RSB create report error
Sebastian Huber
Wed Jul 1 09:21:24 UTC 2020
Hello,
I tried to build the latest RTEMS 6 tools via RSB on Linux, but there
was a failure in GDB. Unfortunately, the report generation failed:
error: building powerpc-rtems6-gdb-4e394b2-x86_64-linux-gnu-1
Build FAILED
error: failure to create error report
Build Set: Time 0:01:32.511549
Traceback (most recent call last):
File "../source-builder/sb/cmd-set-builder.py", line 26, in <module>
setbuilder.run()
File
"/scratch/git-rtems-source-builder/source-builder/sb/setbuilder.py",
line 736, in run
b.build(deps, mail = mail)
File
line 473, in build
self.build_package(configs[s], b)
File
line 258, in build_package
_build.make()
File "/scratch/git-rtems-source-builder/source-builder/sb/build.py",
line 603, in make
self._generate_report_('Build: %s' % (gerr))
line 126, in _generate_report_
self.opts, header, footer)
File
"/scratch/git-rtems-source-builder/source-builder/sb/ereport.py", line
56, in generate
l.write(os.linesep.join(r))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 81:
ordinal not in range(128)
