[PATCH v2] Raspberrypi: updated the console interface.
Christian Mauderer
list at c-mauderer.de
Tue Jan 21 20:26:34 UTC 2020
Hello Niteesh,
yes, sorry. At work I only put a limited time to the mailing list as
long as the patches are not work related and privately I'm currently
quite busy with another project (will be better after 01.02.). Therefore
I didn't have a look yet. I'll take a look at the patches. I think there
is also still a documentation patch outstanding. I'll give some feedback
there too.
Best regards
Christian
On 21/01/2020 13:17, Niteesh wrote:
> I have sent a new patch for the AUX UART driver, can you
> please take a look at it?
> https://www.mail-archive.com/devel@rtems.org/msg21615.html
> https://www.mail-archive.com/devel@rtems.org/msg21614.html
> On Tue, Jan 21, 2020 at 2:42 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
> On 21/01/2020 00:33, Chris Johns wrote:
> > On 29/12/19 8:03 pm, Christian Mauderer wrote:
> >> - You can use a real hardware debugger for it. That's what I
> currently
> >> do - also qemu + gdb could be more powerfull. For that you basically
> >> connect the Alt4 pins (see https://pinout.xyz/pinout/jtag) to a
> hardware
> >> debugger (something supported by OpenOCD, Segger J-Link, ...) add
> >> "gpio=22-27=a4" to your config.txt and load a very minimal kernel
> that
> >> does just an endless loop. Note that I had some trouble debugging
> more
> >> than one core with my debugger.
> > This is really valuable information, thank you. It would be nice
> to see it in
> > the BSP section of the user manual :)
> > Chris
> You can find that stuff with not too much search on a lot of different
> web sites. Therefore I didn't think about adding it to the manual. But I
> can add a short note in the next days.
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
