What do you want to study in GSOC 2020?
Niteesh gsnb.gn at gmail.com
Sat Jan 4 03:13:52 UTC 2020
On Sat, Jan 4, 2020 at 1:29 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 03/01/2020 18:37, Niteesh wrote:
> > On Fri, Jan 3, 2020 at 7:30 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     On 03/01/2020 13:49, Niteesh wrote:
> >     > I have gone through previous year works and selected a few topics
> >     which
> >     > I found
> >     > interesting.
> >     > 1. Basic Support for Trace Compass #3696
> >     > <https://devel.rtems.org/ticket/3696>.
> >     A basic support has been added last year and Sebastian extended that
> >     quite a bit because we had a customer who needed it. I'm not sure
> what
> >     the current state is and whether there are tasks left that could be
> done
> >     in a GSoC project.
> >     > 2. RTEMS testing tool project #2927
> >     <https://devel.rtems.org/ticket/2927>.
> >     No idea what the status is. Chris?
> >     > 3. Beagle BSP: Add a flattened device tree based
> initialization #3784
> >     > <https://devel.rtems.org/ticket/3784>.
> >     That one is open. It would include adding some infrastructure for fdt
> >     based drivers. In theory you could do the same project for raspberry
> or
> >     any other board.
> >     Please note Gedares comment from the previous mail:
> >     >     Infrastructure projects are nice (FDT, dynamic linking,
> debugger,
> >     >     tracer) but need to be clearly defined ahead of time and
> discussed
> >     >     thoroughly with the community, or you risk ending up in the
> "long
> >     >     tedious discussions" when you should be coding.
> >     > 4. BSPs for Simulators #2903 <https://devel.rtems.org/ticket/2903
> >     That's always open.
> >     Some simulators are easy because the board is already supported and
> you
> >     only have to find out how to start it. For these a tester
> integration is
> >     a good target. But most likely that's only small stuff and should be
> >     only one part of a project.
> >     Other simulators are not supported yet. In that case you have to
> write
> >     some drivers which can be a good project size.
> >     > 5. Improve the Raspberry Pi BSP #2899
> >     <https://devel.rtems.org/ticket/2899>.
> >     You already noted: The raspberry BSP isn't in the best shape. So it's
> >     quite open for improvement.
> >     I think that there is still some work getting it to run again. We
> don't
> >     have something with "*bcm*" in libbsd yet so most likely USB and
> >     Ethernet are not working yet. Could be still still be a nice task.
> > Why don't we use the driver's from other sources as a reference and
> > create our
> > own, for USB https://github.com/Chadderz121/csud this could be used as a
> > reference, U-boot, and Linux are good sources too. But is it worth the
> > effort for a
> > BSP like raspberry pi? There is also a c++ bare metal environment called
> > circle
> > https://github.com/rsta2/circle which supports
> > USB(https://github.com/rsta2/uspi)
> > and ethernet.
> The reason for using libbsd is that its already there and therefore its
> easy to add for all chips that are supported (and raspberry is supported
> in FreeBSD).
> U-Boot and Linux can't be used most of the time due to license issues.
> Both have a GPL license which isn't usable in a lot of RTEMS
> applications (industrial, automotive, ...). There shouldn't be any GPL
> code in the core repository and we tend to avoid libraries if there are
> alternatives.
> > Christian, can you check out this https://github.com/0xabu/qemu/wiki it
> > partially supports
> > USB, can you give it a try?
> RTEMS with libbsd doesn't yet have a USB support committed for the
> raspberry. Do you mean try it with Linux or Windows? Did you already
> test something? What do you want to find out?
Can you build this version of qemu and see if USB works properly? you don't
have to use RTEMS, you can use a lightweight linux distro and see if you can
talk to a usb device in qemu.
> >     With the difficulties getting it to run on RPi3 or RPi4 that might
> could
> >     be also a project. It seems that they are aarch64. Also I was quite
> >     surprised about it I didn't find a aarch64 BSP. So that would be a
> >     new port.
> > Rpi3 looks for kernel7.img if it finds one, it boots into 32bit mode, so
> > if the, offset is the only difference
> > between rpi2 and rpi3 it should boot without any issues I'll try adding
> > the AUX uart driver
> > and see if it boots on Rpi3.
> Don't forget to add a "kernel_address=0x00200000" line if you use the
> linker file like it is currently there in RTEMS.
For some reason, I couldn't get it to boot using the default bootloader. I
will
be using u-boot since it also makes it easier for me to upload the kernel
images.
> > I would also like to discuss about the FDT infrastructure for RTEMS, I
> > would like to know what are
> > the requirements, what could be expected in a short span of 3months,
> > what could be used as a reference
> > and so on.
> We use a lot of FreeBSD stuff (because it has a matching license and is
> quite well designed most of the time). So I would suggest to take a look
> how the FDT stuff works in FreeBSD and whether we can adopt or port the
> interface - maybe slightly adapted to RTEMS needs like having an early
> initialization for the console driver. Porting or implementing that and
> adapting a few drivers as proof of concept should be possible in the
> given time if you discuss the basic direction before the coding starts.
> Please note (for any project you pick): If there is some unexpected work
> along the way, the initial plan can be adapted. So don't be afraid that
> you might not manage to get everything done. In such a case you just
> have to talk to your mentor (which you should do anyway on a regular
> basis).
> >     Note that an aarch64 port would most likely be observed with argus
> eyes
> >     because it has the potential to be a very important port. But don't
> let
> >     that keep you bag suggesting it.
> >     > I would like to know what are the future plans for these topics.
> >     > What is the current status of USB and ethernet in raspberrypi?
> >     > Does the beagle BSP require hardware or is it possible to emulate
> it?
> >     I never used an emulator for Beagle. It seems that qemu supported it
> >     some when:
> https://www.cnx-software.com/2011/09/26/beagleboard-emulator-in-ubuntu-with-qemu/
> >     But I didn't find it in current qemu. So most likely it would need
> >     hardware.
> >     > Last year Vijay Kumar Banerjee worked on analysis and generation
> >     of gcov
> >     > reports.
> >     > On Thu, Jan 2, 2020 at 10:07 PM Gedare Bloom <gedare at rtems.org
> >     <mailto:gedare at rtems.org>
> >     > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
> >     >     On Mon, Dec 30, 2019 at 2:47 PM Christian Mauderer
> >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     > On 30/12/2019 15:45, Niteesh wrote:
> >     >     > > On Mon, Dec 30, 2019 at 7:14 PM Christian Mauderer
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >     >     > >     On 30/12/2019 07:25, Niteesh wrote:
> >     >     > >     > On Mon, Dec 30, 2019 at 4:44 AM Peter Dufault
> >     >     <dufault at hda.com <mailto:dufault at hda.com>
> >     <mailto:dufault at hda.com <mailto:dufault at hda.com>>
> >     <mailto:dufault at hda.com <mailto:dufault at hda.com>>>
> >     <mailto:dufault at hda.com <mailto:dufault at hda.com>>>>> wrote:
> >     >     > >     >     Niteesh, what do you want to study?  Go over
> >     what most
> >     >     > >     interests you
> >     >     > >     >     most about working in a real-time environment
> like
> >     >     RTEMS, and not
> >     >     > >     >     about working on the RPI, and look at the
> >     earlier GSOC
> >     >     projects.
> >     >     > >     >     Propose an ideal project for yourself and get
> some
> >     >     feedback.
> >     >     > >     Peter: Thanks for starting that discussion. I started
> to
> >     >     focus too much
> >     >     > >     on the running topics about small stuff that can be
> >     done as a
> >     >     > >     preparation.
> >     >     > >     >  I love learning about how the software and hardware
> >     >     interact, I have
> >     >     > >     > been programming from 9th grade and have a wide
> >     variety of
> >     >     > >     > interests(networking, app development). But recently
> I
> >     >     took a course
> >     >     > >     > called nandtotetris were we build an 8bit computer
> from
> >     >     scratch, we
> >     >     > >     > start with NAND gates and finally finish with a
> >     Tetris game.
> >     >     > >     That sounds like a really nice course. Most likely is
> >     ended
> >     >     in a bigger
> >     >     > >     pile of circuit boards to have a running processor ;-)
> >     >     > > It is a free course on
> >     >     > > coursera
> >     >     https://www.coursera.org/learn/build-a-computer/home/welcome
> >     >     > > do check it out. It's completely simulated in software. But
> >     >     planning to
> >     >     > > build it on PCB.
> >     >     > >     > Low-level
> >     >     > >     > software, systems programming, and operating systems
> are
> >     >     always quite
> >     >     > >     > fascinating for me. While learning about operating
> >     >     systems, I came
> >     >     > >     > across the concepts of real-time systems. Back then
> >     >     arduino was
> >     >     > >     the only
> >     >     > >     > hardware I was having while searching for an RTOS to
> >     play
> >     >     with, I came
> >     >     > >     > across RTEMS. RTOS was harder for me to grasp but
> >     were always
> >     >     > >     > interesting, being a critical part of a system, I
> always
> >     >     wanted to
> >     >     > >     learn
> >     >     > >     > how they worked from inside. That's what bought me to
> >     >     contributing
> >     >     > >     to RTOS.
> >     >     > >     > I wanted to contribute to core of RTEMS, but it was
> >     a bit
> >     >     complex
> >     >     > >     for me
> >     >     > >     > to understand, so I started with driver development
> >     for RTEMS.
> >     >     > >     That's where I started too. But don't hesitate to pick
> a
> >     >     more complex
> >     >     > >     topic if you are interested in it. From what I've seen
> you
> >     >     can read and
> >     >     > >     understand existing code quite fast compared to some
> other
> >     >     GSoC students
> >     >     > >     we had. So I would say that you have a good chance to
> >     manage
> >     >     complex
> >     >     > >     topics too.
> >     >     > > Thank you, it's quite good to hear.
> >     >     > >     > After going through some of the previous GSOC
> >     projects, BSP
> >     >     > >     development
> >     >     > >     > and real-time tracing are what I find interesting.
> >     While also
> >     >     > >     converting
> >     >     > >     > the console driver of rpi to FDT based one,
> *Christian
> >     >     Mauderer
> >     >     > >     > *explained how
> >     >     > >     > FDT worked in FreeBSD and Linux, and RTEMS lacked
> that
> >     >     > >     infrastructure, I
> >     >     > >     > have no idea of how hard it would it, and if I am
> even
> >     >     capable of
> >     >     > >     > developing it. But one proposal would be to build
> >     the FDT
> >     >     > >     infrastructure
> >     >     > >     > similar to FreeBSD or Linux and have the driver's
> probe
> >     >     and attach to
> >     >     > >     > the hardware.
> >     >     > >     We start to have more and more FDT based BSPs. So it
> would
> >     >     be great if
> >     >     > >     our infrastructure would improve. But like I said:
> Don't
> >     >     hesitate to
> >     >     > >     pick any other topic. Device drivers (and similar) are
> low
> >     >     hanging fruit
> >     >     > >     where it is easy to get success and it isn't very
> >     likely to
> >     >     start long
> >     >     > >     tedious discussions because you only touch one BSP.
> >     >     Therefore I tend to
> >     >     > >     suggest them for GSoC. But GSoC isn't limited to that.
> >     >     > >     So if you would like to work at any other topic like
> (for
> >     >     example)
> >     >     > >     porting a new architecture, hacking on some scheduler,
> do
> >     >     something with
> >     >     > >     the dynamic linking support, add stuff to the
> libdebugger,
> >     >     or basically
> >     >     > >     anything else: Just ask whether someone knows a topic
> in
> >     >     that area or is
> >     >     > >     interested in mentoring one you suggest. Most likely
> the
> >     >     mailing list
> >     >     > >     will become quite a bit more active again in about a
> week.
> >     >     I'll be lurking.
> debugger,
> discussed
> "long
> >     >     BSP Projects are only good if they are useful. RPI3 might be
> >     useful,
> >     >     although there haven't been a lot of folks clamoring for it.
> >     >     > > Once I finish with the raspberry pi, I will try to port
> RTEMS
> >     >     for esp32.
> >     >     > > I have that board,
> >     >     > > It has quite a lot of features and really good
> >     documentation. It is
> >     >     > > based on xtensa CPU.
> >     >     > > https://devel.rtems.org/wiki/TBR/UserManual/SupportedCPUs
> >     and is
> >     >     under
> >     >     > > RTEMS potential port.
> >     >     > Interesting idea. You should post that as a project idea for
> >     your GSoC
> >     >     > project. There are quite some points for new cores that can
> >     make a
> >     >     port
> >     >     > very simple or hard as hell. I don't have the experience to
> >     give a
> >     >     good
> >     >     > estimate for that core. But don't worry. I'm quite sure that
> >     this
> >     >     can be
> >     >     > an interesting project.
> >     >     > Just some random thoughts:
> >     >     > - It seems that the Xtensa is supported in the official GCC
> >     since
> >     >     quite
> >     >     > some time up to the most recent releases. That's a really
> good
> >     >     starting
> >     >     > point.
> >     >     > - The core is a commercial IP core. It might can get hard to
> >     get a
> >     >     > detailed core documentation. Let's hope that there is enough
> >     community
> >     >     > documentation for it.
> >     >     > - I didn't really find the core in any other (buyable) chip
> >     but the
> >     >     > ESP32. Do you know whether it is used somewhere else?
> >     >     > - The ESP32 doesn't have too much RAM. If I've seen it right
> >     it's
> >     >     520kB
> >     >     > on-chip. We have smaller targets than that but it's not
> really
> >     >     much. The
> >     >     > libbsd network stack will most likely never run on it. But
> >     lwIP should
> >     >     > work. But I think network stack is something that won't be a
> >     topic
> >     >     for a
> >     >     > first port anyway ;-)
> >     >     > - The Technical Reference Manual looks reasonable detailed:
> https://docs.espressif.com/projects/esp-idf/en/latest/hw-reference/index.html
> >     >     > - For the low level port you definitively need a hardware
> >     debugger
> >     >     or a
> >     >     > good simulator. It seems that JTAG access is possible using
> >     OpenOCD.
> >     >     > There is even an official guide from the manufacturer:
> https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/jtag-debugging/
> >     >     A new architecture port is a worthwhile GSoC Project. There
> >     would be a
> >     >     lot of learning and code generated. However as above there is a
> >     >     question about utility: Will there be more than 1 xtensa user?
> >     >     Historically, DPSs seem to have low demand for an RTOS like
> >     RTEMS. It
> >     >     is still a good GSoC project though. One of the barriers to a
> new
> >     >     architecture however will be testability: is there a simulator
> >     that
> >     >     can be used for development/testing?
> >     >     For difficulty, the thing to investigate is how complex is the
> >     >     register context, interrupt handling mechanisms, memory
> >     management,
> >     >     and on-chip devices (timers, etc.). Also whether or not there
> is a
> >     >     2/3-BSD compliant port elsewhere for reusable code. The base
> >     xtensa
> >     >     looks straightforward. The ESP32 is an interesting board.
> >     >     > >     >     > On Dec 28, 2019, at 05:12 , Christian Mauderer
> >     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> >     >     > >     >     > On 28/12/2019 07:12, Niteesh wrote:
> >     >     > >     >     >> On Sat, 28 Dec, 2019, 3:51 AM Christian
> Mauderer,
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
> >     >     > >     >     >>    On 27/12/2019 19:06, Niteesh wrote:
> >     >     > >     >     >>> Is there something else that I could work
> >     on? I am
> >     >     > >     interested in
> >     >     > >     >     >>    taking
> >     >     > >     >     >>> part
> >     >     > >     >     >>> GSOC of 2020. And I want to learn as much as
> >     possible.
> >     >     > >     >     >>    Do you search tasks specific to raspberry
> >     or general
> >     >     > >     ones? Do
> >     >     > >     >     you search
> >     >     > >     >     >>    something for GSoC or just to warm up?
> >     >     > >     >     >> Anything is fine as long as I am learning
> >     >     something. Since rpi3
> >     >     > >     >     is the
> >     >     > >     >     >> only hardware I have, I am interested in tasks
> >     >     specific to
> >     >     > >     raspi and
> >     >     > >     >     >> general ones which do not require any
> hardware.
> >     >     > >     >     > For raspberry I think you could continue to
> get it
> >     >     running
> >     >     > >     on RPi3. My
> >     >     > >     >     > suggestion would be to replace the table based
> >     >     initialization
> >     >     > >     >     (which is
> >     >     > >     >     > handled by console-termios-init.c) with one
> >     based on
> >     >     the fdt
> >     >     > >     that is
> >     >     > >     >     > similar to the one in the imx BSP. That will
> allow
> >     >     to use
> >     >     > >     the same
> >     >     > >     >     > binary on RPi2 and RPi3. But please do that in
> an
> >     >     extra patch
> >     >     > >     >     after the
> >     >     > >     >     > one that you currently have sent to the
> >     mailing list.
> >     >     > >     >     > Some other raspberry specific topics could be
> the
> >     >     following.
> >     >     > >     Note that
> >     >     > >     >     > this are only suggestions. I don't want to
> >     force you
> >     >     to do
> >     >     > >     any of them
> >     >     > >     >     > if you don't like them:
> >     >     > >     >     > - Documentation how you run an application in
> >     QEMU /
> >     >     on real
> >     >     > >     hardware
> >     >     > >     >     > for the user manual:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
> >     >     > >     >     > (I hope I didn't miss a patch that you already
> >     sent
> >     >     > >     >     > - A configuration for RTEMS tester that uses
> >     the QEMU or
> >     >     > >     real hardware
> >     >     > >     >     > (I think the pi3 allows network boot?). This
> >     allows
> >     >     regular
> >     >     > >     test runs
> >     >     > >     >     > for this BSP:
> >       https://docs.rtems.org/branches/master/user/testing/index.html and
> >     >     https://docs.rtems.org/branches/master/user/tools/tester.html
> >     >     > >     >     > - Chris created a boot image generator last
> >     year. It
> >     >     would
> >     >     > >     be great if
> >     >     > >     >     > you could add a configuration to create
> >     raspberry SD
> >     >     images
> >     >     > >     to it:
> https://docs.rtems.org/branches/master/user/tools/boot-image.html
> >     >     > >     >     > - You can pick basically any component that
> isn't
> >     >     already
> >     >     > >     there and
> >     >     > >     >     > integrate it. If you want to work with libbsd:
> >     >     Testing or
> >     >     > >     porting
> >     >     > >     >     > Ethernet support could be something.
> >     >     > >     >     > - You most likely want to do something with
> RPi in
> >     >     your GSoC
> >     >     > >     too. So
> >     >     > >     >     > maybe some comments ("x is already done", "y
> >     seems to be
> >     >     > >     still open")
> >     >     > >     >     > for the ticket for it would be nice too:
> >     >     > >     >     > For non raspberry topics: We have a lot of
> >     open bugs
> >     >     where
> >     >     > >     everyone is
> >     >     > >     >     > happy if they are closed:
> >     https://devel.rtems.org/query
> >     >     > >     >     > A lot of them might are even out of date and
> >     just need
> >     >     > >     someone who
> >     >     > >     >     reads
> >     >     > >     >     > them and asks whether they can be closed.
> >     >     > >     >     >>> On Fri, Dec 27, 2019 at 5:07 PM Christian
> >     Mauderer
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
> >     >     > >     >     >>>      On 27/12/2019 12:20, Niteesh wrote:
> >     >     > >     >     >>>      > I have sent the patch. I also sent a
> >     >     documentation
> >     >     > >     update
> >     >     > >     >     >>    for the
> >     >     > >     >     >>>      > quick-start section
> >     >     > >     >     >>>      > a few months ago. But no one took a
> >     look at
> >     >     it. Can you
> >     >     > >     >     have a
> >     >     > >     >     >>>      look at it?
> >     >     > >     >     >>>      I'll try to have a look at it soon.
> https://www.mail-archive.com/devel@rtems.org/msg20965.html
> >     >     > >     >     >>>      If you don't get any responses to a
> patch
> >     >     please just
> >     >     > >     send a
> >     >     > >     >     >>    reminder
> >     >     > >     >     >>>      one or two weeks later. It's quite
> likely
> >     >     that the
> >     >     > >     patch just
> >     >     > >     >     >>    slipped
> >     >     > >     >     >>>      the attention.
> >     >     > >     >     >>>      Normally I leave documentation patches
> >     to our
> >     >     native
> >     >     > >     speakers.
> >     >     > >     >     >>    They spot
> >     >     > >     >     >>>      a lot of errors that I won't be able to
> >     find.
> >     >     > >     >     >>>      Can you please send a ping for the
> >     patch. You
> >     >     can add
> >     >     > >     me to CC
> >     >     > >     >     >>    and for
> >     >     > >     >     >>>      this one I would suggest to CC Chris
> >     Johns too.
> >     >     > >     >     > _______________________________________________
> >     >     > >     >     > devel mailing list
> >     >     > >     >     > devel at rtems.org <mailto:devel at rtems.org>
> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>
> >     >     > >     >     > http://lists.rtems.org/mailman/listinfo/devel
> >     >     > >     >     Peter
> >     >     > >     >     Peter Dufault
> >     >     > >     >     HD Associates, Inc.      Software and System
> >     Engineering
> >     >     > >     >     This email is delivered through the public
> >     internet using
> >     >     > >     protocols
> >     >     > >     >     subject to interception and tampering.
> >     >     > devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200104/42ea3383/attachment-0001.html>
