[PATCH 2/2] bsp/xen: Add xen_gicv3 target
Jeff Kubascik
jeff.kubascik at dornerworks.com
Thu Jan 23 16:04:36 UTC 2020
Implement the xen_gicv3 target that uses the GICv3 interrupt controller
driver. This is required for platforms where the underlying processor is
using GICv3 with no legacy operation support.
bsps/arm/xen/config/xen_gicv3.cfg | 14 ++++++++++++++
bsps/arm/xen/include/bsp.h | 10 ++++++++++
bsps/arm/xen/start/bspstartmmu.c | 14 ++++++++++++++
c/src/lib/libbsp/arm/xen/Makefile.am | 5 +++++
c/src/lib/libbsp/arm/xen/configure.ac | 10 ++++++++++
5 files changed, 53 insertions(+)
create mode 100644 bsps/arm/xen/config/xen_gicv3.cfg
diff --git a/bsps/arm/xen/config/xen_gicv3.cfg b/bsps/arm/xen/config/xen_gicv3.cfg
new file mode 100644
index 0000000000..d5ca72b43d
--- /dev/null
+++ b/bsps/arm/xen/config/xen_gicv3.cfg
@@ -0,0 +1,14 @@
+# Configuration file for the "xen_gicv3" target
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
+CFLAGS_OPTIMIZE_V += -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/bsps/arm/xen/include/bsp.h b/bsps/arm/xen/include/bsp.h
index e5b23a902e..13b7592f1e 100644
--- a/bsps/arm/xen/include/bsp.h
+++ b/bsps/arm/xen/include/bsp.h
@@ -58,11 +58,21 @@
extern "C" {
#endif /* __cplusplus */
+#if USE_IRQ_GICV2
#define BSP_ARM_GIC_CPUIF_BASE 0x03002000
#define BSP_ARM_GIC_CPUIF_LENGTH 0x1000
#define BSP_ARM_GIC_DIST_BASE 0x03001000
#define BSP_ARM_GIC_DIST_LENGTH 0x1000
+#endif /* USE_IRQ_GICV2 */
+#if USE_IRQ_GICV3
+#define BSP_ARM_GIC_DIST_BASE 0x03001000
+#define BSP_ARM_GIC_DIST_LENGTH 0x10000
+#define BSP_ARM_GIC_REDIST_BASE 0x03020000
+#define BSP_ARM_GIC_REDIST_LENGTH 0x1000000
+#endif /* USE_IRQ_GICV3 */
#define BSP_ARM_A9MPCORE_SCU_BASE 0
diff --git a/bsps/arm/xen/start/bspstartmmu.c b/bsps/arm/xen/start/bspstartmmu.c
index b24af89d41..6310c37ff1 100644
--- a/bsps/arm/xen/start/bspstartmmu.c
+++ b/bsps/arm/xen/start/bspstartmmu.c
@@ -36,6 +36,7 @@
BSP_START_DATA_SECTION static const arm_cp15_start_section_config
xen_bsp_mmu_config_table[] = {
ARMV7_CP15_START_DEFAULT_SECTIONS,
+#if USE_IRQ_GICV2
.begin = BSP_ARM_GIC_DIST_BASE,
.end = BSP_ARM_GIC_DIST_BASE + BSP_ARM_GIC_DIST_LENGTH,
@@ -44,7 +45,20 @@ xen_bsp_mmu_config_table[] = {
.begin = BSP_ARM_GIC_CPUIF_BASE,
.end = BSP_ARM_GIC_CPUIF_BASE + BSP_ARM_GIC_CPUIF_LENGTH,
.flags = ARMV7_MMU_DEVICE
+#if USE_IRQ_GICV3
+ .begin = BSP_ARM_GIC_DIST_BASE,
+ .end = BSP_ARM_GIC_DIST_BASE + BSP_ARM_GIC_DIST_LENGTH,
+ .flags = ARMV7_MMU_DEVICE
+ .begin = BSP_ARM_GIC_REDIST_BASE,
+ .end = BSP_ARM_GIC_REDIST_BASE + BSP_ARM_GIC_REDIST_LENGTH,
.begin = BSP_XEN_VPL011_BASE,
.end = BSP_XEN_VPL011_BASE + BSP_XEN_VPL011_LENGTH,
diff --git a/c/src/lib/libbsp/arm/xen/Makefile.am b/c/src/lib/libbsp/arm/xen/Makefile.am
index fecb665af4..4db0b78649 100644
--- a/c/src/lib/libbsp/arm/xen/Makefile.am
+++ b/c/src/lib/libbsp/arm/xen/Makefile.am
@@ -34,7 +34,12 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-generic-t
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
# irq
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
+if USE_IRQ_GICV2
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-gic.c
+endif
+if USE_IRQ_GICV3
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-gicv3.c
+endif
# console
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/console/console.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
diff --git a/c/src/lib/libbsp/arm/xen/configure.ac b/c/src/lib/libbsp/arm/xen/configure.ac
index 86ec0033ef..edeaba4e20 100644
--- a/c/src/lib/libbsp/arm/xen/configure.ac
+++ b/c/src/lib/libbsp/arm/xen/configure.ac
@@ -26,6 +26,16 @@ RTEMS_BSPOPTS_HELP([ARM_GENERIC_TIMER_USE_VIRTUAL],[use virtual ARM generic time
RTEMS_BSPOPTS_SET([ARM_GENERIC_TIMER_UNMASK_AT_TICK],[*],[1])
RTEMS_BSPOPTS_HELP([ARM_GENERIC_TIMER_UNMASK_AT_TICK],[unmask the timer in the tick handler, since Xen will mask the virtual timer before injecting the interrupt to the guest])
+RTEMS_BSPOPTS_SET([USE_IRQ_GICV2],[xen_gicv2],[1])
+RTEMS_BSPOPTS_SET([USE_IRQ_GICV2],[*],[0])
+RTEMS_BSPOPTS_HELP([USE_IRQ_GICV2],[use the GICv2 interrupt controller driver])
+AM_CONDITIONAL(USE_IRQ_GICV2,test "$USE_IRQ_GICV2" = "1")
+RTEMS_BSPOPTS_SET([USE_IRQ_GICV3],[xen_gicv3],[1])
+RTEMS_BSPOPTS_SET([USE_IRQ_GICV3],[*],[0])
+RTEMS_BSPOPTS_HELP([USE_IRQ_GICV3],[use the GICv3 interrupt controller driver])
+AM_CONDITIONAL(USE_IRQ_GICV3,test "$USE_IRQ_GICV3" = "1")
RTEMS_BSPOPTS_SET([BSP_START_ZIMAGE_HEADER],[*],[1])
RTEMS_BSPOPTS_HELP([BSP_START_ZIMAGE_HEADER],[include zImage boot header])
2.17.1
