[PATCH 0/2] Add new Xen BSP target using GICv3 driver
Joel Sherrill
joel at rtems.org
Tue Jan 28 17:02:14 UTC 2020
I have merged all of Jeff's patches. Please check that they work as merged
and do not introduce warnings.
Thanks.
--joel
On Thu, Jan 23, 2020 at 10:04 AM Jeff Kubascik <
jeff.kubascik at dornerworks.com> wrote:
> This patch set renames the "xen_virtual" target to "xen_gicv2", and adds a
> new
> "xen_gicv3" target that uses the GICv3 driver. This is the only hardware
> dependency I have identified that a RTEMS virtual machine has with Xen on
> ARMv8.
> The "xen_gicv3" target has been confirmed to work with Xen and ARMv8 QEMU.
> This
> required 3 patches to QEMU, which have been submitted to QEMU devel. As of
> now,
> all 3 patches were accepted into master.
> Jeff Kubascik (2):
> bsp/xen: Rename xen_virtual target to xen_gicv2
> bsp/xen: Add xen_gicv3 target
> .../xen/config/{xen_virtual.cfg => xen_gicv2.cfg} | 2 +-
> bsps/arm/xen/config/xen_gicv3.cfg | 14 ++++++++++++++
> bsps/arm/xen/include/bsp.h | 10 ++++++++++
> bsps/arm/xen/start/bspstartmmu.c | 14 ++++++++++++++
> c/src/lib/libbsp/arm/xen/Makefile.am | 5 +++++
> c/src/lib/libbsp/arm/xen/configure.ac | 10 ++++++++++
> 6 files changed, 54 insertions(+), 1 deletion(-)
> rename bsps/arm/xen/config/{xen_virtual.cfg => xen_gicv2.cfg} (82%)
> create mode 100644 bsps/arm/xen/config/xen_gicv3.cfg
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200128/43dff361/attachment.html>
