[PATCH v3] doc/raspberrypi: Added instructions for raspberrypi
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Jan 23 13:43:27 UTC 2020
On 23/01/2020 14:41, Niteesh wrote:
>         > +Raspberry Pi's.
>         I have to be honest: I'm not sure here. As far as I know the
>         apostroph
>         (') is a sign that you left something out. I'm not sure whether
>         there
>         are cases in English where you use it other than that case. But
>         I would
>         say that you didn't leave anything out in "Pi's" and therefore the
>         plural should be "Pis" even if it looks odd.
>         Some comment from a native speaker?
> Any update on this? As I have said, I added instructions for passing DTB
> file, I will
> send the patch once this issue is resolved.
Let's solve it with another method:
https://www.raspberrypi.org/blog/teaching-pinet/
The official homepage for the RPi uses "Raspberry Pis".
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
