[PATCH v2] Raspberrypi: updated the console interface.
Niteesh gsnb.gn at gmail.com
Tue Jan 21 12:17:26 UTC 2020
I have sent a new patch for the AUX UART driver, can you
please take a look at it?
https://www.mail-archive.com/devel@rtems.org/msg21615.html
https://www.mail-archive.com/devel@rtems.org/msg21614.html
On Tue, Jan 21, 2020 at 2:42 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 21/01/2020 00:33, Chris Johns wrote:
> > On 29/12/19 8:03 pm, Christian Mauderer wrote:
> >> - You can use a real hardware debugger for it. That's what I currently
> >> do - also qemu + gdb could be more powerfull. For that you basically
> >> connect the Alt4 pins (see https://pinout.xyz/pinout/jtag) to a
> hardware
> >> debugger (something supported by OpenOCD, Segger J-Link, ...) add
> >> "gpio=22-27=a4" to your config.txt and load a very minimal kernel that
> >> does just an endless loop. Note that I had some trouble debugging more
> >> than one core with my debugger.
> > This is really valuable information, thank you. It would be nice to see
> it in
> > the BSP section of the user manual :)
> > Chris
> You can find that stuff with not too much search on a lot of different
> web sites. Therefore I didn't think about adding it to the manual. But I
> can add a short note in the next days.
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200121/b1f882ac/attachment.html>
