[PATCH v3] doc/raspberrypi: Added instructions for raspberrypi
Niteesh
gsnb.gn at gmail.com
Thu Jan 23 13:41:06 UTC 2020
On Wed, Jan 22, 2020 at 6:27 AM Niteesh <gsnb.gn at gmail.com> wrote:
> On Wed, Jan 22, 2020 at 2:30 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> Hello Niteesh,
>> you had two different "v3" patches. Therefore I missed this one. I
>> thought there was still a review comment from Gedare pending (which he
>> added at the v2 patch but after the first v3 has been sent).
> I have added instruction about installing QEMU from RSB as he said.
> On 12/01/2020 19:47, G S Niteesh wrote:
>> > Added instructions to run examples on raspberrypi.
>> > user/bsps/arm/raspberrypi.rst | 85 ++++++++++++++++++++++++++++++++++-
>> > 1 file changed, 84 insertions(+), 1 deletion(-)
>> > diff --git a/user/bsps/arm/raspberrypi.rst
>> b/user/bsps/arm/raspberrypi.rst
>> > index 4ef75bd..8e4b38c 100644
>> > --- a/user/bsps/arm/raspberrypi.rst
>> > +++ b/user/bsps/arm/raspberrypi.rst
>> > @@ -5,4 +5,87 @@
>> > raspberrypi
>> > -TODO.
>> > +This BSP supports `Raspberry Pi 1` and `Raspberry Pi 2` currently.
>> > +The support for `Raspberry Pi 3` is work under progress.
>> > +The default bootloader on the Raspberry Pi which is used to boot
>> Raspbian
>> > +or other OS can be also used to boot RTEMS. U-boot can also be used.
>> > +Setup SD card
>> > +The Raspberry Pis have an unconventional booting mechanism. The GPU
>> > +boots first, initializes itself, runs the bootloader and starts the
>> CPU.
>> > +The bootloader looks for a kernel image, by default the kernel images
>> must
>> > +have a name of the form ``kernel*.img`` but this can be changed by
>> adding
>> > +`kernel=<img_name>` to ``config.txt``.
>> > +You must provide the required files for the GPU to proceed. These files
>> > +can be downloaded from
>> > +`the Raspberry Pi Firmware Repository <
>> https://github.com/raspberrypi/firmware/tree/master/boot>`_.
>> > +You can remove the ``kernel*.img`` files if you want too, but don't
>> touch the other files.
>> This line seems a bit long. Please break at 80 chars. The link above it
>> is OK to violate that rule because it would most likely not work with a
>> line break.
>> > +Copy these files in to a SD card with FAT filesystem.
>> > +Kernel image
>> > +The following steps show how to run ``hello.exe`` on a Raspberry Pi 2.
>> > +The same instructions can be applied to Raspberry Pi 1 also.
>> > +Other executables can be processed in a similar way.
>> > +To create the kernel image:
>> > +.. code-block:: none
>> > + arm-rtems5-objcopy -Obinary hello.exe kernel.img
>> > +Copy the kernel image to the SD card.
>> > +Make sure you have these lines below, in your ``config.txt``.
>> > + enable-uart=1
>> > + kernel_address=0x200000
>> > + kernel=kernel.img
>> > +Testing using QEMU
>> > +QEMU can be built using RSB. Navigate to ``<SOURCE_BUILDER_DIR>/rtems``
>> > +and run this command.
>> > + ../source-builder/sb-set-builder --prefix=<TOOLCHAIN_DIR>
>> devel/qemu4.bset
>> > +**Note**: Replace ``<SOURCE_BUILDER_DIR>`` and ``<TOOLCHAIN_DIR>``
>> with the correct
>> > +path of the directories. For example, if you used quick-start section
>> as your reference, these
>> > +two will be ``$HOME/quick-start/src/rsb`` and
>> ``$HOME/quick-start/rtems/5`` respectively,
>> Again: Please use a 80 char limit (except for the code block).
>> > +QEMU along with GDB can be used for debugging, but it only supports
>> > +Raspberry Pi 2 and the emulation is also incomplete. So some of the
>> > +features might not work as expected.
>> > +Make sure your version of QEMU > v2.6, because older ones don't support
>> "...of QEMU is newer than v2.6 ..."
>> For most readers it's much faster to read a text without cryptic
>> abbreviations.
>> > +Raspberry Pi's.
>> I have to be honest: I'm not sure here. As far as I know the apostroph
>> (') is a sign that you left something out. I'm not sure whether there
>> are cases in English where you use it other than that case. But I would
>> say that you didn't leave anything out in "Pi's" and therefore the
>> plural should be "Pis" even if it looks odd.
> Some comment from a native speaker?
Any update on this? As I have said, I added instructions for passing DTB
file, I will
send the patch once this issue is resolved.
> And we also have to add instructions for including the DTB file. I'll make
> the
> changes you mentioned and also add instructions for including DTB.
> I'll send in the patch, once we get a confirmation from a native speaker,
> anyhow
> I googled, and I think it should be Pis. The *'s *symbolizes
> possessiveness.
>> > + qemu-system-arm -M raspi2 -m 1G -kernel hello.exe -serial
>> mon:stdio -nographic -S -s
>> > +This starts QEMU and creates a socket at port ``localhost:1234`` for
>> GDB to
>> > +connect.
>> > +In a new terminal, run GDB using
>> > + arm-rtems5-gdb hello.exe
>> > + tar remote:1234
>> > + load
>> > +This will connect GDB to QEMU and will load the application.
>> > +**Note**: Add ``set scheduler-locking on`` in GDB if you have any
>> issues
>> > +running the examples.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200123/2a8d80c2/attachment.html>
