[PATCH v2] bsp/raspberrypi: Updated the console API.
Christian Mauderer list at c-mauderer.de
Tue Jan 7 18:46:21 UTC 2020
On 07/01/2020 18:45, Niteesh wrote:
> You said that the FB was not working, was it because of this bug?
> or else I want to take a look at it.
No, that is a different problem. So if you want feel free to take a look.
The first thing I noted is that the command line is not parsed
correctly. The current console select code searches for a "--console="
but there is only a "console=" in the commandline.txt. You took that
logic over 1:1 from the old console.
> On Tue, Jan 7, 2020 at 11:03 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
>     Great, thank you it wouldn't have been possible without your help
>     and support.
>     And thanks for patiently answering my questions :)
Thanks for beeing patient enough to rework the patch again and again.
>     On Tue, Jan 7, 2020 at 10:58 PM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>         Pushed with a minor modification: Due to the header reorder it was
>         necessary to include one extra header in bsp/fbcons.h. But that
>         has been
>         a hidden bug anyway.
>         On 04/01/2020 20:50, G S Niteesh wrote:
>         > Replaces the legacy termios API with new termios API (#3034)
>         > Replaces the custom PL011 serial driver with RTEMS arm-pl011.
>         > Update #3034
>         >  bsps/arm/raspberrypi/console/console-config.c | 143
>         >  bsps/arm/raspberrypi/console/console_select.c | 114 ------------
>         >  bsps/arm/raspberrypi/console/fbcons.c         |  78 ++++----
>         >  bsps/arm/raspberrypi/console/usart.c          | 167
>         >  bsps/arm/raspberrypi/include/bsp.h            |   2 +
>         >  bsps/arm/raspberrypi/include/bsp/fbcons.h     |  17 +-
>         >  .../arm/raspberrypi/include/bsp/raspberrypi.h |  54 ++----
>         >  bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
>         >  bsps/arm/raspberrypi/start/bspstart.c         |  15 ++
>         >  c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   6 +-
>         >  10 files changed, 197 insertions(+), 404 deletions(-)
>         >  delete mode 100644 bsps/arm/raspberrypi/console/console_select.c
>         >  delete mode 100644 bsps/arm/raspberrypi/console/usart.c
>         > diff --git a/bsps/arm/raspberrypi/console/console-config.c
>         b/bsps/arm/raspberrypi/console/console-config.c
>         > index d2186c918b..48c4c6a3ec 100644
>         > --- a/bsps/arm/raspberrypi/console/console-config.c
>         > +++ b/bsps/arm/raspberrypi/console/console-config.c
>         > @@ -19,50 +19,133 @@
>         >  #include <rtems/bspIo.h>
>         > +#include <rtems/console.h>
>         > +#include <rtems/sysinit.h>
>         >  #include <libchip/serial.h>
>         > +#include <libfdt.h>
>         >  #include <bspopts.h>
>         > -#include <bsp/irq.h>
>         >  #include <bsp/usart.h>
>         >  #include <bsp/raspberrypi.h>
>         >  #include <bsp/fbcons.h>
>         > +#include <bsp.h>
>         > +#include <bsp/arm-pl011.h>
>         > +#include <bsp/console-termios.h>
>         > +#include <bsp/fdt.h>
>         > +#include <bsp/fatal.h>
>         > -console_tbl Console_Configuration_Ports [] = {
>         > -      .sDeviceName = "/dev/ttyS0",
>         > -      .deviceType = SERIAL_CUSTOM,
>         > -      .pDeviceFns = &bcm2835_usart_fns,
>         > -      .deviceProbe = NULL,
>         > -      .pDeviceFlow = NULL,
>         > -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>         > -      .ulCtrlPort2 = 0,
>         > -      .ulClock = USART0_DEFAULT_BAUD,
>         > -      .ulIntVector = BCM2835_IRQ_ID_UART
>         > -      .sDeviceName ="/dev/fbcons",
>         > -      .pDeviceFns = &fbcons_fns,
>         > -      .deviceProbe = fbcons_probe,
>         > -#define PORT_COUNT \
>         > -  (sizeof(Console_Configuration_Ports) \
>         > -    / sizeof(Console_Configuration_Ports [0]))
>         > -unsigned long Console_Configuration_Count = PORT_COUNT;
>         > +#define UART0     "/dev/ttyS0"
>         > +#define FBCONS    "/dev/fbcons"
>         > +arm_pl011_context pl011_context;
>         > +rpi_fb_context fb_context;
>         > +static void output_char_serial(char c)
>         > +  arm_pl011_write_polled(&pl011_context.base, c);
>         > +void output_char_fb(char c)
>         > +  fbcons_write_polled(&fb_context.base, c);
>         > +static void init_ctx_arm_pl011(
>         > +  const void *fdt,
>         > +  int node
>         > +  arm_pl011_context *ctx = &pl011_context;
>         > +  rtems_termios_device_context_initialize(&ctx->base, "UART");
>         > +  ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
>         > +static void register_fb( void )
>         > +  if (fbcons_probe(&fb_context.base) == true) {
>         > +    rtems_termios_device_install(
>         > +      FBCONS,
>         > +      &fbcons_fns,
>         > +      NULL,
>         > +      &fb_context.base);
>         > +static void console_select( void )
>         > +  const char *opt;
>         > +  opt = rpi_cmdline_get_arg("--console=");
>         > +  if ( opt ) {
>         > +    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) ==
>         0 ) {
>         > +      if ( rpi_video_is_initialized() > 0 ) {
>         > +        BSP_output_char = output_char_fb;
>         > +        link(FBCONS, CONSOLE_DEVICE_NAME);
>         > +        return ;
>         > +  BSP_output_char = output_char_serial;
>         > +  link(UART0, CONSOLE_DEVICE_NAME);
>         > +static void uart_probe(void)
>         > +  static bool initialized = false;
>         > +  const void *fdt;
>         > +  int node;
>         > +  if ( initialized ) {
>         > +    return ;
>         > +  fdt = bsp_fdt_get();
>         > +  node = fdt_node_offset_by_compatible(fdt, -1,
>         "brcm,bcm2835-pl011");
>         > +  init_ctx_arm_pl011(fdt, node);
>         > +  initialized = true;
>         >  static void output_char(char c)
>         > -  const console_fns *con =
>         > -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>         > +  uart_probe();
>         > +  output_char_serial(c);
>         > +rtems_status_code console_initialize(
>         > +  rtems_device_major_number major,
>         > +  rtems_device_minor_number minor,
>         > +  void *arg
>         > +  rtems_termios_initialize();
>         > -  con->deviceWritePolled((int) Console_Port_Minor, c);
>         > +  uart_probe();
>         > +    UART0,
>         > +    &arm_pl011_fns,
>         > +    NULL,
>         > +    &pl011_context.base
>         > +  register_fb();
>         > +  console_select();
>         > +  return RTEMS_SUCCESSFUL;
>         >  BSP_output_char_function_type BSP_output_char = output_char;
>         >  BSP_polling_getchar_function_type BSP_poll_char = NULL;
>         > +RTEMS_SYSINIT_ITEM(
>         > +  uart_probe,
>         > +  RTEMS_SYSINIT_BSP_START,
>         > +  RTEMS_SYSINIT_ORDER_LAST
>         > \ No newline at end of file
>         > diff --git a/bsps/arm/raspberrypi/console/console_select.c
>         b/bsps/arm/raspberrypi/console/console_select.c
>         > deleted file mode 100644
>         > index bd246ca868..0000000000
>         > --- a/bsps/arm/raspberrypi/console/console_select.c
>         > +++ /dev/null
>         > @@ -1,114 +0,0 @@
>         > - * @file
>         > - * @ingroup raspberrypi_console
>         > - * @brief console select
>         > - * Copyright (c) 2015 Yang Qiao
>         > - *  The license and distribution terms for this file may be
>         > - *  found in the file LICENSE in this distribution or at
>         > - *  http://www.rtems.org/license/LICENSE
>         > -#include <bsp.h>
>         > -#include <bsp/fatal.h>
>         > -#include <rtems/libio.h>
>         > -#include <stdlib.h>
>         > -#include <string.h>
>         > -#include <assert.h>
>         > -#include <termios.h>
>         > -#include <rtems/termiostypes.h>
>         > -#include <libchip/serial.h>
>         > -#include "../../shared/dev/serial/legacy-console.h"
>         > -#include <bsp/rpi-fb.h>
>         > -rtems_device_minor_number BSPPrintkPort = 0;
>         > - * Method to return true if the device associated with the
>         > - * minor number probs available.
>         > -static bool bsp_Is_Available( rtems_device_minor_number minor )
>         > -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>         > -   * First perform the configuration dependent probe, then the
>         > -   * device dependent probe
>         > -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>         > -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>         > -    return true;
>         > -  return false;
>         > - * Method to return the first available device.
>         > -static rtems_device_minor_number bsp_First_Available_Device(
>         void )
>         > -  rtems_device_minor_number minor;
>         > -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>         > -      return minor;
>         > -   *  Error No devices were found.  We will want to bail here.
>         > -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>         > -void bsp_console_select( void )
>         > -   *  Reset Console_Port_Minor and
>         > -   *  BSPPrintkPort here if desired.
>         > -   *  This default version allows the bsp to set these
>         > -   *  values at creation and will not touch them again
>         > -   *  unless the selected port number is not available.
>         > -  const char *opt;
>         > -  Console_Port_Minor = BSP_CONSOLE_UART0;
>         > -  BSPPrintkPort = BSP_CONSOLE_UART0;
>         > -  opt = rpi_cmdline_get_arg( "--console=" );
>         > -  if ( opt ) {
>         > -    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) ==
>         0 ) {
>         > -      if ( rpi_video_is_initialized() > 0 ) {
>         > -        Console_Port_Minor = BSP_CONSOLE_FB;
>         > -        BSPPrintkPort = BSP_CONSOLE_FB;
>         > -   * If the device that was selected isn't available then
>         > -   * let the user know and select the first available device.
>         > -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>         > -    Console_Port_Minor = bsp_First_Available_Device();
>         > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>         b/bsps/arm/raspberrypi/console/fbcons.c
>         > index 3669ba458d..0c0a5087ce 100644
>         > --- a/bsps/arm/raspberrypi/console/fbcons.c
>         > +++ b/bsps/arm/raspberrypi/console/fbcons.c
>         > @@ -18,6 +18,7 @@
>         >  #include <rtems.h>
>         > +#include <rtems/termiostypes.h>
>         >  #include <stdlib.h>
>         > @@ -29,15 +30,6 @@
>         >  #include <bsp/vc.h>
>         > - *  fbcons_init
>         > - *  This function initializes the fb console to a quiecsent
>         state.
>         > -static void fbcons_init( int minor )
>         >   *  fbcons_open
>         > @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
>         >   *  Default state is 9600 baud, 8 bits, No parity, and 1 stop
>         bit.
>         > -static int fbcons_open(
>         > -  int   major,
>         > -  int   minor,
>         > -  void *arg
>         > +static bool fbcons_open(
>         > +  struct rtems_termios_tty *tty,
>         > +  rtems_termios_device_context *base,
>         > +  struct termios *term,
>         > +  rtems_libio_open_close_args_t *args
>         > -  return RTEMS_SUCCESSFUL;
>         > +  return true;
>         > @@ -59,13 +52,12 @@ static int fbcons_open(
>         >   *  This function shuts down the requested port.
>         > -static int fbcons_close(
>         > -  int   major,
>         > -  int   minor,
>         > -  void *arg
>         > +static void fbcons_close(
>         > -  return ( RTEMS_SUCCESSFUL );
>         > @@ -73,8 +65,8 @@ static int fbcons_close(
>         >   *  This routine polls out the requested character.
>         > -static void fbcons_write_polled(
>         > -  int  minor,
>         > +void fbcons_write_polled(
>         >    char c
>         > @@ -90,8 +82,8 @@ static void fbcons_write_polled(
>         >   *  Console Termios output entry point when using polled output.
>         > -static ssize_t fbcons_write_support_polled(
>         > -  int         minor,
>         > +static void fbcons_write_support_polled(
>         >    const char *buf,
>         >    size_t      len
>         > @@ -102,14 +94,9 @@ static ssize_t fbcons_write_support_polled(
>         >     * poll each byte in the string out of the port.
>         >    while ( nwrite < len ) {
>         > -    fbcons_write_polled( minor, *buf++ );
>         > +    fbcons_write_polled( base, *buf++ );
>         >      nwrite++;
>         > -   * return the number of bytes written.
>         > -  return nwrite;
>         > @@ -117,7 +104,9 @@ static ssize_t fbcons_write_support_polled(
>         >   *  Console Termios polling input entry point.
>         > -static int fbcons_inbyte_nonblocking_polled( int minor )
>         > +static int fbcons_inbyte_nonblocking_polled(
>         >    // if( rtems_kbpoll() ) {
>         >    //   int c = getch();
>         > @@ -133,15 +122,17 @@ static int
>         >   *  This function sets the UART channel to reflect the
>         requested termios
>         >   *  port settings.
>         > -static int fbcons_set_attributes(
>         > -  int                   minor,
>         > +static bool fbcons_set_attributes(
>         >    const struct termios *t
>         > -  return 0;
>         > +  return true;
>         > -bool fbcons_probe( int minor )
>         > +bool fbcons_probe(
>         > +  rtems_termios_device_context *context
>         >    // rtems_status_code status;
>         >    static bool firstTime = true;
>         > @@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
>         >    return ret;
>         > -const console_fns fbcons_fns =
>         > +const rtems_termios_device_handler fbcons_fns =
>         > -  .deviceProbe = libchip_serial_default_probe,     /*
>         deviceProbe */
>         > -  .deviceFirstOpen = fbcons_open,                 /*
>         deviceFirstOpen */
>         > -  .deviceLastClose = fbcons_close,                /*
>         deviceLastClose */
>         > -  .deviceRead = fbcons_inbyte_nonblocking_polled, /*
>         deviceRead */
>         > -  .deviceWrite = fbcons_write_support_polled,     /*
>         deviceWrite */
>         > -  .deviceInitialize = fbcons_init,                /*
>         deviceInitialize */
>         > -  .deviceWritePolled = fbcons_write_polled,       /*
>         deviceWritePolled */
>         > -  .deviceSetAttributes = fbcons_set_attributes,   /*
>         deviceSetAttributes */
>         > -  .deviceOutputUsesInterrupts = FALSE,           /*
>         deviceOutputUsesInterrupts*/
>         > +  .first_open = fbcons_open,
>         > +  .last_close = fbcons_close,
>         > +  .poll_read = fbcons_inbyte_nonblocking_polled,
>         > +  .write = fbcons_write_support_polled,
>         > +  .set_attributes = fbcons_set_attributes,
>         > +  .mode = TERMIOS_POLLED
>         > diff --git a/bsps/arm/raspberrypi/console/usart.c
>         b/bsps/arm/raspberrypi/console/usart.c
>         > index 25fb523621..0000000000
>         > --- a/bsps/arm/raspberrypi/console/usart.c
>         > +++ /dev/null
>         > @@ -1,167 +0,0 @@
>         > - * @file
>         > - * @ingroup raspberrypi_usart
>         > - * @brief USART support.
>         > - * Copyright (c) 2013 Alan Cudmore
>         > -#include <libchip/sersupp.h>
>         > -#include <bsp.h>
>         > -#include <bsp/usart.h>
>         > -#include <bsp/raspberrypi.h>
>         > -#include <rtems/bspIo.h>
>         > -static void usart_delay(uint32_t n)
>         > - volatile uint32_t i = 0;
>         > - for(i = 0; i < n; i++)
>         > -#if 0
>         > - *  These will be useful when the driver supports interrupt
>         driven IO.
>         > -static rtems_vector_number usart_get_irq_number(const
>         console_tbl *ct)
>         > -  return ct->ulIntVector;
>         > -static uint32_t usart_get_baud(const console_tbl *ct)
>         > -  return ct->ulClock;
>         > -#endif
>         > -static void usart_set_baud(int minor, int baud)
>         > -  * Nothing for now
>         > - return;
>         > -static void usart_initialize(int minor)
>         > -  unsigned int gpio_reg;
>         > -  ** Program GPIO pins for UART 0
>         > -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>         > -  gpio_reg &= ~(7<<12);    /* gpio14 */
>         > -  gpio_reg |=  (4<<12);    /* alt0   */
>         > -  gpio_reg &= ~(7<<15);    /* gpio15 */
>         > -  gpio_reg |=  (4<<15);    /* alt0   */
>         > -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>         > -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>         > -  usart_delay(150);
>         > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>         > -  usart_delay(150);
>         > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>         > -  ** Init the PL011 UART
>         > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>         > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>         > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>         > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>         > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>         > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>         > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>         > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>         > -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>         > -  usart_set_baud(minor, 115000);
>         > -static int usart_first_open(int major, int minor, void *arg)
>         > -  rtems_libio_open_close_args_t *oc =
>         (rtems_libio_open_close_args_t *) arg;
>         > -  struct rtems_termios_tty *tty = (struct rtems_termios_tty
>         *) oc->iop->data1;
>         > -  const console_tbl *ct = Console_Port_Tbl [minor];
>         > -  console_data *cd = &Console_Port_Data [minor];
>         > -  cd->termios_data = tty;
>         > -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>         > -  return 0;
>         > -static int usart_last_close(int major, int minor, void *arg)
>         > -  return 0;
>         > -static int usart_read_polled(int minor)
>         > -  if (minor == 0) {
>         > -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
>         BCM2835_UART0_FR_RXFE) == 0) {
>         > -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>         > -    } else {
>         > -      return -1;
>         > -  } else {
>         > -    printk("Unknown console minor number: %d\n", minor);
>         > -    return -1;
>         > -static void usart_write_polled(int minor, char c)
>         > -   while (1) {
>         > -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>         BCM2835_UART0_FR_TXFF) == 0)
>         > -       break;
>         > -   BCM2835_REG(BCM2835_UART0_DR) = c;
>         > -static ssize_t usart_write_support_polled(
>         > -  int minor,
>         > -  const char *s,
>         > -  size_t n
>         > -  ssize_t i = 0;
>         > -  for (i = 0; i < n; ++i) {
>         > -    usart_write_polled(minor, s [i]);
>         > -  return n;
>         > -static int usart_set_attributes(int minor, const struct
>         termios *term)
>         > -  return -1;
>         > -const console_fns bcm2835_usart_fns = {
>         > -  .deviceFirstOpen = usart_first_open,
>         > -  .deviceLastClose = usart_last_close,
>         > -  .deviceRead = usart_read_polled,
>         > -  .deviceWrite = usart_write_support_polled,
>         > -  .deviceInitialize = usart_initialize,
>         > -  .deviceWritePolled = usart_write_polled,
>         > -  .deviceSetAttributes = usart_set_attributes,
>         > -  .deviceOutputUsesInterrupts = false
>         > diff --git a/bsps/arm/raspberrypi/include/bsp.h
>         b/bsps/arm/raspberrypi/include/bsp.h
>         > index b81d19cd76..190dd16184 100644
>         > --- a/bsps/arm/raspberrypi/include/bsp.h
>         > +++ b/bsps/arm/raspberrypi/include/bsp.h
>         > @@ -54,6 +54,8 @@ extern "C" {
>         >  #define BSP_CONSOLE_UART0   0
>         >  #define BSP_CONSOLE_FB      1
>         > +void *raspberrypi_get_reg_of_node(const void *fdt, int node);
>         >  void rpi_init_cmdline(void);
>         >  const char *rpi_cmdline_get_cached(void);
>         >  const char *rpi_cmdline_get_raw(void);
>         > diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         > index d0e126699a..9de75ee5a4 100644
>         > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         > @@ -33,12 +33,25 @@ extern "C" {
>         >  #define FB_CONSOLE 0x50492835
>         > -bool fbcons_probe( int minor );
>         > +bool fbcons_probe(
>         > +  char c
>         > +void output_char_fb(char c);
>         > +typedef struct {
>         > +    rtems_termios_device_context base;
>         > +} rpi_fb_context ;
>         >   * Driver function table
>         > -extern const console_fns fbcons_fns;
>         > +extern const rtems_termios_device_handler fbcons_fns;
>         >  #ifdef __cplusplus
>         > diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         > index 40c80cf408..eeb48c42f1 100644
>         > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         > @@ -53,12 +53,24 @@
>         >  #if (BSP_IS_RPI2 == 1)
>         > -   #define RPI_PERIPHERAL_BASE      0x3F000000
>         > +  #define RPI_PERIPHERAL_BASE    0x3F000000
>         > +  #define BASE_OFFSET            0X3F000000
>         >  #else
>         > -   #define RPI_PERIPHERAL_BASE      0x20000000
>         > +  #define RPI_PERIPHERAL_BASE    0x20000000
>         > +  #define BASE_OFFSET            0X5E000000
>         >  #endif
>         > -#define RPI_PERIPHERAL_SIZE         0x01000000
>         > +#define RPI_PERIPHERAL_SIZE      0x01000000
>         > + * @name Bus to Physical address translation
>         > + *       Macro.
>         > +#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
>         >   * @name Internal ARM Timer Registers
>         > @@ -184,42 +196,6 @@
>         > - * @name UART 0 (PL011) Registers
>         > -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
>         > -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
>         > -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
>         > -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
>         > -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
>         > -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
>         > -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
>         > -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
>         > -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
>         > -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
>         > -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
>         > -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
>         > -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
>         > -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
>         > -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
>         > -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
>         > -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
>         > -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
>         > -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
>         > -#define BCM2835_UART0_MIS_RX    0x10
>         > -#define BCM2835_UART0_MIS_TX    0x20
>         > -#define BCM2835_UART0_IMSC_RX   0x10
>         > -#define BCM2835_UART0_IMSC_TX   0x20
>         > -#define BCM2835_UART0_FR_RXFE   0x10
>         > -#define BCM2835_UART0_FR_TXFF   0x20
>         > -#define BCM2835_UART0_ICR_RX    0x10
>         > -#define BCM2835_UART0_ICR_TX    0x20
>         > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>         b/bsps/arm/raspberrypi/include/bsp/usart.h
>         > index d3e710c5e9..abbf53626c 100644
>         > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>         > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>         > @@ -32,9 +32,8 @@
>         >  extern "C" {
>         >  #endif /* __cplusplus */
>         > -#define USART0_DEFAULT_BAUD 115000
>         > -extern const console_fns bcm2835_usart_fns;
>         > +#define PL011_DEFAULT_BAUD 115000
>         > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>         >  #ifdef __cplusplus
>         > diff --git a/bsps/arm/raspberrypi/start/bspstart.c
>         b/bsps/arm/raspberrypi/start/bspstart.c
>         > index 6ff286f840..49896e4d47 100644
>         > --- a/bsps/arm/raspberrypi/start/bspstart.c
>         > +++ b/bsps/arm/raspberrypi/start/bspstart.c
>         > @@ -24,6 +24,8 @@
>         >  #include <bsp/vc.h>
>         >  static const struct {
>         >      uint32_t code;
>         >      const char* label;
>         > @@ -86,6 +88,19 @@ static const char* rpi_mem[] =
>         >  #define NUMOF(_s) (sizeof(_s) / sizeof(_s[0]))
>         > +  int len;
>         > +  const uint32_t *val;
>         > +  val = fdt_getprop(fdt, node, "reg", &len);
>         > +  if (val == NULL || len < 4) {
>         > +    return NULL;
>         > +  return (BUS_TO_PHY((void *) fdt32_to_cpu(val[0])));
>         >  void bsp_start(void)
>         >      bcm2835_get_board_spec_entries spec = { 0 };
>         > diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         > index 77aa360977..57562c10c7 100644
>         > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         > @@ -64,11 +64,9 @@ librtemsbsp_a_SOURCES +=
>         ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>         ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>         >  # Console
>         > -librtemsbsp_a_SOURCES +=
>         ../../../../../../bsps/shared/dev/serial/legacy-console.c
>         ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>         > +librtemsbsp_a_SOURCES +=
>         ../../../../../../bsps/shared/dev/serial/console-termios.c
>         ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>         ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>         ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>         ../../../../../../bsps/arm/raspberrypi/console/usart.c
>         ../../../../../../bsps/arm/raspberrypi/console/fb.c
>         ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>         ../../../../../../bsps/arm/raspberrypi/console/outch.c
