.com <mailto:dufault at hda.com>>>> wrote:
>> > > > > Niteesh, what do you want to study? Go over what most
>> > > > interests you
>> > > > > most about working in a real-time environment like
>> > RTEMS, and not
>> > > > > about working on the RPI, and look at the earlier GSOC
>> > projects.
>> > > > > Propose an ideal project for yourself and get some
>> > feedback.
>> > > > Peter: Thanks for starting that discussion. I started to
>> > focus too much
>> > > > on the running topics about small stuff that can be done as
>> a
>> > > > preparation.
>> > > > > I love learning about how the software and hardware
>> > interact, I have
>> > > > > been programming from 9th grade and have a wide variety of
>> > > > > interests(networking, app development). But recently I
>> > took a course
>> > > > > called nandtotetris were we build an 8bit computer from
>> > scratch, we
>> > > > > start with NAND gates and finally finish with a Tetris
>> game.
>> > > > That sounds like a really nice course. Most likely is ended
>> > in a bigger
>> > > > pile of circuit boards to have a running processor ;-)
>> > > > It is a free course on
>> > > > coursera
>> > https://www.coursera.org/learn/build-a-computer/home/welcome
>> > > > do check it out. It's completely simulated in software. But
>> > planning to
>> > > > build it on PCB.
>> > > > > Low-level
>> > > > > software, systems programming, and operating systems are
>> > always quite
>> > > > > fascinating for me. While learning about operating
>> > systems, I came
>> > > > > across the concepts of real-time systems. Back then
>> > arduino was
>> > > > the only
>> > > > > hardware I was having while searching for an RTOS to play
>> > with, I came
>> > > > > across RTEMS. RTOS was harder for me to grasp but were
>> always
>> > > > > interesting, being a critical part of a system, I always
>> > wanted to
>> > > > learn
>> > > > > how they worked from inside. That's what bought me to
>> > contributing
>> > > > to RTOS.
>> > > > > I wanted to contribute to core of RTEMS, but it was a bit
>> > complex
>> > > > for me
>> > > > > to understand, so I started with driver development for
>> RTEMS.
>> > > > That's where I started too. But don't hesitate to pick a
>> > more complex
>> > > > topic if you are interested in it. From what I've seen you
>> > can read and
>> > > > understand existing code quite fast compared to some other
>> > GSoC students
>> > > > we had. So I would say that you have a good chance to manage
>> > complex
>> > > > topics too.
>> > > > Thank you, it's quite good to hear.
>> > > > > After going through some of the previous GSOC projects,
>> BSP
>> > > > development
>> > > > > and real-time tracing are what I find interesting. While
>> also
>> > > > converting
>> > > > > the console driver of rpi to FDT based one, *Christian
>> > Mauderer
>> > > > > *explained how
>> > > > > FDT worked in FreeBSD and Linux, and RTEMS lacked that
>> > > > infrastructure, I
>> > > > > have no idea of how hard it would it, and if I am even
>> > capable of
>> > > > > developing it. But one proposal would be to build the FDT
>> > > > infrastructure
>> > > > > similar to FreeBSD or Linux and have the driver's probe
>> > and attach to
>> > > > > the hardware.
>> > > > We start to have more and more FDT based BSPs. So it would
>> > be great if
>> > > > our infrastructure would improve. But like I said: Don't
>> > hesitate to
>> > > > pick any other topic. Device drivers (and similar) are low
>> > hanging fruit
>> > > > where it is easy to get success and it isn't very likely to
>> > start long
>> > > > tedious discussions because you only touch one BSP.
>> > Therefore I tend to
>> > > > suggest them for GSoC. But GSoC isn't limited to that.
>> > > > So if you would like to work at any other topic like (for
>> > example)
>> > > > porting a new architecture, hacking on some scheduler, do
>> > something with
>> > > > the dynamic linking support, add stuff to the libdebugger,
>> > or basically
>> > > > anything else: Just ask whether someone knows a topic in
>> > that area or is
>> > > > interested in mentoring one you suggest. Most likely the
>> > mailing list
>> > > > will become quite a bit more active again in about a week.
>> > I'll be lurking.
>> > BSP Projects are only good if they are useful. RPI3 might be useful,
>> > although there haven't been a lot of folks clamoring for it.
>> > > > Once I finish with the raspberry pi, I will try to port RTEMS
>> > for esp32.
>> > > > I have that board,
>> > > > It has quite a lot of features and really good documentation.
>> It is
>> > > > based on xtensa CPU.
>> > > > https://devel.rtems.org/wiki/TBR/UserManual/SupportedCPUs and
>> is
>> > under
>> > > > RTEMS potential port.
>> > > Interesting idea. You should post that as a project idea for your
>> GSoC
>> > > project. There are quite some points for new cores that can make a
>> > port
>> > > very simple or hard as hell. I don't have the experience to give a
>> > good
>> > > estimate for that core. But don't worry. I'm quite sure that this
>> > can be
>> > > an interesting project.
>> > > Just some random thoughts:
>> > > - It seems that the Xtensa is supported in the official GCC since
>> > quite
>> > > some time up to the most recent releases. That's a really good
>> > starting
>> > > point.
>> > > - The core is a commercial IP core. It might can get hard to get a
>> > > detailed core documentation. Let's hope that there is enough
>> community
>> > > documentation for it.
>> > > - I didn't really find the core in any other (buyable) chip but
>> the
>> > > ESP32. Do you know whether it is used somewhere else?
>> > > - The ESP32 doesn't have too much RAM. If I've seen it right it's
>> > 520kB
>> > > on-chip. We have smaller targets than that but it's not really
>> > much. The
>> > > libbsd network stack will most likely never run on it. But lwIP
>> should
>> > > work. But I think network stack is something that won't be a topic
>> > for a
>> > > first port anyway ;-)
>> > > - The Technical Reference Manual looks reasonable detailed:
>> https://docs.espressif.com/projects/esp-idf/en/latest/hw-reference/index.html
>> > > - For the low level port you definitively need a hardware debugger
>> > or a
>> > > good simulator. It seems that JTAG access is possible using
>> OpenOCD.
>> > > There is even an official guide from the manufacturer:
>> https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/jtag-debugging/
>> > A new architecture port is a worthwhile GSoC Project. There would
>> be a
>> > lot of learning and code generated. However as above there is a
>> > question about utility: Will there be more than 1 xtensa user?
>> > Historically, DPSs seem to have low demand for an RTOS like RTEMS.
>> It
>> > is still a good GSoC project though. One of the barriers to a new
>> > architecture however will be testability: is there a simulator that
>> > can be used for development/testing?
>> > For difficulty, the thing to investigate is how complex is the
>> > register context, interrupt handling mechanisms, memory management,
>> > and on-chip devices (timers, etc.). Also whether or not there is a
>> > 2/3-BSD compliant port elsewhere for reusable code. The base xtensa
>> > looks straightforward. The ESP32 is an interesting board.
>> > > > > > On Dec 28, 2019, at 05:12 , Christian Mauderer
>> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>> > > > > > On 28/12/2019 07:12, Niteesh wrote:
>> > > > > >> On Sat, 28 Dec, 2019, 3:51 AM Christian Mauderer,
>> > <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>> > > > > >> On 27/12/2019 19:06, Niteesh wrote:
>> > > > > >>> Is there something else that I could work on? I am
>> > > > interested in
>> > > > > >> taking
>> > > > > >>> part
>> > > > > >>> GSOC of 2020. And I want to learn as much as
>> possible.
>> > > > > >> Do you search tasks specific to raspberry or
>> general
>> > > > ones? Do
>> > > > > you search
>> > > > > >> something for GSoC or just to warm up?
>> > > > > >> Anything is fine as long as I am learning
>> > something. Since rpi3
>> > > > > is the
>> > > > > >> only hardware I have, I am interested in tasks
>> > specific to
>> > > > raspi and
>> > > > > >> general ones which do not require any hardware.
>> > > > > > For raspberry I think you could continue to get it
>> > running
>> > > > on RPi3. My
>> > > > > > suggestion would be to replace the table based
>> > initialization
>> > > > > (which is
>> > > > > > handled by console-termios-init.c) with one based on
>> > the fdt
>> > > > that is
>> > > > > > similar to the one in the imx BSP. That will allow
>> > to use
>> > > > the same
>> > > > > > binary on RPi2 and RPi3. But please do that in an
>> > extra patch
>> > > > > after the
>> > > > > > one that you currently have sent to the mailing
>> list.
>> > > > > > Some other raspberry specific topics could be the
>> > following.
>> > > > Note that
>> > > > > > this are only suggestions. I don't want to force you
>> > to do
>> > > > any of them
>> > > > > > if you don't like them:
>> > > > > > - Documentation how you run an application in QEMU /
>> > on real
>> > > > hardware
>> > > > > > for the user manual:
>> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
>> > > > > > (I hope I didn't miss a patch that you already sent
>> > > > > > - A configuration for RTEMS tester that uses the
>> QEMU or
>> > > > real hardware
>> > > > > > (I think the pi3 allows network boot?). This allows
>> > regular
>> > > > test runs
>> > > > > > for this BSP:
>> > https://docs.rtems.org/branches/master/user/testing/index.html and
>> > https://docs.rtems.org/branches/master/user/tools/tester.html
>> > > > > > - Chris created a boot image generator last year. It
>> > would
>> > > > be great if
>> > > > > > you could add a configuration to create raspberry SD
>> > images
>> > > > to it:
>> > https://docs.rtems.org/branches/master/user/tools/boot-image.html
>> > > > > > - You can pick basically any component that isn't
>> > already
>> > > > there and
>> > > > > > integrate it. If you want to work with libbsd:
>> > Testing or
>> > > > porting
>> > > > > > Ethernet support could be something.
>> > > > > > - You most likely want to do something with RPi in
>> > your GSoC
>> > > > too. So
>> > > > > > maybe some comments ("x is already done", "y seems
>> to be
>> > > > still open")
>> > > > > > for the ticket for it would be nice too:
>> > > > > > For non raspberry topics: We have a lot of open bugs
>> > where
>> > > > everyone is
>> > > > > > happy if they are closed:
>> https://devel.rtems.org/query
>> > > > > > A lot of them might are even out of date and just
>> need
>> > > > someone who
>> > > > > reads
>> > > > > > them and asks whether they can be closed.
>> > > > > >>> On Fri, Dec 27, 2019 at 5:07 PM Christian Mauderer
>> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>> > > > > >>> On 27/12/2019 12:20, Niteesh wrote:
>> > > > > >>> > I have sent the patch. I also sent a
>> > documentation
>> > > > update
>> > > > > >> for the
>> > > > > >>> > quick-start section
>> > > > > >>> > a few months ago. But no one took a look at
>> > it. Can you
>> > > > > have a
>> > > > > >>> look at it?
>> > > > > >>> I'll try to have a look at it soon.
>> > > > https://www.mail-archive.com/devel@rtems.org/msg20965.html
>> > > > > >>> If you don't get any responses to a patch
>> > please just
>> > > > send a
>> > > > > >> reminder
>> > > > > >>> one or two weeks later. It's quite likely
>> > that the
>> > > > patch just
>> > > > > >> slipped
>> > > > > >>> the attention.
>> > > > > >>> Normally I leave documentation patches to our
>> > native
>> > > > speakers.
>> > > > > >> They spot
>> > > > > >>> a lot of errors that I won't be able to find.
>> > > > > >>> Can you please send a ping for the patch. You
>> > can add
>> > > > me to CC
>> > > > > >> and for
>> > > > > >>> this one I would suggest to CC Chris Johns
>> too.
>> > > > > > _______________________________________________
>> > > > > > devel mailing list
>> > > > > > devel at rtems.org <mailto:devel at rtems.org>
>> > <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>> > <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>> > > > > > http://lists.rtems.org/mailman/listinfo/devel
>> > > > > Peter
>> > > > > Peter Dufault
>> > > > > HD Associates, Inc. Software and System
>> Engineering
>> > > > > This email is delivered through the public internet
>> using
>> > > > protocols
>> > > > > subject to interception and tampering.
>> > > devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200104/b85d5212/attachment-0001.html>
