[PATCH] doc/raspberrypi: Added instructions for raspberrypi
G S Niteesh
gsnb.gn at gmail.com
Sun Jan 5 12:46:48 UTC 2020
Added instructions to run examples on raspberrypi.
user/bsps/arm/raspberrypi.rst | 75 ++++++++++++++++++++++++++++++++++-
1 file changed, 74 insertions(+), 1 deletion(-)
diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
index 4ef75bd..653f8a7 100644
--- a/user/bsps/arm/raspberrypi.rst
+++ b/user/bsps/arm/raspberrypi.rst
@@ -5,4 +5,77 @@
raspberrypi
-TODO.
+This BSP support's `raspberrypi 1` and `raspberrypi 2` currently.
+The support for `raspberrypi 3` is work under progress.
+The default bootloader on the raspberrypi which is used to boot raspbian
+or other OS can be also used to boot RTEMS. U-boot can also be used
+but it a personal preferance.
+Setup up SD card
+The raspberrypi's have an unconventional booting mechanism. The GPU
+boots first, initializes itself, runs the bootloader and start the CPU.
+The bootloader looks for a kernel image, by default the kernel images must
+have name of form `kernel*.img` but this can be changed by adding `kernel=<img_name>`
+to config.txt.
+You must provide the required files for the GPU to proceed. These files
+can be downloded from this link https://github.com/raspberrypi/firmware/tree/master/boot
+.You can remove the kernel*.img if you want, but don't touch the other files.
+Copy these files in to a SD card with FAT filesystem.
+Kernel image
+We will be running the hello.exe on raspberrypi 2. Other examples can be
+found under testsuites.
+To create the kernel image:
+.. code-block:: none
+ arm-rtems5-objcopy -Obinary hello.exe kernel.img
+Copy the kernel image to the SD card.
+Make sure you have these lines below in your config.txt.
+ enable-uart=1
+ kernel_address=0x200000
+ kernel=kernel.img
+Testing
+Qemu along with GDB can be used for debugging, but it only supports
+``raspberrpi2`` and emulation is also incomplete. So some of the features
+might not work as expected.
+Make sure you have latest version of qemu, older ones don't support
+raspberrypi.
+ qemu-system-arm -M raspi2 -m 1G -kernel hello.exe -serial mon:stdio -nographic -S -s
+This starts qemu and creates a socket at port ``1234`` for GDB to connect.
+In a new terminal, run GDB using
+ arm-rtems5-gdb hello.exe
+ tar remote:1234
+ load
+This will connect GDB to qemu and loads the application.
+**Note**: Add ``set scheduler-locking on`` in GDB if you have any issues running
+the examples.
2.17.1
