[PATCH v2] doc/raspberrypi: Added instructions for raspberrypi
Mon Jan 6 19:29:59 UTC 2020
On Mon, Jan 6, 2020 at 11:25 AM Niteesh <gsnb.gn at gmail.com> wrote:
> Do you want to add a build section or just add in a statement that states "it was built
> using xx version of RSB"?
Just a simple statement. Don't even  need to mention a specific
version, if they use RSB to build QEMU it should just work, right?
> On Mon, Jan 6, 2020 at 11:51 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Jan 6, 2020 at 2:47 AM Christian Mauderer <list at c-mauderer.de> wrote:
>> > Looks a lot better.
>> > On 05/01/2020 20:19, G S Niteesh wrote:
>> > > Added instructions to run examples on raspberrypi.
>> > >  user/bsps/arm/raspberrypi.rst | 74 ++++++++++++++++++++++++++++++++++-
>> > >  1 file changed, 73 insertions(+), 1 deletion(-)
>> > > diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
>> > > index 4ef75bd..7eccca5 100644
>> > > --- a/user/bsps/arm/raspberrypi.rst
>> > > +++ b/user/bsps/arm/raspberrypi.rst
>> > > @@ -5,4 +5,76 @@
>> > >  raspberrypi
>> > > -TODO.
>> > > +This BSP supports `Raspberry Pi 1` and `Raspberry Pi 2` currently.
>> > > +The support for `Raspberry Pi 3` is work under progress.
>> > > +The default bootloader on the raspberrypi which is used to boot raspbian
>> > raspberrypi -> Raspberry Pi
>> > raspbian -> Raspbian
>> > > +or other OS can be also used to boot RTEMS. U-boot can also be used.
>> > > +Setup SD card
>> > > +The Raspberry Pis have an unconventional booting mechanism. The GPU
>> > > +boots first, initializes itself, runs the bootloader and starts the CPU.
>> > > +The bootloader looks for a kernel image, by default the kernel images must
>> > > +have a name of the form `kernel*.img` but this can be changed by adding
>> > Please highlight all files in the same way. Other BSPs use the following
>> > syntax:
>> >     The ``ticker.exe`` elf file must be translated ...
>> > So here it is:
>> > `kernel*.img` -> ``kernel*.img``
>> > > +`kernel=<img_name>` to config.txt.
>> > config.txt -> ``config.txt``
>> > > +You must provide the required files for the GPU to proceed. These files
>> > > +can be downloaded from this
>> > > +`link <https://github.com/raspberrypi/firmware/tree/master/boot>`_.
>> > I would suggest:
>> > ... can be downloaded from
>> > `the Raspberry Pi Firmware Repository
>> > I think you shouldn't break links so if this is too long you can
>> > exceptionally break the 80 character rule. It's done for other links too.
>> > > +You can remove the kernel*.img if you want, but don't touch the other files.
>> > kernel*.img -> ``kernel*.img``
>> > > +Copy these files in to a SD card with FAT filesystem.
>> > > +Kernel image
>> > > +The following steps show how to run hello.exe on a Raspberry Pi 2.
>> > hello.exe -> ``hello.exe``
>> > > +The same instructions can be applied to Raspberry Pi 1 also.
>> > > +Other executables can be processed in a similar way.
>> > > +To create the kernel image:
>> > > +.. code-block:: none
>> > > +     arm-rtems5-objcopy -Obinary hello.exe kernel.img
>> > > +Copy the kernel image to the SD card.
>> > > +Make sure you have these lines below in your config.txt.
>> > > +     enable-uart=1
>> > > +     kernel_address=0x200000
>> > > +     kernel=kernel.img
>> > > +Testing
>> > Maybe change that chapter to "Emulation" or "Testing using QEMU". When
>> > reading I had expected a hardware setup in this chapter after the
>> > SD-card has been prepared in the previous one.
>> > > +Qemu along with GDB can be used for debugging, but it only supports
>> > Please always use the capitalization that the project uses. In this case:
>> > Qemu -> QEMU
>> > > +``Raspberry Pi 2`` and the emulation is also incomplete. So some of the
>> > Again: One formatting for one phrase. So that would be:
>> > ``Raspberry Pi 2`` -> Raspberry Pi 2
>> > > +features might not work as expected.
>> > > +Make sure you have latest version of qemu, because older ones don't support
>> > qemu -> QEMU
>> My only other comment is if this version is built by RSB already it is
>> worth mentioning here.
>> > > +Raspberry Pi.
>> > > +     qemu-system-arm -M raspi2 -m 1G -kernel hello.exe -serial mon:stdio -nographic -S -s
>> > > +This starts qemu and creates a socket at port ``localhost:1234`` for GDB to
>> > qemu -> QEMU
>> > > +connect.
>> > > +In a new terminal, run GDB using
>> > > +     arm-rtems5-gdb hello.exe
>> > > +     tar remote:1234
>> > > +     load
>> > > +This will connect GDB to qemu and load the application.
>> > qemu -> QEMU
>> > > +**Note**: Add ``set scheduler-locking on`` in GDB if you have any issues
>> > > +running the examples.
>> > > \ No newline at end of file
