[PATCH 1/2] bsp/xen: Rename xen_virtual target to xen_gicv2
Jeff Kubascik jeff.kubascik at dornerworks.com
Thu Jan 23 16:04:35 UTC 2020
Rename the xen_virtual target to xen_gicv2, to reflect that this target
is using the GICv2 interrupt controller driver. A RTEMS virtual machine
may be required to use a different interrupt controller driver,
depending on the underlying platform.
 bsps/arm/xen/config/{xen_virtual.cfg => xen_gicv2.cfg} | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
 rename bsps/arm/xen/config/{xen_virtual.cfg => xen_gicv2.cfg} (82%)
diff --git a/bsps/arm/xen/config/xen_virtual.cfg b/bsps/arm/xen/config/xen_gicv2.cfg
similarity index 82%
rename from bsps/arm/xen/config/xen_virtual.cfg
rename to bsps/arm/xen/config/xen_gicv2.cfg
index 1b5031c3f0..ebb6131693 100644
--- a/bsps/arm/xen/config/xen_virtual.cfg
+++ b/bsps/arm/xen/config/xen_gicv2.cfg
@@ -1,5 +1,5 @@
-#  Configuration file for the "xen_virtual" target
+#  Configuration file for the "xen_gicv2" target
 include $(RTEMS_ROOT)/make/custom/default.cfg
2.17.1
