What do you want to study in GSOC 2020?
Christian Mauderer list at c-mauderer.de
Fri Jan 3 19:59:30 UTC 2020
On 03/01/2020 18:37, Niteesh wrote:
> On Fri, Jan 3, 2020 at 7:30 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 03/01/2020 13:49, Niteesh wrote:
>     > I have gone through previous year works and selected a few topics
>     which
>     > I found
>     > interesting.
>     > 1. Basic Support for Trace Compass #3696
>     > <https://devel.rtems.org/ticket/3696>.
>     A basic support has been added last year and Sebastian extended that
>     quite a bit because we had a customer who needed it. I'm not sure what
>     the current state is and whether there are tasks left that could be done
>     in a GSoC project.
>     > 2. RTEMS testing tool project #2927
>     <https://devel.rtems.org/ticket/2927>.
>     No idea what the status is. Chris?
>     > 3. Beagle BSP: Add a flattened device tree based initialization #3784
>     > <https://devel.rtems.org/ticket/3784>.
>     That one is open. It would include adding some infrastructure for fdt
>     based drivers. In theory you could do the same project for raspberry or
>     any other board.
>     Please note Gedares comment from the previous mail:
>     >     Infrastructure projects are nice (FDT, dynamic linking, debugger,
>     >     tracer) but need to be clearly defined ahead of time and discussed
>     >     thoroughly with the community, or you risk ending up in the "long
>     >     tedious discussions" when you should be coding.
>     > 4. BSPs for Simulators #2903 <https://devel.rtems.org/ticket/2903>.
>     That's always open.
>     Some simulators are easy because the board is already supported and you
>     only have to find out how to start it. For these a tester integration is
>     a good target. But most likely that's only small stuff and should be
>     only one part of a project.
>     Other simulators are not supported yet. In that case you have to write
>     some drivers which can be a good project size.
>     > 5. Improve the Raspberry Pi BSP #2899
>     <https://devel.rtems.org/ticket/2899>.
>     You already noted: The raspberry BSP isn't in the best shape. So it's
>     quite open for improvement.
>     I think that there is still some work getting it to run again. We don't
>     have something with "*bcm*" in libbsd yet so most likely USB and
>     Ethernet are not working yet. Could be still still be a nice task.
> Why don't we use the driver's from other sources as a reference and
> create our
> own, for USB https://github.com/Chadderz121/csud this could be used as a
> reference, U-boot, and Linux are good sources too. But is it worth the
> effort for a
> BSP like raspberry pi? There is also a c++ bare metal environment called
> circle
> https://github.com/rsta2/circle which supports
> USB(https://github.com/rsta2/uspi)
> and ethernet.
The reason for using libbsd is that its already there and therefore its
easy to add for all chips that are supported (and raspberry is supported
in FreeBSD).
U-Boot and Linux can't be used most of the time due to license issues.
Both have a GPL license which isn't usable in a lot of RTEMS
applications (industrial, automotive, ...). There shouldn't be any GPL
code in the core repository and we tend to avoid libraries if there are
alternatives.
> Christian, can you check out this https://github.com/0xabu/qemu/wiki it
> partially supports
> USB, can you give it a try?
RTEMS with libbsd doesn't yet have a USB support committed for the
raspberry. Do you mean try it with Linux or Windows? Did you already
test something? What do you want to find out?
>     With the difficulties getting it to run on RPi3 or RPi4 that might could
>     be also a project. It seems that they are aarch64. Also I was quite
>     surprised about it I didn't find a aarch64 BSP. So that would be a
>     new port.
> Rpi3 looks for kernel7.img if it finds one, it boots into 32bit mode, so
> if the, offset is the only difference
> between rpi2 and rpi3 it should boot without any issues I'll try adding
> the AUX uart driver
> and see if it boots on Rpi3.
Don't forget to add a "kernel_address=0x00200000" line if you use the
linker file like it is currently there in RTEMS.
> I would also like to discuss about the FDT infrastructure for RTEMS, I
> would like to know what are
> the requirements, what could be expected in a short span of 3months,
> what could be used as a reference
> and so on.
We use a lot of FreeBSD stuff (because it has a matching license and is
quite well designed most of the time). So I would suggest to take a look
how the FDT stuff works in FreeBSD and whether we can adopt or port the
interface - maybe slightly adapted to RTEMS needs like having an early
initialization for the console driver. Porting or implementing that and
adapting a few drivers as proof of concept should be possible in the
given time if you discuss the basic direction before the coding starts.
Please note (for any project you pick): If there is some unexpected work
along the way, the initial plan can be adapted. So don't be afraid that
you might not manage to get everything done. In such a case you just
have to talk to your mentor (which you should do anyway on a regular basis).
>     Note that an aarch64 port would most likely be observed with argus eyes
>     because it has the potential to be a very important port. But don't let
>     that keep you bag suggesting it.
>     > I would like to know what are the future plans for these topics.
>     > What is the current status of USB and ethernet in raspberrypi?
>     > Does the beagle BSP require hardware or is it possible to emulate it?
>     I never used an emulator for Beagle. It seems that qemu supported it
>     some when:
>     https://www.cnx-software.com/2011/09/26/beagleboard-emulator-in-ubuntu-with-qemu/
>     But I didn't find it in current qemu. So most likely it would need
>     hardware.
>     > Last year Vijay Kumar Banerjee worked on analysis and generation
>     of gcov
>     > reports.
>     > On Thu, Jan 2, 2020 at 10:07 PM Gedare Bloom <gedare at rtems.org
>     <mailto:gedare at rtems.org>
>     > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
>     >     On Mon, Dec 30, 2019 at 2:47 PM Christian Mauderer
>     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     > On 30/12/2019 15:45, Niteesh wrote:
>     >     > > On Mon, Dec 30, 2019 at 7:14 PM Christian Mauderer
>     >     > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >     > >     On 30/12/2019 07:25, Niteesh wrote:
>     >     > >     > On Mon, Dec 30, 2019 at 4:44 AM Peter Dufault
>     >     <dufault at hda.com <mailto:dufault at hda.com>
>     <mailto:dufault at hda.com <mailto:dufault at hda.com>>
>     >     > >     <mailto:dufault at hda.com <mailto:dufault at hda.com>
>     <mailto:dufault at hda.com <mailto:dufault at hda.com>>>
>     >     > >     > <mailto:dufault at hda.com <mailto:dufault at hda.com>
>     <mailto:dufault at hda.com <mailto:dufault at hda.com>>>>> wrote:
>     >     > >     >     Niteesh, what do you want to study?  Go over
>     what most
>     >     > >     interests you
>     >     > >     >     most about working in a real-time environment like
>     >     RTEMS, and not
>     >     > >     >     about working on the RPI, and look at the
>     earlier GSOC
>     >     projects.
>     >     > >     >     Propose an ideal project for yourself and get some
>     >     feedback.
>     >     > >     Peter: Thanks for starting that discussion. I started to
>     >     focus too much
>     >     > >     on the running topics about small stuff that can be
>     done as a
>     >     > >     preparation.
>     >     > >     >  I love learning about how the software and hardware
>     >     interact, I have
>     >     > >     > been programming from 9th grade and have a wide
>     variety of
>     >     > >     > interests(networking, app development). But recently I
>     >     took a course
>     >     > >     > called nandtotetris were we build an 8bit computer from
>     >     scratch, we
>     >     > >     > start with NAND gates and finally finish with a
>     Tetris game.
>     >     > >     That sounds like a really nice course. Most likely is
>     ended
>     >     in a bigger
>     >     > >     pile of circuit boards to have a running processor ;-)
>     >     > > It is a free course on
>     >     > > coursera
>     >     https://www.coursera.org/learn/build-a-computer/home/welcome
>     >     > > do check it out. It's completely simulated in software. But
>     >     planning to
>     >     > > build it on PCB.
>     >     > >     > Low-level
>     >     > >     > software, systems programming, and operating systems are
>     >     always quite
>     >     > >     > fascinating for me. While learning about operating
>     >     systems, I came
>     >     > >     > across the concepts of real-time systems. Back then
>     >     arduino was
>     >     > >     the only
>     >     > >     > hardware I was having while searching for an RTOS to
>     play
>     >     with, I came
>     >     > >     > across RTEMS. RTOS was harder for me to grasp but
>     were always
>     >     > >     > interesting, being a critical part of a system, I always
>     >     wanted to
>     >     > >     learn
>     >     > >     > how they worked from inside. That's what bought me to
>     >     contributing
>     >     > >     to RTOS.
>     >     > >     > I wanted to contribute to core of RTEMS, but it was
>     a bit
>     >     complex
>     >     > >     for me
>     >     > >     > to understand, so I started with driver development
>     for RTEMS.
>     >     > >     That's where I started too. But don't hesitate to pick a
>     >     more complex
>     >     > >     topic if you are interested in it. From what I've seen you
>     >     can read and
>     >     > >     understand existing code quite fast compared to some other
>     >     GSoC students
>     >     > >     we had. So I would say that you have a good chance to
>     manage
>     >     complex
>     >     > >     topics too.
>     >     > > Thank you, it's quite good to hear.
>     >     > >     > After going through some of the previous GSOC
>     projects, BSP
>     >     > >     development
>     >     > >     > and real-time tracing are what I find interesting.
>     While also
>     >     > >     converting
>     >     > >     > the console driver of rpi to FDT based one, *Christian
>     >     Mauderer
>     >     > >     > *explained how
>     >     > >     > FDT worked in FreeBSD and Linux, and RTEMS lacked that
>     >     > >     infrastructure, I
>     >     > >     > have no idea of how hard it would it, and if I am even
>     >     capable of
>     >     > >     > developing it. But one proposal would be to build
>     the FDT
>     >     > >     infrastructure
>     >     > >     > similar to FreeBSD or Linux and have the driver's probe
>     >     and attach to
>     >     > >     > the hardware.
>     >     > >     We start to have more and more FDT based BSPs. So it would
>     >     be great if
>     >     > >     our infrastructure would improve. But like I said: Don't
>     >     hesitate to
>     >     > >     pick any other topic. Device drivers (and similar) are low
>     >     hanging fruit
>     >     > >     where it is easy to get success and it isn't very
>     likely to
>     >     start long
>     >     > >     tedious discussions because you only touch one BSP.
>     >     Therefore I tend to
>     >     > >     suggest them for GSoC. But GSoC isn't limited to that.
>     >     > >     So if you would like to work at any other topic like (for
>     >     example)
>     >     > >     porting a new architecture, hacking on some scheduler, do
>     >     something with
>     >     > >     the dynamic linking support, add stuff to the libdebugger,
>     >     or basically
>     >     > >     anything else: Just ask whether someone knows a topic in
>     >     that area or is
>     >     > >     interested in mentoring one you suggest. Most likely the
>     >     mailing list
>     >     > >     will become quite a bit more active again in about a week.
>     >     I'll be lurking.
>     >     BSP Projects are only good if they are useful. RPI3 might be
>     useful,
>     >     although there haven't been a lot of folks clamoring for it.
>     >     > > Once I finish with the raspberry pi, I will try to port RTEMS
>     >     for esp32.
>     >     > > I have that board,
>     >     > > It has quite a lot of features and really good
>     documentation. It is
>     >     > > based on xtensa CPU.
>     >     > > https://devel.rtems.org/wiki/TBR/UserManual/SupportedCPUs
>     and is
>     >     under
>     >     > > RTEMS potential port.
>     >     > Interesting idea. You should post that as a project idea for
>     your GSoC
>     >     > project. There are quite some points for new cores that can
>     make a
>     >     port
>     >     > very simple or hard as hell. I don't have the experience to
>     give a
>     >     good
>     >     > estimate for that core. But don't worry. I'm quite sure that
>     this
>     >     can be
>     >     > an interesting project.
>     >     > Just some random thoughts:
>     >     > - It seems that the Xtensa is supported in the official GCC
>     since
>     >     quite
>     >     > some time up to the most recent releases. That's a really good
>     >     starting
>     >     > point.
>     >     > - The core is a commercial IP core. It might can get hard to
>     get a
>     >     > detailed core documentation. Let's hope that there is enough
>     community
>     >     > documentation for it.
>     >     > - I didn't really find the core in any other (buyable) chip
>     but the
>     >     > ESP32. Do you know whether it is used somewhere else?
>     >     > - The ESP32 doesn't have too much RAM. If I've seen it right
>     it's
>     >     520kB
>     >     > on-chip. We have smaller targets than that but it's not really
>     >     much. The
>     >     > libbsd network stack will most likely never run on it. But
>     lwIP should
>     >     > work. But I think network stack is something that won't be a
>     topic
>     >     for a
>     >     > first port anyway ;-)
>     >     > - The Technical Reference Manual looks reasonable detailed:
>      https://docs.espressif.com/projects/esp-idf/en/latest/hw-reference/index.html
>     >     > - For the low level port you definitively need a hardware
>     debugger
>     >     or a
>     >     > good simulator. It seems that JTAG access is possible using
>     OpenOCD.
>     >     > There is even an official guide from the manufacturer:
>      https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/jtag-debugging/
>     >     A new architecture port is a worthwhile GSoC Project. There
>     would be a
>     >     lot of learning and code generated. However as above there is a
>     >     question about utility: Will there be more than 1 xtensa user?
>     >     Historically, DPSs seem to have low demand for an RTOS like
>     RTEMS. It
>     >     is still a good GSoC project though. One of the barriers to a new
>     >     architecture however will be testability: is there a simulator
>     that
>     >     can be used for development/testing?
>     >     For difficulty, the thing to investigate is how complex is the
>     >     register context, interrupt handling mechanisms, memory
>     management,
>     >     and on-chip devices (timers, etc.). Also whether or not there is a
>     >     2/3-BSD compliant port elsewhere for reusable code. The base
>     xtensa
>     >     looks straightforward. The ESP32 is an interesting board.
>     >     > >     >     > On Dec 28, 2019, at 05:12 , Christian Mauderer
>     >     > >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >     > >     >     <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >     > >     >     > On 28/12/2019 07:12, Niteesh wrote:
>     >     > >     >     >> On Sat, 28 Dec, 2019, 3:51 AM Christian Mauderer,
>     >     > >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >     > >     >     >> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >     > >     >     >>    On 27/12/2019 19:06, Niteesh wrote:
>     >     > >     >     >>> Is there something else that I could work
>     on? I am
>     >     > >     interested in
>     >     > >     >     >>    taking
>     >     > >     >     >>> part
>     >     > >     >     >>> GSOC of 2020. And I want to learn as much as
>     possible.
>     >     > >     >     >>    Do you search tasks specific to raspberry
>     or general
>     >     > >     ones? Do
>     >     > >     >     you search
>     >     > >     >     >>    something for GSoC or just to warm up?
>     >     > >     >     >> Anything is fine as long as I am learning
>     >     something. Since rpi3
>     >     > >     >     is the
>     >     > >     >     >> only hardware I have, I am interested in tasks
>     >     specific to
>     >     > >     raspi and
>     >     > >     >     >> general ones which do not require any hardware.
>     >     > >     >     > For raspberry I think you could continue to get it
>     >     running
>     >     > >     on RPi3. My
>     >     > >     >     > suggestion would be to replace the table based
>     >     initialization
>     >     > >     >     (which is
>     >     > >     >     > handled by console-termios-init.c) with one
>     based on
>     >     the fdt
>     >     > >     that is
>     >     > >     >     > similar to the one in the imx BSP. That will allow
>     >     to use
>     >     > >     the same
>     >     > >     >     > binary on RPi2 and RPi3. But please do that in an
>     >     extra patch
>     >     > >     >     after the
>     >     > >     >     > one that you currently have sent to the
>     mailing list.
>     >     > >     >     > Some other raspberry specific topics could be the
>     >     following.
>     >     > >     Note that
>     >     > >     >     > this are only suggestions. I don't want to
>     force you
>     >     to do
>     >     > >     any of them
>     >     > >     >     > if you don't like them:
>     >     > >     >     > - Documentation how you run an application in
>     QEMU /
>     >     on real
>     >     > >     hardware
>     >     > >     >     > for the user manual:
>      https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
>     >     > >     >     > (I hope I didn't miss a patch that you already
>     sent
>     >     > >     >     > - A configuration for RTEMS tester that uses
>     the QEMU or
>     >     > >     real hardware
>     >     > >     >     > (I think the pi3 allows network boot?). This
>     allows
>     >     regular
>     >     > >     test runs
>     >     > >     >     > for this BSP:
>       https://docs.rtems.org/branches/master/user/testing/index.html and
>     >     https://docs.rtems.org/branches/master/user/tools/tester.html
>     >     > >     >     > - Chris created a boot image generator last
>     year. It
>     >     would
>     >     > >     be great if
>     >     > >     >     > you could add a configuration to create
>     raspberry SD
>     >     images
>     >     > >     to it:
>     >      https://docs.rtems.org/branches/master/user/tools/boot-image.html
>     >     > >     >     > - You can pick basically any component that isn't
>     >     already
>     >     > >     there and
>     >     > >     >     > integrate it. If you want to work with libbsd:
>     >     Testing or
>     >     > >     porting
>     >     > >     >     > Ethernet support could be something.
>     >     > >     >     > - You most likely want to do something with RPi in
>     >     your GSoC
>     >     > >     too. So
>     >     > >     >     > maybe some comments ("x is already done", "y
>     seems to be
>     >     > >     still open")
>     >     > >     >     > for the ticket for it would be nice too:
>     >     > >     >     https://devel.rtems.org/ticket/2899
>     >     > >     >     > For non raspberry topics: We have a lot of
>     open bugs
>     >     where
>     >     > >     everyone is
>     >     > >     >     > happy if they are closed:
>     https://devel.rtems.org/query
>     >     > >     >     > A lot of them might are even out of date and
>     just need
>     >     > >     someone who
>     >     > >     >     reads
>     >     > >     >     > them and asks whether they can be closed.
>     >     > >     >     >>> On Fri, Dec 27, 2019 at 5:07 PM Christian
>     Mauderer
>     >     > >     >     >>    <list at c-mauderer.de
>     >     > >     >     >>> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>     >     > >     >     >>>      On 27/12/2019 12:20, Niteesh wrote:
>     >     > >     >     >>>      > I have sent the patch. I also sent a
>     >     documentation
>     >     > >     update
>     >     > >     >     >>    for the
>     >     > >     >     >>>      > quick-start section
>     >     > >     >     >>>      > a few months ago. But no one took a
>     look at
>     >     it. Can you
>     >     > >     >     have a
>     >     > >     >     >>>      look at it?
>     >     > >     >     >>>      I'll try to have a look at it soon.
>     >     > >     https://www.mail-archive.com/devel@rtems.org/msg20965.html
>     >     > >     >     >>>      If you don't get any responses to a patch
>     >     please just
>     >     > >     send a
>     >     > >     >     >>    reminder
>     >     > >     >     >>>      one or two weeks later. It's quite likely
>     >     that the
>     >     > >     patch just
>     >     > >     >     >>    slipped
>     >     > >     >     >>>      the attention.
>     >     > >     >     >>>      Normally I leave documentation patches
>     to our
>     >     native
>     >     > >     speakers.
>     >     > >     >     >>    They spot
>     >     > >     >     >>>      a lot of errors that I won't be able to
>     find.
>     >     > >     >     >>>      Can you please send a ping for the
>     patch. You
>     >     can add
>     >     > >     me to CC
>     >     > >     >     >>    and for
>     >     > >     >     >>>      this one I would suggest to CC Chris
>     Johns too.
>     >     > >     >     > _______________________________________________
>     >     > >     >     > devel mailing list
>     >     > >     >     > devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     >     > >     <mailto:devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>
>     >     > >     >     > http://lists.rtems.org/mailman/listinfo/devel
>     >     > >     >     Peter
>     >     > >     >     Peter Dufault
>     >     > >     >     HD Associates, Inc.      Software and System
>     Engineering
>     >     > >     >     This email is delivered through the public
>     internet using
>     >     > >     protocols
>     >     > >     >     subject to interception and tampering.
