Requirement Document generator tool
Chris Johns
chrisj at rtems.org
Tue Jan 28 00:42:08 UTC 2020
On 28/1/20 10:48 am, Joel Sherrill wrote:
> On Mon, Jan 27, 2020 at 4:18 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 24/1/20 9:57 pm, Jose Valdez wrote:
> > In fact these tools target the pre-qualified project.
> Do you see this as different to the RTEMS project?
> > Since it was Sebastian who suggested to create this set of python tools,
> I think Sebastian is wanting a smooth path for these tools into the project.
> > I think the idea was to standardize the use of python not only for this
> project, but also for other python written code in RTEMS community. This has
> the advantages that every written python code is standard, but has the
> drawbacks:
> > -> old written code would need to be adapted to the standards.
> How different to the proposed coding standard is the existing code? Why not base
> the coding standard on what exists in the code base?
> This is a very important question.
> Have you evaluated the size of the task to update the existing code? How would
> get such changes for the rtems-tools and the RSB be tested and integrated back
> into the project? This apporach seems like a huge review task for me.
> It could be or it may turn out that there isn't much changed. Without someone
> running the reformatter and reporting, we won't know.
Running a reformatter may give you an idea of the scale however I have some
concerns as Python's logic is based on indent levels and a missed level changes
the logic. I am not sure how you know such a tool is safe to use unless you
review all the changes.
> I tend to think it is worth knowing if this is a monster or a mouse before making
> a decision.
Yes this is important and also if it is a monster which specific rules make it
so? It maybe most of the rules are fine.
If these rules are important to the qual effort I hope they see the value in
find these answers for us.
> > Another option could be leave it as it is and only do this for new written
> code.
> It would be confusing to any new user to the code to have code written to a
> standard and code that is not? If you edit the old code is it to the new
> standard? If you edit an old file do you need to update the whole file?
> If we accept a standard, then it is all or nothing. I'm going to sound like a
> cranky old man but we have said things like this before and regretted it
> every time. Consistency is critical.
If you are a cranky old man then that must make me one as well. Ah the youth of
today ... :)
> Quick run of sloccount for a baseline
> + rtems-tools -
> Totals grouped by language (dominant language first):
> ansic: 47237 (49.86%)
> cpp: 25837 (27.27%)
> python: 21227 (22.40%)
> sh: 442 (0.47%)
Nice start. A more accurate report on this code would mean removing the imported
pieces.
> + rtems-source-builder/source-builder -
> SLOC Directory SLOC-by-Language (Sorted)
> 14314 sb python=14169,sh=145
> 65 top_dir sh=65
> 0 config (none)
There are the .cfg and .bset files.
> 0 patches (none)
> So we have about 35K SLOC or Python by that.
> No idea how the new standard versus the old looks. I thought Python had a consistent
> style but I could be very wrong. :(
I am not sure, I have never looked. My python skills have developed producing
these tools and this code. I know doc comments are missing.
> > -> at some point some tools need to be upgraded (ex: python 3.7 will
> become unusable in 2030 Operating systems).
> I am not sure how this relates. Yes it will need to update however we need to
> support python2 for user facing tools for a while yet. A lot of what we do and
> how we work is historically driven.
> CentOS 8 was just released in October. None of the big organization users I
> see are using it yet.
> We need to make a LTS release with 5 on Python 2 as a minimum. I feel strongly
> about that.
And I suspect longer.
> As long as the tools are written in a python agnostic manner, the version won't
> matter.
Yes I agree, we should aim for a middle ground and avoid hitting any of issues
that can arise.
> We need some test cases for the tools to verify them
Yes.
> > I hope soon to formalize our suggestion to you and then you may review it
> (and propose changes if you find appropriate).
> I suggest working in the open and with us will be more beneficial in the
> long term.
> +1 I can't agree strongly enough.
> Note, I am assuming the remainder of the email was Christian's. The quoting from
> your email client made it difficult to tell.
> Chris
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
