Raspberry Pi test report
Alan Cudmore alan.cudmore at gmail.com
Mon Jan 20 23:20:48 UTC 2020
As it turns out the latest RTEMS master may need some of the dtb
and/or overlay files in the raspberry pi SD card. But the updated
instructions that Niteesh submitted for the raspberrypi BSP should
still be valid.
Either way, we should be able to automate it. A firmware release on
Github is ~180 megabytes. If you clone the whole repository, it's 10+
Gigabytes, probably because you get every binary release.
I'm trying to troubleshoot the RPi 2 SMP a little bit now. Non SMP
code seems to work on the Pi 2, but when you have an example with
#define CONFIGURE_MAXIMUM_PROCESSORS 4
it crashes during initialization.
On Mon, Jan 20, 2020 at 5:06 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/1/20 9:42 am, Alan Cudmore wrote:
> > I finally found the time to try the latest RTEMS head on my collection of
> > Raspberry Pi models.
> > The last time I tried to run RTEMS on a Pi, I had trouble with the current
> > version of the Raspberry Pi Firmware, so I had to go back to a specific tag on
> > the Rasberry Pi firmware repository to get RTEMS to work. This time, the head of
> > the firmware repository seems to work (at least on the single core models)
> > To keep things simple, I'm just going address the single core models here, I can
> > follow up after I finish testing the Raspberry Pi 2.
> > Test Setup:
> > I used the git.rtems.org <http://git.rtems.org> rtems master from Jan 03 2020.
> > I used the Raspberry Pi firmware from the same date.
> > The firmware can be found here:
> > https://github.com/raspberrypi/firmware/tree/master/boot
> > To boot an RTEMS image, you can copy all files from the above "boot" directory
> > on a DOS formatted SD/MicroSD card along with the RTEMS image (more about that
> > in a minute).
> > On the SD card, I deleted the "dtb" files, as well as the overlay directory. I
> > dont think these are necessary to boot an RTEMS image.
> Interesting. Do you think support for this could be added to the RTEMS boot
> image tool?
> https://docs.rtems.org/branches/master/user/tools/boot-image.html
> It would be nice if we can automate the creation of an SD card image and
> abstract the low level host things needed to manage an SD card.
> I wonder if an option could be added to download and cache the boot files then
> that are copied to the SD card with the kernel image and a suitable config.
> Chris
