What do you want to study in GSOC 2020?
Christian Mauderer
list at c-mauderer.de
Sat Jan 4 19:08:20 UTC 2020
On 04/01/2020 06:08, Niteesh wrote:
> I problem was in uart_probe, and console_select. I totally forgot about
> console_select
> changing back to pl011. The application starts without any
> issues https://ibb.co/PZY5BWr
> but *rtems_shell_wait_for_input *return unsuccessful, maybe it fails
> because it calls
> ioctl and I haven't provided a proper handler, what do you think?
> Now, since I know everything works I'll add in a proper AUX
> driver(ns16550) and test it again.
> And also if you remember, there was this issue of printing garbage and
> FATAL_SOURCE_EXCEPTION
> while running examples in qemu, I have run the examples multiple times
> on the board and no issues till now.
Quite possible that the qemu simulation isn't complete at some point.
> On Sat, Jan 4, 2020 at 8:47 AM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
> On Sat, Jan 4, 2020 at 3:34 AM Christian Mauderer
> <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
> On 03/01/2020 20:17, Niteesh wrote:
> > Finally, I am able to load IMAGES into Rpi3 using u-boot. But
> didn't
> > check whether FDT works. I added the AUX driver from my bare-metal
> > project for testing. I'll replace it with NS16550 soon.
> > I loaded the fileio example and it prints the board
> information. Below
> > is the link to the screenshot
> > https://ibb.co/cJbFHqz
> That's a great start.
> > But it's stuck there, maybe an exception was raised because I
> didn't
> > modify the address for another device but not sure! Can you
> think of
> > something
> > which could have caused it?
> Exceptions should print an exception frame. So I'm not sure
> whether that
> is the case. Do you have some JTAG adapter that would work with
> OpenOCD
> or simmilar?
> I dont have a JTAG. I going to fallback to printfs. I going to stick
> printf in various places
> and see where it hangs.
> Do you have any other ideas? Can we use GDB?
> > On Fri, Jan 3, 2020 at 11:07 PM Niteesh <gsnb.gn at gmail.com
> > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
> > On Fri, Jan 3, 2020 at 7:30 PM Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > On 03/01/2020 13:49, Niteesh wrote:
> > > I have gone through previous year works and selected
> a few
> > topics which
> > > I found
> > > interesting.
> > > 1. Basic Support for Trace Compass #3696
> > > <https://devel.rtems.org/ticket/3696>.
> > A basic support has been added last year and Sebastian
> extended that
> > quite a bit because we had a customer who needed it.
> I'm not
> > sure what
> > the current state is and whether there are tasks left
> that could
> > be done
> > in a GSoC project.
> > > 2. RTEMS testing tool project #2927
> > <https://devel.rtems.org/ticket/2927>.
> > No idea what the status is. Chris?
> > > 3. Beagle BSP: Add a flattened device tree based
> > initialization #3784
> > > <https://devel.rtems.org/ticket/3784>.
> > That one is open. It would include adding some
> infrastructure
> > for fdt
> > based drivers. In theory you could do the same project for
> > raspberry or
> > any other board.
> > Please note Gedares comment from the previous mail:
> > > Infrastructure projects are nice (FDT, dynamic
> linking,
> > debugger,
> > > tracer) but need to be clearly defined ahead of
> time and
> > discussed
> > > thoroughly with the community, or you risk
> ending up in
> > the "long
> > > tedious discussions" when you should be coding.
> > > 4. BSPs for Simulators #2903
> > <https://devel.rtems.org/ticket/2903>.
> > That's always open.
> > Some simulators are easy because the board is already
> supported
> > and you
> > only have to find out how to start it. For these a tester
> > integration is
> > a good target. But most likely that's only small stuff
> and should be
> > only one part of a project.
> > Other simulators are not supported yet. In that case
> you have to
> > write
> > some drivers which can be a good project size.
> > > 5. Improve the Raspberry Pi BSP #2899
> > <https://devel.rtems.org/ticket/2899>.
> > You already noted: The raspberry BSP isn't in the best
> shape. So
> > it's
> > quite open for improvement.
> > I think that there is still some work getting it to
> run again.
> > We don't
> > have something with "*bcm*" in libbsd yet so most
> likely USB and
> > Ethernet are not working yet. Could be still still be
> a nice task.
> > Why don't we use the driver's from other sources as a
> reference and
> > create our
> > own, for USB https://github.com/Chadderz121/csud this
> could be used as a
> > reference, U-boot, and Linux are good sources too. But is
> it worth
> > the effort for a
> > BSP like raspberry pi? There is also a c++ bare metal
> environment
> > called circle
> > https://github.com/rsta2/circle which supports
> > USB(https://github.com/rsta2/uspi)
> > and ethernet.
> > Christian, can you check out
> > this https://github.com/0xabu/qemu/wiki it partially supports
> > USB, can you give it a try?
> > With the difficulties getting it to run on RPi3 or
> RPi4 that
> > might could
> > be also a project. It seems that they are aarch64.
> Also I was quite
> > surprised about it I didn't find a aarch64 BSP. So
> that would be
> > a new port.
> > Rpi3 looks for kernel7.img if it finds one, it boots into
> 32bit
> > mode, so if the, offset is the only difference
> > between rpi2 and rpi3 it should boot without any issues
> I'll try
> > adding the AUX uart driver
> > and see if it boots on Rpi3.
> > I would also like to discuss about the FDT infrastructure
> for RTEMS,
> > I would like to know what are
> > the requirements, what could be expected in a short span
> of 3months,
> > what could be used as a reference
> > and so on.
> > Note that an aarch64 port would most likely be
> observed with
> > argus eyes
> > because it has the potential to be a very important
> port. But
> > don't let
> > that keep you bag suggesting it.
> > > I would like to know what are the future plans for
> these topics.
> > > What is the current status of USB and ethernet in
> raspberrypi?
> > > Does the beagle BSP require hardware or is it
> possible to
> > emulate it?
> > I never used an emulator for Beagle. It seems that
> qemu supported it
> > some when:
> https://www.cnx-software.com/2011/09/26/beagleboard-emulator-in-ubuntu-with-qemu/
> > But I didn't find it in current qemu. So most likely
> it would
> > need hardware.
> > > Last year Vijay Kumar Banerjee worked on analysis and
> > generation of gcov
> > > reports.
> > > On Thu, Jan 2, 2020 at 10:07 PM Gedare Bloom
> <gedare at rtems.org <mailto:gedare at rtems.org>
> > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>> wrote:
> > > On Mon, Dec 30, 2019 at 2:47 PM Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > On 30/12/2019 15:45, Niteesh wrote:
> > > > > On Mon, Dec 30, 2019 at 7:14 PM Christian
> Mauderer
> <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> > > > > On 30/12/2019 07:25, Niteesh wrote:
> > > > > > On Mon, Dec 30, 2019 at 4:44 AM Peter
> Dufault
> > > <dufault at hda.com <mailto:dufault at hda.com>
> <mailto:dufault at hda.com <mailto:dufault at hda.com>>
> <mailto:dufault at hda.com <mailto:dufault at hda.com>>>
> <mailto:dufault at hda.com> <mailto:dufault at hda.com
> <mailto:dufault at hda.com <mailto:dufault at hda.com>>>>
> <mailto:dufault at hda.com <mailto:dufault at hda.com>>>>>> wrote:
> > > > > > Niteesh, what do you want to
> study? Go over
> > what most
> > > > > interests you
> > > > > > most about working in a real-time
> > environment like
> > > RTEMS, and not
> > > > > > about working on the RPI, and look
> at the
> > earlier GSOC
> > > projects.
> > > > > > Propose an ideal project for
> yourself and
> > get some
> > > feedback.
> > > > > Peter: Thanks for starting that
> discussion. I
> > started to
> > > focus too much
> > > > > on the running topics about small stuff
> that can
> > be done as a
> > > > > preparation.
> > > > > > I love learning about how the
> software and hardware
> > > interact, I have
> > > > > > been programming from 9th grade and
> have a wide
> > variety of
> > > > > > interests(networking, app
> development). But
> > recently I
> > > took a course
> > > > > > called nandtotetris were we build an 8bit
> > computer from
> > > scratch, we
> > > > > > start with NAND gates and finally
> finish with a
> > Tetris game.
> > > > > That sounds like a really nice course.
> Most likely
> > is ended
> > > in a bigger
> > > > > pile of circuit boards to have a running
> processor ;-)
> > > > > It is a free course on
> > > > > coursera
> https://www.coursera.org/learn/build-a-computer/home/welcome
> > > > > do check it out. It's completely simulated in
> > software. But
> > > planning to
> > > > > build it on PCB.
> > > > > > Low-level
> > > > > > software, systems programming, and
> operating
> > systems are
> > > always quite
> > > > > > fascinating for me. While learning
> about operating
> > > systems, I came
> > > > > > across the concepts of real-time
> systems. Back then
> > > arduino was
> > > > > the only
> > > > > > hardware I was having while searching
> for an
> > RTOS to play
> > > with, I came
> > > > > > across RTEMS. RTOS was harder for me
> to grasp
> > but were always
> > > > > > interesting, being a critical part of
> a system,
> > I always
> > > wanted to
> > > > > learn
> > > > > > how they worked from inside. That's
> what bought
> > me to
> > > contributing
> > > > > to RTOS.
> > > > > > I wanted to contribute to core of
> RTEMS, but it
> > was a bit
> > > complex
> > > > > for me
> > > > > > to understand, so I started with driver
> > development for RTEMS.
> > > > > That's where I started too. But don't
> hesitate to
> > pick a
> > > more complex
> > > > > topic if you are interested in it. From
> what I've
> > seen you
> > > can read and
> > > > > understand existing code quite fast
> compared to
> > some other
> > > GSoC students
> > > > > we had. So I would say that you have a
> good chance
> > to manage
> > > complex
> > > > > topics too.
> > > > > Thank you, it's quite good to hear.
> > > > > > After going through some of the
> previous GSOC
> > projects, BSP
> > > > > development
> > > > > > and real-time tracing are what I find
> > interesting. While also
> > > > > converting
> > > > > > the console driver of rpi to FDT based
> one,
> > *Christian
> > > Mauderer
> > > > > > *explained how
> > > > > > FDT worked in FreeBSD and Linux, and RTEMS
> > lacked that
> > > > > infrastructure, I
> > > > > > have no idea of how hard it would it,
> and if I
> > am even
> > > capable of
> > > > > > developing it. But one proposal would
> be to
> > build the FDT
> > > > > infrastructure
> > > > > > similar to FreeBSD or Linux and have the
> > driver's probe
> > > and attach to
> > > > > > the hardware.
> > > > > We start to have more and more FDT based
> BSPs. So
> > it would
> > > be great if
> > > > > our infrastructure would improve. But
> like I said:
> > Don't
> > > hesitate to
> > > > > pick any other topic. Device drivers
> (and similar)
> > are low
> > > hanging fruit
> > > > > where it is easy to get success and it
> isn't very
> > likely to
> > > start long
> > > > > tedious discussions because you only
> touch one BSP.
> > > Therefore I tend to
> > > > > suggest them for GSoC. But GSoC isn't
> limited to that.
> > > > > So if you would like to work at any
> other topic
> > like (for
> > > example)
> > > > > porting a new architecture, hacking on some
> > scheduler, do
> > > something with
> > > > > the dynamic linking support, add stuff
> to the
> > libdebugger,
> > > or basically
> > > > > anything else: Just ask whether someone
> knows a
> > topic in
> > > that area or is
> > > > > interested in mentoring one you suggest.
> Most
> > likely the
> > > mailing list
> > > > > will become quite a bit more active
> again in about
> > a week.
> > > I'll be lurking.
> linking,
> > debugger,
> time and
> > discussed
> ending up in
> > the "long
> > > BSP Projects are only good if they are useful.
> RPI3 might
> > be useful,
> > > although there haven't been a lot of folks
> clamoring for it.
> > > > > Once I finish with the raspberry pi, I will
> try to
> > port RTEMS
> > > for esp32.
> > > > > I have that board,
> > > > > It has quite a lot of features and really good
> > documentation. It is
> > > > > based on xtensa CPU.
> https://devel.rtems.org/wiki/TBR/UserManual/SupportedCPUs and is
> > > under
> > > > > RTEMS potential port.
> > > > Interesting idea. You should post that as a
> project idea
> > for your GSoC
> > > > project. There are quite some points for new
> cores that
> > can make a
> > > port
> > > > very simple or hard as hell. I don't have the
> experience
> > to give a
> > > good
> > > > estimate for that core. But don't worry. I'm
> quite sure
> > that this
> > > can be
> > > > an interesting project.
> > > > Just some random thoughts:
> > > > - It seems that the Xtensa is supported in the
> official
> > GCC since
> > > quite
> > > > some time up to the most recent releases. That's a
> > really good
> > > starting
> > > > point.
> > > > - The core is a commercial IP core. It might
> can get
> > hard to get a
> > > > detailed core documentation. Let's hope that
> there is
> > enough community
> > > > documentation for it.
> > > > - I didn't really find the core in any other
> (buyable)
> > chip but the
> > > > ESP32. Do you know whether it is used
> somewhere else?
> > > > - The ESP32 doesn't have too much RAM. If I've
> seen it
> > right it's
> > > 520kB
> > > > on-chip. We have smaller targets than that but
> it's not
> > really
> > > much. The
> > > > libbsd network stack will most likely never
> run on it.
> > But lwIP should
> > > > work. But I think network stack is something
> that won't
> > be a topic
> > > for a
> > > > first port anyway ;-)
> > > > - The Technical Reference Manual looks
> reasonable detailed:
> https://docs.espressif.com/projects/esp-idf/en/latest/hw-reference/index.html
> > > > - For the low level port you definitively need a
> > hardware debugger
> > > or a
> > > > good simulator. It seems that JTAG access is
> possible
> > using OpenOCD.
> > > > There is even an official guide from the
> manufacturer:
> https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/jtag-debugging/
> > > A new architecture port is a worthwhile GSoC
> Project.
> > There would be a
> > > lot of learning and code generated. However as
> above there
> > is a
> > > question about utility: Will there be more than
> 1 xtensa user?
> > > Historically, DPSs seem to have low demand for
> an RTOS
> > like RTEMS. It
> > > is still a good GSoC project though. One of the
> barriers
> > to a new
> > > architecture however will be testability: is there a
> > simulator that
> > > can be used for development/testing?
> > > For difficulty, the thing to investigate is how
> complex is the
> > > register context, interrupt handling mechanisms,
> memory
> > management,
> > > and on-chip devices (timers, etc.). Also whether
> or not
> > there is a
> > > 2/3-BSD compliant port elsewhere for reusable
> code. The
> > base xtensa
> > > looks straightforward. The ESP32 is an
> interesting board.
> > > > > > > On Dec 28, 2019, at 05:12 ,
> Christian Mauderer
> <mailto:list at c-mauderer.de>> <mailto:list at c-mauderer.de
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
> > > > > > > On 28/12/2019 07:12, Niteesh wrote:
> > > > > > >> On Sat, 28 Dec, 2019, 3:51 AM
> Christian
> > Mauderer,
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
> > > > > > >> On 27/12/2019 19:06, Niteesh
> wrote:
> > > > > > >>> Is there something else that I
> could
> > work on? I am
> > > > > interested in
> > > > > > >> taking
> > > > > > >>> part
> > > > > > >>> GSOC of 2020. And I want to
> learn as
> > much as possible.
> > > > > > >> Do you search tasks specific to
> > raspberry or general
> > > > > ones? Do
> > > > > > you search
> > > > > > >> something for GSoC or just
> to warm up?
> > > > > > >> Anything is fine as long as I
> am learning
> > > something. Since rpi3
> > > > > > is the
> > > > > > >> only hardware I have, I am
> interested in
> > tasks
> > > specific to
> > > > > raspi and
> > > > > > >> general ones which do not
> require any
> > hardware.
> > > > > > > For raspberry I think you could
> continue
> > to get it
> > > running
> > > > > on RPi3. My
> > > > > > > suggestion would be to replace
> the table based
> > > initialization
> > > > > > (which is
> > > > > > > handled by
> console-termios-init.c) with
> > one based on
> > > the fdt
> > > > > that is
> > > > > > > similar to the one in the imx
> BSP. That
> > will allow
> > > to use
> > > > > the same
> > > > > > > binary on RPi2 and RPi3. But
> please do
> > that in an
> > > extra patch
> > > > > > after the
> > > > > > > one that you currently have sent
> to the
> > mailing list.
> > > > > > > Some other raspberry specific
> topics could
> > be the
> > > following.
> > > > > Note that
> > > > > > > this are only suggestions. I
> don't want to
> > force you
> > > to do
> > > > > any of them
> > > > > > > if you don't like them:
> > > > > > > - Documentation how you run an
> application
> > in QEMU /
> > > on real
> > > > > hardware
> > > > > > > for the user manual:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
> > > > > > > (I hope I didn't miss a patch
> that you
> > already sent
> > > > > > > - A configuration for RTEMS
> tester that
> > uses the QEMU or
> > > > > real hardware
> > > > > > > (I think the pi3 allows network
> boot?).
> > This allows
> > > regular
> > > > > test runs
> > > > > > > for this BSP:
> https://docs.rtems.org/branches/master/user/testing/index.html and
> https://docs.rtems.org/branches/master/user/tools/tester.html
> > > > > > > - Chris created a boot image
> generator
> > last year. It
> > > would
> > > > > be great if
> > > > > > > you could add a configuration to
> create
> > raspberry SD
> > > images
> > > > > to it:
> https://docs.rtems.org/branches/master/user/tools/boot-image.html
> > > > > > > - You can pick basically any
> component
> > that isn't
> > > already
> > > > > there and
> > > > > > > integrate it. If you want to
> work with libbsd:
> > > Testing or
> > > > > porting
> > > > > > > Ethernet support could be something.
> > > > > > > - You most likely want to do
> something
> > with RPi in
> > > your GSoC
> > > > > too. So
> > > > > > > maybe some comments ("x is
> already done",
> > "y seems to be
> > > > > still open")
> > > > > > > for the ticket for it would be
> nice too:
> > > > > > > For non raspberry topics: We
> have a lot of
> > open bugs
> > > where
> > > > > everyone is
> > > > > > > happy if they are closed:
> > https://devel.rtems.org/query
> > > > > > > A lot of them might are even out
> of date
> > and just need
> > > > > someone who
> > > > > > reads
> > > > > > > them and asks whether they can
> be closed.
> > > > > > >>> On Fri, Dec 27, 2019 at 5:07 PM
> > Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>>> wrote:
> > > > > > >>> On 27/12/2019 12:20,
> Niteesh wrote:
> > > > > > >>> > I have sent the patch.
> I also sent a
> > > documentation
> > > > > update
> > > > > > >> for the
> > > > > > >>> > quick-start section
> > > > > > >>> > a few months ago. But
> no one took
> > a look at
> > > it. Can you
> > > > > > have a
> > > > > > >>> look at it?
> > > > > > >>> I'll try to have a look
> at it soon.
> https://www.mail-archive.com/devel@rtems.org/msg20965.html
> > > > > > >>> If you don't get any
> responses to a
> > patch
> > > please just
> > > > > send a
> > > > > > >> reminder
> > > > > > >>> one or two weeks later.
> It's quite
> > likely
> > > that the
> > > > > patch just
> > > > > > >> slipped
> > > > > > >>> the attention.
> > > > > > >>> Normally I leave
> documentation
> > patches to our
> > > native
> > > > > speakers.
> > > > > > >> They spot
> > > > > > >>> a lot of errors that I
> won't be
> > able to find.
> > > > > > >>> Can you please send a
> ping for the
> > patch. You
> > > can add
> > > > > me to CC
> > > > > > >> and for
> > > > > > >>> this one I would suggest
> to CC
> > Chris Johns too.
> > > > > > > devel mailing list
> > > > > > > devel at rtems.org
> <mailto:devel at rtems.org> <mailto:devel at rtems.org
> <mailto:devel at rtems.org>>
> > <mailto:devel at rtems.org <mailto:devel at rtems.org>
> <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
> <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>
> <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>>
> > > > > > Peter
> > > > > > Peter Dufault
> > > > > > HD Associates, Inc. Software
> and System
> > Engineering
> > > > > > This email is delivered through
> the public
> > internet using
> > > > > protocols
> > > > > > subject to interception and tampering.
> > > > devel mailing list
