Raspberrypi3: AUX Uart driver
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 14 08:27:46 UTC 2020
On 13/01/2020 19:04, Niteesh wrote:
> The ns16550_context already has a field named baud_divisor, so if the
> user passes
> value for it, then we can skip the GetBaudDivisor function and use that
> value instead.
> Is this approach okay?
Is the driver still able to handle different baud rates with this? Does
the ioctl call for setting the baudrate work?
Best regards
Christian
> On Mon, Jan 13, 2020 at 3:46 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
>     On Mon, Jan 13, 2020 at 1:38 PM Christian Mauderer
>     <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>> wrote:
>         On 12/01/2020 21:26, Niteesh wrote:
>         > On Sun, Jan 12, 2020 at 11:42 PM Christian Mauderer
>         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>         >     Hello Niteesh,
>         >     On 12/01/2020 16:06, Niteesh wrote:
>         >     > The only issue, I faced while using this driver is the
>         baud divisor is
>         >     > calculated
>         >     > by CLOCK_FREQ/(BAUD_RATE * 16) (*ns16550-context.c:68)*
>         >     > but it should BAUD_DIV = (CLOCK_FREQ/(8 * BAUD_RATE)) -
>         1, for Rpi3.
>         >     > For testing, I assigned the baud divisor to 270 (115200
>         bits/s) in
>         >     > ns16550-context.c,
>         >     > and everything works fine.
>         >     Sounds great. In NS16550_GetBaudDivisor there is already a
>         case where
>         >     the baudDivisor is calculated differently (depending on
>         >     ctx->has_precision_clock_synthesizer and
>         >     ctx->has_fractional_divider_register). If none of the two
>         cases are ok
>         >     for the controller you could just add another one.
>         > Can we pass in a function, which gets called, won't this be more
>         > flexible? because
>         > in the future if we have some other board that has a different
>         > calculation for the baud rate
>         > the function will take care of it.
>         It's possible. Please make sure to be compatible with the
>         current API.
>         For example if the pointer is NULL you should call the legacy
>         function
>         instead.
>     I will be adding an extra field, a function pointer to ns16550_context,
>     the prototype of the function would be *uint32_t
>     calculate_baud_divisor( ns16550_context * )*
>     This is will calculate the baud divisor using its own formula and
>     the initial baud.
>     If this function is not NULL then it would be called inside
>     *NS16550_GetBaudDivisor* function,
>         >     > For console selection, my plan is to search for the aux
>         node using
>         >     > compatible
>         >     > property and if its status is enabled, then initialize
>         the AUX
>         >     uart and
>         >     > set the BSP_output_char
>         >     > to aux_output_char, else pl011_output_char. All this
>         will be done
>         >     inside
>         >     > the uart_probe function,
>         >     > except for the initialization of AUX which will be done in
>         >     init_ctx_aux.
>         >     > And finally, call the output char
>         >     > function using *BSP_output_char. Do you have any neat
>         way to do this?
>         >     I don't have an example for a similar case at hand. So:
>         No, no neat way
>         >     that I can tell you.
>         >     Before you start to write code: Please take a look at the
>         different
>         >     beagle variants what is possible. Is there a variant where
>         AUX uart
>         >     would be there but shouldn't be used as a console (one of
>         the Zeros
>         >     maybe or the compute module?). How does Raspbian or
>         FreeBSD decide which
>         >     port should be used? Maybe they decide based on the
>         commandline.txt? In
>         >     such a case it would be better to just initialize all
>         active (in the
>         >     fdt) serial ports and decide based on the commandline too.
>         > The Documentation says the following:
>         > *By default, on Raspberry Pis equipped with the
>         wireless/Bluetooth*
>         > *module (Raspberry Pi 3 and Raspberry Pi Zero W), **the PL011
>         UART is*
>         > *connected to the Bluetooth module, while the mini UART is
>         used as the
>         > primary UART and*
>         > *will have a Linux console on it. On all other models, the
>         PL011 is used
>         > as the primary UART.
>         > *In Linux device terms, by default, /dev/ttyS0 refers to the
>         mini UART,
>         > and /dev/ttyAMA0 refers*
>         > *to the PL011. The primary UART is the one assigned to the Linux
>         > console, which depends on*
>         > *the Raspberry Pi model as described above. There are also
>         symlinks:
>         > /dev/serial0, which always*
>         > *refers to the primary UART (if enabled), and /dev/serial1, which
>         > similarly always refers to the secondary UART (if enabled).*
>         > I checked in all the DTB files, by decompiling them (files are
>         > from https://github.com/raspberrypi/firmware/tree/master/boot).
>         > In all board with support for wireless and bluetooth, the AuX
>         is enabled
>         > and serial0 points to it. So we could use serial0
>         > to find the correct UART port. I think this is solid enough.
>         So, should
>         > I use this approach?
>         Sounds OK. If possible please initialize the other UART too if it is
>         enabled in the FDT. Although we don't support bluetooth yet
>         maybe there
>         will be support in the future or someone wants to do it in the
>         application.
>     I will go with this method then.
>         > Or if using the command line, then we need to move the link to
>         > CONSOLE_DEVICE to console_initialize, and parse the
>         > command line twice. If this is no problem, then we could use this
>         > approach also.
>         Would be possible too.
>         >     > And why don't we have a function similar
>         to *of_device_is_available*,
>         >     > since there will be more and more
>         >     > FDT based boards, this will be really helpful.
>         >     I agree that it would be helpful. Seems that you just
>         found a function
>         >     that should be in a FDT framework.
>         >     RTEMS currently only has the basic libfdt functions and
>         some RTEMS
>         >     specific ones. The of_... functions belong to the FreeBSD
>         "Open Firmware
>         >     Bus" which is an abstraction layer on top of FDT. It would
>         be great to
>         >     identify useful ones and port them or provide an RTEMS
>         implementation.
>         >     Like already discussed this could be part of a GSoC project.
>         >     Best regards
>         >     Christian
>         >     > On Sun, Jan 5, 2020 at 12:57 AM Christian Mauderer
>         >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>         >     >     On 04/01/2020 09:32, Niteesh wrote:
>         >     >     > We could now run RTEMS on Rpi3. I tried examples
>         from the
>         >     samples
>         >     >     > section and they run
>         >     >     > fine. But still, a lot of functionality has to
>         tested since it
>         >     >     uses the
>         >     >     > RPI2 BSP. To test these examples
>         >     >     > I used a simple driver for the AUX.
>         >     >     > The documentation from BCM link
>           <https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf> (pg
>         >     >     > no 10) states that
>         >     >     >     *The implemented UART is not a 16650
>         compatible UART However
>         >     >     as far
>         >     >     >     as possible the first 8 control and status
>         registers are
>         >     laid out
>         >     >     >     like a 16550 UART.*
>         >     >     It also tells
>         >     >         "Al 16550 register bits which are not supported
>         can be
>         >     written but
>         >     >     will be ignored and read back as 0. All control bits for
>         >     simple UART
>         >     >     receive/transmit operations are available."
>         >     >     So I would expect that not everything works like
>         expected (for
>         >     example
>         >     >     setting DCD, DSR, DTR, RI - they are not there for
>         the mini
>         >     UART) but
>         >     >     the basic stuff should work.
>         >     >     > My question is can we use the existing ns16550
>         driver or
>         >     should I
>         >     >     create
>         >     >     > a new one? I also checked the address of the
>         registers the
>         >     offsets
>         >     >     don't
>         >     >     > seem right to me, but someone should check and
>         correct me if
>         >     I am
>         >     >     wrong.
>         >     >     If you compare the registers in the existing driver
>         >     >     (NS16550_RECEIVE_BUFFER, ... in ns16550_p.h) and the
>         one in
>         >     the BCM
>         >     >     datasheet the registers look very similar (at least
>         from the
>         >     position /
>         >     >     function). I haven't done a bit by bit comparison
>         yet. Please
>         >     note that
>         >     >     you have to do a conversion between the defines and
>         register
>         >     addresses.
>         >     >     The define gives you a register index for a 32bit
>         register. So
>         >     you have
>         >     >     to multiply by 4 to get an address. The driver is
>         designed
>         >     that you
>         >     >     provide a setRegister and getRegister function that
>         can do this
>         >     >     conversion.
>         >     >     Where did you find differences?
>         >     >     I would suggest to just try the driver.
>         > _______________________________________________
>         > devel mailing list
>         > devel at rtems.org <mailto:devel at rtems.org>
>         > http://lists.rtems.org/mailman/listinfo/devel
>         embedded brains GmbH
>         Herr Christian Mauderer
>         Dornierstr. 4
>         D-82178 Puchheim
>         Germany
>         email: christian.mauderer at embedded-brains.de
>         Phone: +49-89-18 94 741 - 18
>         Fax:   +49-89-18 94 741 - 08
>         PGP: Public key available on request.
>         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>         EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
