Raspberrypi3: AUX Uart driver
Niteesh gsnb.gn at gmail.com
Tue Jan 14 14:34:17 UTC 2020
On Tue, Jan 14, 2020 at 1:57 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 13/01/2020 19:04, Niteesh wrote:
> > The ns16550_context already has a field named baud_divisor, so if the
> > user passes
> > value for it, then we can skip the GetBaudDivisor function and use that
> > value instead.
> > Is this approach okay?
> Is the driver still able to handle different baud rates with this? Does
> the ioctl call for setting the baudrate work?
I didn't think about this, it won't work if we are using this method.
ns16550_set_attributes
calls ns16550_GetBaudDivisor, then I think we will have to stick with the
old method.
Best regards
> Christian
> > On Mon, Jan 13, 2020 at 3:46 PM Niteesh <gsnb.gn at gmail.com
> > <mailto:gsnb.gn at gmail.com>> wrote:
> >     On Mon, Jan 13, 2020 at 1:38 PM Christian Mauderer
> >     <christian.mauderer at embedded-brains.de
> >     <mailto:christian.mauderer at embedded-brains.de>> wrote:
> >         On 12/01/2020 21:26, Niteesh wrote:
> >         > On Sun, Jan 12, 2020 at 11:42 PM Christian Mauderer
> >         <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> wrote:
> >         >     Hello Niteesh,
> >         >     On 12/01/2020 16:06, Niteesh wrote:
> >         >     > The only issue, I faced while using this driver is the
> >         baud divisor is
> >         >     > calculated
> >         >     > by CLOCK_FREQ/(BAUD_RATE * 16) (*ns16550-context.c:68)*
> >         >     > but it should BAUD_DIV = (CLOCK_FREQ/(8 * BAUD_RATE)) -
> >         1, for Rpi3.
> >         >     > For testing, I assigned the baud divisor to 270 (115200
> >         bits/s) in
> >         >     > ns16550-context.c,
> >         >     > and everything works fine.
> >         >     Sounds great. In NS16550_GetBaudDivisor there is already a
> >         case where
> >         >     the baudDivisor is calculated differently (depending on
> >         >     ctx->has_precision_clock_synthesizer and
> >         >     ctx->has_fractional_divider_register). If none of the two
> >         cases are ok
> >         >     for the controller you could just add another one.
> >         > Can we pass in a function, which gets called, won't this be
> more
> >         > flexible? because
> >         > in the future if we have some other board that has a different
> >         > calculation for the baud rate
> >         > the function will take care of it.
> >         It's possible. Please make sure to be compatible with the
> >         current API.
> >         For example if the pointer is NULL you should call the legacy
> >         function
> >         instead.
> >     I will be adding an extra field, a function pointer to
> ns16550_context,
> >     the prototype of the function would be *uint32_t
> >     calculate_baud_divisor( ns16550_context * )*
> >     This is will calculate the baud divisor using its own formula and
> >     the initial baud.
> >     If this function is not NULL then it would be called inside
> >     *NS16550_GetBaudDivisor* function,
> >         >     > For console selection, my plan is to search for the aux
> >         node using
> >         >     > compatible
> >         >     > property and if its status is enabled, then initialize
> >         the AUX
> >         >     uart and
> >         >     > set the BSP_output_char
> >         >     > to aux_output_char, else pl011_output_char. All this
> >         will be done
> >         >     inside
> >         >     > the uart_probe function,
> >         >     > except for the initialization of AUX which will be done
> in
> >         >     init_ctx_aux.
> >         >     > And finally, call the output char
> >         >     > function using *BSP_output_char. Do you have any neat
> >         way to do this?
> >         >     I don't have an example for a similar case at hand. So:
> >         No, no neat way
> >         >     that I can tell you.
> >         >     Before you start to write code: Please take a look at the
> >         different
> >         >     beagle variants what is possible. Is there a variant where
> >         AUX uart
> >         >     would be there but shouldn't be used as a console (one of
> >         the Zeros
> >         >     maybe or the compute module?). How does Raspbian or
> >         FreeBSD decide which
> >         >     port should be used? Maybe they decide based on the
> >         commandline.txt? In
> >         >     such a case it would be better to just initialize all
> >         active (in the
> >         >     fdt) serial ports and decide based on the commandline too.
> >         > The Documentation says the following:
> >         > *By default, on Raspberry Pis equipped with the
> >         wireless/Bluetooth*
> >         > *module (Raspberry Pi 3 and Raspberry Pi Zero W), **the PL011
> >         UART is*
> >         > *connected to the Bluetooth module, while the mini UART is
> >         used as the
> >         > primary UART and*
> >         > *will have a Linux console on it. On all other models, the
> >         PL011 is used
> >         > as the primary UART.
> >         > *In Linux device terms, by default, /dev/ttyS0 refers to the
> >         mini UART,
> >         > and /dev/ttyAMA0 refers*
> >         > *to the PL011. The primary UART is the one assigned to the
> Linux
> >         > console, which depends on*
> >         > *the Raspberry Pi model as described above. There are also
> >         symlinks:
> >         > /dev/serial0, which always*
> >         > *refers to the primary UART (if enabled), and /dev/serial1,
> which
> >         > similarly always refers to the secondary UART (if enabled).*
> >         > I checked in all the DTB files, by decompiling them (files are
> >         > from https://github.com/raspberrypi/firmware/tree/master/boot
> >         > In all board with support for wireless and bluetooth, the AuX
> >         is enabled
> >         > and serial0 points to it. So we could use serial0
> >         > to find the correct UART port. I think this is solid enough.
> >         So, should
> >         > I use this approach?
> >         Sounds OK. If possible please initialize the other UART too if
> it is
> >         enabled in the FDT. Although we don't support bluetooth yet
> >         maybe there
> >         will be support in the future or someone wants to do it in the
> >         application.
> >     I will go with this method then.
> >         > Or if using the command line, then we need to move the link to
> >         > CONSOLE_DEVICE to console_initialize, and parse the
> >         > command line twice. If this is no problem, then we could use
> this
> >         > approach also.
> >         Would be possible too.
> >         >     > And why don't we have a function similar
> >         to *of_device_is_available*,
> >         >     > since there will be more and more
> >         >     > FDT based boards, this will be really helpful.
> >         >     I agree that it would be helpful. Seems that you just
> >         found a function
> >         >     that should be in a FDT framework.
> >         >     RTEMS currently only has the basic libfdt functions and
> >         some RTEMS
> >         >     specific ones. The of_... functions belong to the FreeBSD
> >         "Open Firmware
> >         >     Bus" which is an abstraction layer on top of FDT. It would
> >         be great to
> >         >     identify useful ones and port them or provide an RTEMS
> >         implementation.
> >         >     Like already discussed this could be part of a GSoC
> project.
> >         >     Best regards
> >         >     Christian
> >         >     > On Sun, Jan 5, 2020 at 12:57 AM Christian Mauderer
> >         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >         >     >     On 04/01/2020 09:32, Niteesh wrote:
> >         >     >     > We could now run RTEMS on Rpi3. I tried examples
> >         from the
> >         >     samples
> >         >     >     > section and they run
> >         >     >     > fine. But still, a lot of functionality has to
> >         tested since it
> >         >     >     uses the
> >         >     >     > RPI2 BSP. To test these examples
> >         >     >     > I used a simple driver for the AUX.
> >         >     >     > The documentation from BCM link
> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
> > (pg
> >         >     >     > no 10) states that
> >         >     >     >     *The implemented UART is not a 16650
> >         compatible UART However
> >         >     >     as far
> >         >     >     >     as possible the first 8 control and status
> >         registers are
> >         >     laid out
> >         >     >     >     like a 16550 UART.*
> >         >     >     It also tells
> >         >     >         "Al 16550 register bits which are not supported
> >         can be
> >         >     written but
> >         >     >     will be ignored and read back as 0. All control bits
> for
> >         >     simple UART
> >         >     >     receive/transmit operations are available."
> >         >     >     So I would expect that not everything works like
> >         expected (for
> >         >     example
> >         >     >     setting DCD, DSR, DTR, RI - they are not there for
> >         the mini
> >         >     UART) but
> >         >     >     the basic stuff should work.
> >         >     >     > My question is can we use the existing ns16550
> >         driver or
> >         >     should I
> >         >     >     create
> >         >     >     > a new one? I also checked the address of the
> >         registers the
> >         >     offsets
> >         >     >     don't
> >         >     >     > seem right to me, but someone should check and
> >         correct me if
> >         >     I am
> >         >     >     wrong.
> >         >     >     If you compare the registers in the existing driver
> >         >     >     (NS16550_RECEIVE_BUFFER, ... in ns16550_p.h) and the
> >         one in
> >         >     the BCM
> >         >     >     datasheet the registers look very similar (at least
> >         from the
> >         >     position /
> >         >     >     function). I haven't done a bit by bit comparison
> >         yet. Please
> >         >     note that
> >         >     >     you have to do a conversion between the defines and
> >         register
> >         >     addresses.
> >         >     >     The define gives you a register index for a 32bit
> >         register. So
> >         >     you have
> >         >     >     to multiply by 4 to get an address. The driver is
> >         designed
> >         >     that you
> >         >     >     provide a setRegister and getRegister function that
> >         can do this
> >         >     >     conversion.
> >         >     >     Where did you find differences?
> >         >     >     I would suggest to just try the driver.
> >         > _______________________________________________
> >         > devel mailing list
> >         > devel at rtems.org <mailto:devel at rtems.org>
> >         > http://lists.rtems.org/mailman/listinfo/devel
> >         embedded brains GmbH
> >         Herr Christian Mauderer
> >         Dornierstr. 4
> >         D-82178 Puchheim
> >         Germany
> >         email: christian.mauderer at embedded-brains.de
> >         Phone: +49-89-18 94 741 - 18
> >         Fax:   +49-89-18 94 741 - 08
> >         PGP: Public key available on request.
> >         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> >         EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200114/b4320ec1/attachment-0001.html>
