[PATCH v2] doc/raspberrypi: Added instructions for raspberrypi
Niteesh
gsnb.gn at gmail.com
Tue Jan 7 17:42:14 UTC 2020
I didn't use the QEMU build from RSB, I built it from the source directly
for another project
I'll try QEMU from RSB, and will also add instructions for it in a couple
of days.
On Tue, Jan 7, 2020 at 1:00 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Jan 6, 2020 at 11:25 AM Niteesh <gsnb.gn at gmail.com> wrote:
> > Do you want to add a build section or just add in a statement that
> states "it was built
> > using xx version of RSB"?
> Just a simple statement. Don't even need to mention a specific
> version, if they use RSB to build QEMU it should just work, right?
> > On Mon, Jan 6, 2020 at 11:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Mon, Jan 6, 2020 at 2:47 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
> >> > Looks a lot better.
> >> > On 05/01/2020 20:19, G S Niteesh wrote:
> >> > > Added instructions to run examples on raspberrypi.
> >> > > user/bsps/arm/raspberrypi.rst | 74
> >> > > 1 file changed, 73 insertions(+), 1 deletion(-)
> >> > > diff --git a/user/bsps/arm/raspberrypi.rst
> b/user/bsps/arm/raspberrypi.rst
> >> > > index 4ef75bd..7eccca5 100644
> >> > > --- a/user/bsps/arm/raspberrypi.rst
> >> > > +++ b/user/bsps/arm/raspberrypi.rst
> >> > > @@ -5,4 +5,76 @@
> >> > > raspberrypi
> >> > > -TODO.
> >> > > +This BSP supports `Raspberry Pi 1` and `Raspberry Pi 2` currently.
> >> > > +The support for `Raspberry Pi 3` is work under progress.
> >> > > +The default bootloader on the raspberrypi which is used to boot
> raspbian
> >> > raspberrypi -> Raspberry Pi
> >> > raspbian -> Raspbian
> >> > > +or other OS can be also used to boot RTEMS. U-boot can also be
> used.
> >> > > +Setup SD card
> >> > > +The Raspberry Pis have an unconventional booting mechanism. The GPU
> >> > > +boots first, initializes itself, runs the bootloader and starts
> the CPU.
> >> > > +The bootloader looks for a kernel image, by default the kernel
> images must
> >> > > +have a name of the form `kernel*.img` but this can be changed by
> adding
> >> > Please highlight all files in the same way. Other BSPs use the
> following
> >> > syntax:
> >> > The ``ticker.exe`` elf file must be translated ...
> >> > So here it is:
> >> > `kernel*.img` -> ``kernel*.img``
> >> > > +`kernel=<img_name>` to config.txt.
> >> > config.txt -> ``config.txt``
> >> > > +You must provide the required files for the GPU to proceed. These
> files
> >> > > +can be downloaded from this
> >> > > +`link <https://github.com/raspberrypi/firmware/tree/master/boot
> >`_.
> >> > I would suggest:
> >> > ... can be downloaded from
> >> > `the Raspberry Pi Firmware Repository
> >> > <https://github.com/raspberrypi/firmware/tree/master/boot>`_.
> >> > I think you shouldn't break links so if this is too long you can
> >> > exceptionally break the 80 character rule. It's done for other links
> too.
> >> > > +You can remove the kernel*.img if you want, but don't touch the
> other files.
> >> > kernel*.img -> ``kernel*.img``
> >> > > +Copy these files in to a SD card with FAT filesystem.
> >> > > +Kernel image
> >> > > +The following steps show how to run hello.exe on a Raspberry Pi 2.
> >> > hello.exe -> ``hello.exe``
> >> > > +The same instructions can be applied to Raspberry Pi 1 also.
> >> > > +Other executables can be processed in a similar way.
> >> > > +To create the kernel image:
> >> > > +.. code-block:: none
> >> > > + arm-rtems5-objcopy -Obinary hello.exe kernel.img
> >> > > +Copy the kernel image to the SD card.
> >> > > +Make sure you have these lines below in your config.txt.
> >> > > + enable-uart=1
> >> > > + kernel_address=0x200000
> >> > > + kernel=kernel.img
> >> > > +Testing
> >> > Maybe change that chapter to "Emulation" or "Testing using QEMU". When
> >> > reading I had expected a hardware setup in this chapter after the
> >> > SD-card has been prepared in the previous one.
> >> > > +Qemu along with GDB can be used for debugging, but it only supports
> >> > Please always use the capitalization that the project uses. In this
> case:
> >> > Qemu -> QEMU
> >> > > +``Raspberry Pi 2`` and the emulation is also incomplete. So some
> of the
> >> > Again: One formatting for one phrase. So that would be:
> >> > ``Raspberry Pi 2`` -> Raspberry Pi 2
> >> > > +features might not work as expected.
> >> > > +Make sure you have latest version of qemu, because older ones
> don't support
> >> > qemu -> QEMU
> >> My only other comment is if this version is built by RSB already it is
> >> worth mentioning here.
> >> > > +Raspberry Pi.
> >> > > + qemu-system-arm -M raspi2 -m 1G -kernel hello.exe -serial
> mon:stdio -nographic -S -s
> >> > > +This starts qemu and creates a socket at port ``localhost:1234``
> for GDB to
> >> > qemu -> QEMU
> >> > > +connect.
> >> > > +In a new terminal, run GDB using
> >> > > + arm-rtems5-gdb hello.exe
> >> > > + tar remote:1234
> >> > > + load
> >> > > +This will connect GDB to qemu and load the application.
> >> > qemu -> QEMU
> >> > > +**Note**: Add ``set scheduler-locking on`` in GDB if you have any
> issues
> >> > > +running the examples.
> >> > > \ No newline at end of file
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200107/3806749f/attachment.html>
